Comprehensive Review: " APL1 " - Advanced DSP / EQ / Phase Correction Unit - Page 39 - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 01-09-2018   #951
Elgrosso's Avatar
Rep Power: 98 Elgrosso will become famous soon enoughElgrosso will become famous soon enoughElgrosso will become famous soon enoughElgrosso will become famous soon enoughElgrosso will become famous soon enoughElgrosso will become famous soon enoughElgrosso will become famous soon enough
Originally Posted by oliverlim View Post
Thanks for your thoughts on this. I will try to remeasure my system on TDA and workshop with the apl1 EQ on and see if it is actually working well. I am still playing around with TDA to try to get my crossover/delays improved on my new setup. So it could be i am still having some issues with my setup.
Safe bet, it’s too easy to spend time on a target even if we know we have other issues uncovered.
About the loudness compensation, I tried this some time ago when I first got my horns and used to listen loud:
3 settings basically:
- for 70/75db > boost low and highs
- for 85/90db untouched
- for 100db cut low and highs
The lowest one was useful, brought up some depth and details while keeping it confortable.
And the highest one didn't really work as intended. I realized that the road noise was naturally masked by the loudness effect at high level (high level means usually high speed for me).
So the compensation on the highs was good, but the low end should have been let untouched.
Well anyway I drop the idea as I just don't bother with settings for that now, and just listen to more reasonable levels.
But I would appreciate if someone builds this feature in a box, or a plugin.
The Following User Says Thank You to Elgrosso For This Useful Post:
Holmz (02-04-2018)
Old 01-10-2018   #952
Rep Power: 36 oliverlim will become famous soon enougholiverlim will become famous soon enougholiverlim will become famous soon enougholiverlim will become famous soon enougholiverlim will become famous soon enougholiverlim will become famous soon enough
Thanks for the detailed explanation. Actually Audison bit one/bit one hd has a feature called dynamic eq. It allows you to tune 2 different eq curve at Teo different vol levels. So not the three u are looking at but two would also fit what u are trying to achieve with the loudness curve.
oliverlim is offline   Reply With Quote Quick reply to this message
Old 01-10-2018   #953
Originally Posted by cycfari View Post
I used a center speakers setup with MS-8 in my previous car for 2 seat listening. MP1 bass is heavy. I am now just running APL1 to MS8, 3 way active + small active sub.
Interesting. What does ms8 addition do? I understand it makes fir eq based on a number of location so that it sounds good in those locations?
Old 01-15-2018   #954
Rep Power: 0 cycfari will become famous soon enoughcycfari will become famous soon enoughcycfari will become famous soon enoughcycfari will become famous soon enoughcycfari will become famous soon enoughcycfari will become famous soon enough
MS-8 auto-tune the time alignment for different seats. Also if you have a center channel, the center stage will be perfect with added advantage of L7 processing.
However there is not much self tuning options other then EQ & Gain.Correct crossovers selection and amplifier gains still needs to be dialled in before the autotune,
From my personal experience, MS8 is an easy setup for novice but it wont give u the perfect sound.
cycfari is offline   Reply With Quote Quick reply to this message
Old 01-29-2018   #955
Raimonds's Avatar
http://*****aplaudio*****/
Acoustic Power Lab APL
chairman
Rep Power: 67 Raimonds will become famous soon enoughRaimonds will become famous soon enoughRaimonds will become famous soon enoughRaimonds will become famous soon enoughRaimonds will become famous soon enoughRaimonds will become famous soon enough
Dreams come true
Originally Posted by Raimonds View Post
Right now, the most compact version is stack of 4 PCBs 75 mm in high.
The all in one board 10 channel unit is a dream.
I am thinking about some kind of "kickstarter" project.
But it is too much business management for an engineer to do that.
The target or parametric eq can be used for each particular unit/driver/way
and for all system as master.
You can use ordinary parametric EQ interface and/or input as a curve in form of txt file.
10 channel unit with master EQ on input (12 FIR cores) is ready to serve demanding customers : )
The Following User Says Thank You to Raimonds For This Useful Post:
captainobvious (01-30-2018)
Old 01-29-2018   #956
Dreams come true
The board looks pretty small. Please do one for car installation
Old 01-30-2018   #957
Rep Power: 0 Spartak802 will become famous soon enoughSpartak802 will become famous soon enoughSpartak802 will become famous soon enoughSpartak802 will become famous soon enoughSpartak802 will become famous soon enoughSpartak802 will become famous soon enough
Great news, Raimonds! Will keep it in mind for my next install.
Spartak802 is offline   Reply With Quote Quick reply to this message
Old 01-30-2018   #958
Has anybody tried this Amarra player with in-built convolution feature?
Amarra 4 Luxe
It has a native support for DSD64/128 files and option for impulse response correction "on the go". For IOS 10x and Win 8 (and higher) users.
It seams that this player allows to use ordinary units (f.ex. iphone/ipod/ipad) as a source in the car with the stock install for better sounding. Using APL Workshop, one will be able to create (with the help of Raimonds) own IRS-files for correction of the sound in a car.
Sounds impressive, am I wrong?
Old 01-30-2018   #959
Rep Power: 131 LumbermanSVO has a spectacular aura aboutLumbermanSVO has a spectacular aura aboutLumbermanSVO has a spectacular aura aboutLumbermanSVO has a spectacular aura aboutLumbermanSVO has a spectacular aura aboutLumbermanSVO has a spectacular aura aboutLumbermanSVO has a spectacular aura aboutLumbermanSVO has a spectacular aura aboutLumbermanSVO has a spectacular aura about
Dreams come true
Well golly, looks I need some of those in my Home Theater rack!
Does it use the same software as in this post?: https://www.diymobileaudio.com/forum/...8-post836.html
2 channels in and 10 out?
What's the price tag on that?
Is the white switch on the front a second power switch, or a bypass switch?
Are those digital in/out RCA plugs inside the unit functional?
1986 Bronco Build
2010 Miata Build
The Following User Says Thank You to LumbermanSVO For This Useful Post:
captainobvious (01-31-2018)
Old 01-31-2018   #960
Originally Posted by crackinhedz View Post
I have to say, I love the APL.
But, my experience with the VST has not been very ideal. First, foobar2000 works perfect with the VST, but I hate foobar2000 as my media player...not very carpc friendly, small text etc.
Not quite correct. There are some versions of foobar2000, which are designed to be used in a car environment.
There is just one example.
https://www.youtube.com/watch?v=iodM_cT2uFM
As soon it is a Windows version (carPC) - you are able to use the APL VST plugin fot it.
Old 02-02-2018   #961
Rep Power: 55 Holmz will become famous soon enoughHolmz will become famous soon enoughHolmz will become famous soon enoughHolmz will become famous soon enoughHolmz will become famous soon enoughHolmz will become famous soon enoughHolmz will become famous soon enoughHolmz will become famous soon enough
Dreams come true
OK What does this mean... 12 FIR cores, and 10 channels?
Is the FIR based EQ done on the left and right independently, and then the remaining 5 channels per side are bandpass crossover outputs?
If the EQ is done on the input then what happens in the passband? It seems like ripples would be different on the low-side and high-side speakers, so the phase correction would need to be different on each speaker??
And it sort of seems like it is similar to a DDRC-88A, but with access to the FIR filters - or am I wrong?
Also, I could not exactly see this on the APL home page.
Holmz is online now   Reply With Quote Quick reply to this message
Old 02-02-2018   #962
Elgrosso's Avatar
Check here: https://www.facebook.com/aplaudio
Old 02-03-2018   #963
Raimonds's Avatar
chairman
Thank you for questions!
You should compare results of mentioned “similar” solution in fields of car audio competitions and pro audio. And how much they trust themselves in terms of investment to develop own hardware.
You should also check how far in “moon shining” they are from original work
https://www.google.com/patents/US8121302
published at May 18, 2005
Real competitor products are Dolby Lake and Fouraudio HD2
Thanks to Elgrosso for pointing to preliminary press release on APL’s facebook
FIR based EQ should be done in each of bands.
Then final FIR based EQ should be used on overall system (master EQ on input) to fine tune small residual crossover tuning errors and to use any targets.
10 channels means 10 analog output channels.
12 FIR cores means 12 independent FIR filters with 4096 taps each (in first release, later will be more, especially for 96 and 192kHz versions)
Any of FIRs can be any kind of filter and are not tighten to some bandpass or else.
As example, the unit can be configured as 12 channels EQ
The detailed correction of each speaker makes crossover “ideal” with complementary ripples, amplitude and phase responses. This actually is making all the value for use FIRs on each band.
Holmz (02-03-2018)
Old 02-03-2018   #964
Ok
1) What happens on Subwoofer channels?
I think that ideally one would filter-decimate the sample rate down... but I suspect that all the cores run at full sample rate.
So should I be concerned with filter resolution in the subwoofer band?
2) would I still need something else to do time alignment?
Or is time delay conceptually the same as rotating the taps to the right or left?
3) What is this unit called?
4) What is the Euro price?
5) is it available now? Or when it is to be released?
6) how does one start? As in what software tools should I get for use in OSX?
Or do I need to run windows in a VM?
Old 02-03-2018   #965
Elgrosso's Avatar
I’m seriously considering it!
Any plan to port your soft on mac?
Old 02-03-2018   #966
Raimonds's Avatar
chairman
Ok
You are on the button! I am considering that for 96/192 kHz.
The 4096 taps for 48kHz (85ms ir) is pretty much ok
C5 software is managing this in exactly mentioned way.
APL1012a
negotiated from deal to deal
Yes, please make your order!
1) You need Workshop or TDA EQ for basic measurement.
2) TDA - for crossover tuning, time alignment
3) C5 - for all the management.
You will need Windows on VM for Workshop to run on mac.
TDA series programs and C5 can be ported to mac with
pretty much not so big effort.
But it depends on your (customers) support to this project.
It was considered as some kind of "kikstarter" project at August last year.
Now, it is ready for orders without that.
But anyway, your early orders will help a lot.
Old 02-04-2018   #967
OK...
Q7) So would subwoofer management be a software implementation - with some filter-decimate brickwall convolution 'pre-stage' that can happen in the future?
Q8) Are the DSPs cores fixed point or floating point?
I have an analogue radio/CD that I was set on using... But then I got a new (used) unit that has a digital out?
The amps are old school jobs that are on RCAs, so I am thinking about whether I need to worry about low level signals and whether at quieter volumes I will be running out of bit depth... (The higher sample rates should help) The new radio/CD does 24bit CDs, but I have no idea what happens with the aux inputs from say an iPad, or an iPad into a GPS-aux input with a bluetooth phone, and then all the mess back into one of the radio's 2 aux inputs.
Old 02-04-2018   #968
Elgrosso's Avatar
Very interesting!
C5/TDA running on mac, that’s the trigger I needed.
Workshop I'm ok to play it on VM as it's not so often.
Ok then email now, thank you Raimonds.
Old 02-04-2018   #969
Raimonds's Avatar
chairman
OK...
Anyway, it must be hardware.
The good idea is to use as short FIRs as possible - to have as small "time smearing" as possible. 4096 taps can be sufficient for sub processing with that in mind.
They are no floating point as we know that from computer science.
They are floating point in terms that the point is floating to keep max accuracy for all computation - no quantization used till output.
Old 02-05-2018   #970
Ok ^that^ is pretty slick!
I saw on the C5 photo that the sample rate was selectable for each channel. If there was a ADC running at 4K, then one could probably do the subwoofer with 256 taps? Or do all the channels need to be the same sample rate? (I understand aliasing and Nyquist theorem.)
Ok - I did not do computer science at uni, however I seem to be doing it most of the time. I recall Estonia having the best internet in the world (a few years ago), so I assume Latvia is similarly advanced in technology? - based just on proximity alone.
Old 02-05-2018   #971
Hanatsu's Avatar
Rep Power: 326 Hanatsu has a reputation beyond reputeHanatsu has a reputation beyond reputeHanatsu has a reputation beyond reputeHanatsu has a reputation beyond reputeHanatsu has a reputation beyond reputeHanatsu has a reputation beyond reputeHanatsu has a reputation beyond reputeHanatsu has a reputation beyond reputeHanatsu has a reputation beyond reputeHanatsu has a reputation beyond reputeHanatsu has a reputation beyond repute
Default Comprehensive Review: " APL1 " - Advanced DSP / EQ / Phase Correction Unit
I don’t think the sampling frequency can be arbitrary set due to hardware but I could be wrong...
Old 03-18-2018   #972
Raimonds's Avatar
chairman
Hi,
Take a look on car version of APL1012!
The Following 2 Users Say Thank You to Raimonds For This Useful Post:
captainobvious (03-18-2018), claydo (03-18-2018)
Old 03-18-2018   #973
Rep Power: 44 Bnlcmbcar will become famous soon enoughBnlcmbcar will become famous soon enoughBnlcmbcar will become famous soon enoughBnlcmbcar will become famous soon enoughBnlcmbcar will become famous soon enoughBnlcmbcar will become famous soon enough
How soon can we expect the car version of the APL1012 to be available for purchase? Any pricing yet?
I’m going back and forth between going with APL-1S unit or the Dirac DDRC 22D or DDRC 88a. This car version APL1012 seems to be the most ideal!!
Bnlcmbcar is offline   Reply With Quote Quick reply to this message
Old 03-18-2018   #974
captainobvious's Avatar
Rep Power: 391 captainobvious has a reputation beyond reputecaptainobvious has a reputation beyond reputecaptainobvious has a reputation beyond reputecaptainobvious has a reputation beyond reputecaptainobvious has a reputation beyond reputecaptainobvious has a reputation beyond reputecaptainobvious has a reputation beyond reputecaptainobvious has a reputation beyond reputecaptainobvious has a reputation beyond reputecaptainobvious has a reputation beyond reputecaptainobvious has a reputation beyond repute
Nice Raimonds!
Is there a connection for the ribbon cable of the preset switch on the outside of the enclosure?
-Steve
2018 Iasca ProAm Champion
2018 Meca Extreme 2nd Place
2018 Mike Baylor Sportsmanship Award
Old 03-18-2018   #975
I also noticed that there is no optical input?
