Dayton Audio RS100-4, PS95-8 and HAT L3V2 - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 04-10-2015   #1
Rep Power: 116 edouble101 will become famous soon enoughedouble101 will become famous soon enoughedouble101 will become famous soon enoughedouble101 will become famous soon enoughedouble101 will become famous soon enoughedouble101 will become famous soon enoughedouble101 will become famous soon enough
Default Dayton Audio RS100-4, PS95-8 and HAT L3V2
This is more of a "Hey go check this speaker out!!" than a review.
I am testing about 15 pairs of 3" midrange drivers. I listened and measured just about all of them now and I want to bring to light a true outlier, the Dayton Audio PS95-8. The overall clarity and response is outstanding! For the minimal cost of these speakers anybody in the market for a 3" driver should pick these up. FYI I have not tested any other 3" driver that has better high frequency extension.
edouble101 is offline   Reply With Quote Quick reply to this message
Old 04-10-2015   #2
LaserSVT's Avatar
L&D Automotive
Rep Power: 150 LaserSVT will become famous soon enoughLaserSVT will become famous soon enoughLaserSVT will become famous soon enoughLaserSVT will become famous soon enoughLaserSVT will become famous soon enoughLaserSVT will become famous soon enoughLaserSVT will become famous soon enough
Default Re: Dayton Audio RS100-4, PS95-8 and HAT L3V2
Very nice. I may have to give those a try.
Denali:Alpine X009GM, SI TM65MKIII, SI M25, SI BM MKV, Helix G One & G Four amps.
Old 04-10-2015   #3
I'd definitely recommend them in the appropriate install.
Old 04-10-2015   #4
Rep Power: 139 lizardking will become famous soon enoughlizardking will become famous soon enoughlizardking will become famous soon enoughlizardking will become famous soon enoughlizardking will become famous soon enoughlizardking will become famous soon enough
Impressive considering they are 8ohm vs. the 4ohm drivers. The output is actually better down low and up high. Cool
lizardking is offline   Reply With Quote Quick reply to this message
Old 04-10-2015   #5
fredridge's Avatar
Rep Power: 175 fredridge will become famous soon enoughfredridge will become famous soon enoughfredridge will become famous soon enoughfredridge will become famous soon enoughfredridge will become famous soon enoughfredridge will become famous soon enough
I wonder how the PS95-8 would do in a column array - 6-8 in a row. I wonder how much air space they would need.
fredridge is offline   Reply With Quote Quick reply to this message
Old 04-10-2015   #6
All of the 8hm drivers I have have a higher sensitivy than the 4ohm drivers, which can be heard.
BTW they handled 80 wrms from my test amp in an open baffle no problem.
I don't think they were designed for an array but give it a try.
Old 04-10-2015   #7
1996blackmax's Avatar
Rep Power: 152 1996blackmax will become famous soon enough1996blackmax will become famous soon enough1996blackmax will become famous soon enough1996blackmax will become famous soon enough1996blackmax will become famous soon enough1996blackmax will become famous soon enough
It's nice to have another option in this size.
AudioControl: LC2i PPI: DEQ.8
Scan-Speak: Rev 18W, Discovery 10F, Illuminator R3004
Stereo Integrity: MAG V3 D2
Rockford Fosgate: Power T800-4ad, T400-4, T1000-1bdCP
1996blackmax is offline   Reply With Quote Quick reply to this message
Old 04-11-2015   #8
Rep Power: 122 Ray21 will become famous soon enoughRay21 will become famous soon enoughRay21 will become famous soon enoughRay21 will become famous soon enoughRay21 will become famous soon enoughRay21 will become famous soon enough
Nice, I've read good things about both the RS100 and the PS95 on other forums. I actually just used the RS100-8 recently in a home audio setup with great results.
What were they mounted on/in and are these on-axis measurements?
Ray21 is offline   Reply With Quote Quick reply to this message
Old 04-11-2015   #9
They were mounted on an open baffle. The measurements were taken 3" from the cone. I did not calibrate my mic for SPL. Soundcard is calibrated though.
Pic of baffles :
If anybody sees fault in my measurements let me know. I certainly do not know it all when it comes to taking RTA measurements and I will gladly taek advice.
RTA setup - Dayton EMM-6 mic, Tascam US-122 MKII, laptop.
Old 04-11-2015   #10
Rep Power: 0 Orion525iT has a spectacular aura aboutOrion525iT has a spectacular aura aboutOrion525iT has a spectacular aura aboutOrion525iT has a spectacular aura aboutOrion525iT has a spectacular aura aboutOrion525iT has a spectacular aura aboutOrion525iT has a spectacular aura aboutOrion525iT has a spectacular aura about
Any distortion plots? Spl is one thing, but if that Spl comes from higher distortion levels, then that is part of the equation. Polars would be nice too.
Thanks for the measurements. It takes effort to do this kind of stuff and it is always welcomed by me.
Orion525iT is offline   Reply With Quote Quick reply to this message
Old 04-11-2015   #11
I've ever done either of those tests. Give me a while to research it and I'll post them.
Old 04-12-2015   #12
beerdrnkr's Avatar
Rep Power: 160 beerdrnkr will become famous soon enoughbeerdrnkr will become famous soon enoughbeerdrnkr will become famous soon enoughbeerdrnkr will become famous soon enoughbeerdrnkr will become famous soon enoughbeerdrnkr will become famous soon enough
Good to hear since i just ordered a pair yesterday. Ill be running a pair in stock locations in the dash.
beerdrnkr is offline   Reply With Quote Quick reply to this message
Old 04-12-2015   #13
Please comment in this thread once you have them installed and demoed them!
They are fairly heavy for their size. The motor structure is almost the same size as the RS100-4. Mounting flange is a tad smaller than the RS100-4. Leaps and bounds above the RS100-4 in overall music clarity.
Old 04-13-2015   #14
beerdrnkr's Avatar
I definitely will. I currently have the rs-180 7s (paper) in the doors and the dayton rs28s tweets in the dash.
I also have a set of the dayton reference 4s (paper) and a pair of the dayton amt mini tweets that I have to play with. Processing power is holding me back on trying those other speakers out. I'm hoping this full range driver will work well for the time being.
Old 04-13-2015   #15
brett's Avatar
Rep Power: 183 brett will become famous soon enoughbrett will become famous soon enoughbrett will become famous soon enoughbrett will become famous soon enoughbrett will become famous soon enoughbrett will become famous soon enough
Send a message via AIM to brett
just bought the rs125-p and was playing around with it, but definitely interested in a further review of the ps95-8 as i almost snagged it as well.
changes coming....
brett is offline   Reply With Quote Quick reply to this message
Old 04-19-2015   #16
beerdrnkr's Avatar
Soon!
Old 04-20-2015   #17
Rep Power: 191 Mless5 will become famous soon enoughMless5 will become famous soon enoughMless5 will become famous soon enoughMless5 will become famous soon enoughMless5 will become famous soon enoughMless5 will become famous soon enough
I have those PS95s and I wonder how would paper RS100 would stack up against it or RS75 for that matter. Looking for a tad more detailed sound I guess.
Old 04-21-2015   #18
beerdrnkr's Avatar
I'll be installing mine today after work. Currently have the RS100-4p installed in the dash.
Mless, where are your mids installed?
Old 04-21-2015   #19
In the kicks pointing to the back of the radio.
Old 04-21-2015   #20
You are looking for a more detailed sound than the PS95? I find it hard to achieve any more detail ( referring to FR) from a single speaker.
Old 04-23-2015   #21
beerdrnkr's Avatar
So after a little experimenting with the Dayton full range 3 1/2s , i decided to go back to the dayton rs100s.
In my application with the mids in the dash firing towards the windshield, the rs100s just sound much better and they're much easier to tame. With my limited dsp, i just couldn't get the fullrange daytons to sound good. They have plenty of detail but I just couldn't eq them in the high midrange (between 1kh-8khz) enough to tame them down a bit.
The rs100Ps are great and although they can't extend as high as the fullrangers they still sound great and give plenty of detail, while also playing lower. I plan on getting a processor and mounting some tweeters in the a-pillars sometime soon to help out the RS100p that last bit in the 10khz-20khz range.
Old 05-05-2015   #22
Rep Power: 58 Kazuhiro will become famous soon enoughKazuhiro will become famous soon enoughKazuhiro will become famous soon enoughKazuhiro will become famous soon enoughKazuhiro will become famous soon enoughKazuhiro will become famous soon enough
You may have sold me on the Dayton Audio PS95-8
How would it compare to the aluminum cone RS100? Does it come in 4ohm also?
edit; Also looks like the PS95 is outta stock all about?
Kazuhiro is offline   Reply With Quote Quick reply to this message
Old 05-21-2015   #23
Rep Power: 0 satx60 will become famous soon enoughsatx60 will become famous soon enoughsatx60 will become famous soon enoughsatx60 will become famous soon enoughsatx60 will become famous soon enoughsatx60 will become famous soon enough
Thanks for the info on that little driver! Here's some tips to help you get more accurate measurements.
You need to measure far field to see accurate high frequency content. At 3" from the cone, your data is only accurate up to about 1k. That's probably why the responses slope down so much. I'd try around 20". I believe the rule is 5 times cone diameter.
You'll likely want to gate out room reflections when taking farfield measurements. Look at the impulse response to see the first room refection and create a window below that. usually around 3.5ms indoors.
Set smoothing at 1/12 or 1/24. That should give good resolution.
Make graphs 5db scale.
Your measurement baffle should be smooth, so no stepped ring around the driver. I don't know if this will have any real effect on a mid, but with tweeters you'd see edge diffraction in the response. Also, your baffle looks fairly wide, but remember that you'll get baffle step in your response where it looks like the drivers aren't very strong down low depending on the width. If this is say 10" wide the response will be 3db down at around 450Hz and continue down from there.
satx60 is offline   Reply With Quote Quick reply to this message
Old 07-19-2015   #24
Rep Power: 0 kandroid will become famous soon enoughkandroid will become famous soon enoughkandroid will become famous soon enoughkandroid will become famous soon enoughkandroid will become famous soon enoughkandroid will become famous soon enough
I use the Dayton RS100-4 in the dash in custom fiberglass enclosure in a active setup. it easily hits 300 hz without a whimper.
kandroid is offline   Reply With Quote Quick reply to this message
Old 07-20-2015   #25
I'm pretty sure the rs100 will do 300hz fine in a small pillar.
Nice pods but dont they intrude your view a little bit? Either way, drive safe.
85' JDM Prelude Si
Pioneer|Soundstream|Audible Physics
