2000 Pontiac Grand Prix: PK3 module wiring for Viper remote start - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 11-12-2018   #1
Rep Power: 85 syc0path will become famous soon enoughsyc0path will become famous soon enoughsyc0path will become famous soon enoughsyc0path will become famous soon enoughsyc0path will become famous soon enoughsyc0path will become famous soon enough
Default 2000 Pontiac Grand Prix: PK3 module wiring for Viper remote start
I'm installing a Viper 150 ESP. I'm trying to figure out the PK3 module wiring to bypass the factory Passkey security system. Below is the wiring list on the back of the module, and I'm using the Grand Prix wiring site to try to figure out what to hook up to:
Red -- 12V+
Black -- Ground
Blue -- (-) Remote start
Green -- Key Sense
Purple -- Data (I/O)
Pink -- IGN (ECM side)
Pink/Black -- IGN (Key side)
Blue/White -- Fuel Enable
Red and Black are obvious, and Blue connects to the remote start unit.
I think Green should connect to BCM Connector 2, D2, Light Green, Key In Ignition Input (-).
I have no idea what Purple should connect to.
I think Pink should connect to BCM Connector 2, C13, Pink, Ignition Feed.
I don't know what Pink/Black should connect to.
I don't know what Blue/White should connect to.
Can any1 help me out?
Old 11-14-2018   #2
Rep Power: 64 audiokid1 will become famous soon enoughaudiokid1 will become famous soon enoughaudiokid1 will become famous soon enoughaudiokid1 will become famous soon enoughaudiokid1 will become famous soon enoughaudiokid1 will become famous soon enough
Default Re: 2000 Pontiac Grand Prix: PK3 module wiring for Viper remote start
All wiring is usually/should be done at the Passkey module at the ignition switch.
Almost... all of the wire colors on your PK3 module will match the wire colors on the vehicle.
Wire up the Red, Black, and Blue wires of the PK3 module as you have already described
Key Sense is Lt Green in the vehicles Ignition Harness
Check for the following wires at the PK module on the vehicle
Pink - Ignition (Wire gets cut in half and ends go to Pink and Pink/Black of your PK3 bypass module)
Purple - Data
Dark Blue - Fuel Enable
Other documents that may be helpful (I can't recall if 2004 still had same wiring as the 2000 model)
97 & Up Grand Prix.pdf
Grand Prix.pdf
audiokid1 is offline   Reply With Quote Quick reply to this message
Old 04-09-2019   #3
Now that the weather is warming up, I'm getting back to this job. Unfortunately, I can't find the Purple or Dark Blue wires in the factory wiring diagrams from the website I listed above. What I really need is the installation manual from the DEI website, but I don't have a dealer login
https://www.directechs.com/vehicleco...&countryID=223
