2012 Toyota highlander system design - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 10-25-2011   #1
Rep Power: 0 Bublik2002 will become famous soon enoughBublik2002 will become famous soon enoughBublik2002 will become famous soon enoughBublik2002 will become famous soon enoughBublik2002 will become famous soon enoughBublik2002 will become famous soon enough
Default 2012 Toyota highlander system design
I want to do a very clean install in my new car. So far I have settled on the following:
Pioneer x930bt
Jl 12w6v2 sealed
Jl 500/1
Jl 300/4
Now I need to figure it what 6.5 comps to do up front and what 6.5 speakers to do in the rear doors.
Bublik2002 is offline   Reply With Quote Quick reply to this message
Old 10-27-2011   #2
This place
Rep Power: 40147 schmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond reputeschmiddr2 has a reputation beyond repute
Default Re: 2012 Toyota highlander system design
If you don't often have rear passengers just omit the rear speakers. If you do then spend waaay less on them compared to the front speakers.
What is the budget?
Also, if you aren't too worried about sub output but want a great sub then the Dayton HO 12" would save you money and works in a tiny enclosure.
schmiddr2 is offline   Reply With Quote Quick reply to this message
Old 10-28-2011   #3
I made a decision to go with dls up6i for fronts and dls rs6n for rears... Sound good?
Old 10-28-2011   #4
This place
Never heard any DLS, but I'm sure there are reviews on here. Regardless of the quality you can maximize the performance of the speaker(s) by sealing the doors properly and building a good baffle. If you are not using processing, then keep each front tweet the same distance to your ear as the woofer if you can (that doesn't mean it has to be next to it).
Old 10-28-2011   #5
Would adding a jbl ms8 make a big difference?
Old 10-28-2011   #6
This place
Yes, but it would require an amp channel for each speaker to take full advantage of it's ability.
Old 10-28-2011   #7
Is that what is meant by going active? Having a channel per mid and tweeter?
Old 10-28-2011   #8
This place
Going active can mean using digital processing of the crossover points and slope or can mean that plus EQ, TA.
To use active crossovers you will need separate amp channel for each speaker. For the other 2 processing features you can use TA with quasi-active setups and EQ with any setup (although still more effective with separate channels).
