1966 Ford Truck Restoration - Page 2 - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 07-09-2019   #26
rton20s's Avatar
Rep Power: 358 rton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond reputerton20s has a reputation beyond repute
Default Re: 1966 Ford Truck Restoration
I was going to have a big drawn out post, but I will leave it at this...
Skip the 3 channel amp, especially at a higher cost.
Skip the DAC until after you have evaluated the installed system without one.
Skip the more expensive DSP unless you really have the budget for it.
Pioneer DEH-80PRS | Helix DSP.2 | Zapco Z-150.6 AP + Z-400.2 AP (x2) | Illusion TL 25 BN | Illusion C5 | Raven 10XL (x2)
2015 MECA SQL Street | 2017 & 2018 MECA Modex California State Champion
Old 07-09-2019   #27
Rep Power: 8 ajt976 will become famous soon enoughajt976 will become famous soon enoughajt976 will become famous soon enoughajt976 will become famous soon enoughajt976 will become famous soon enoughajt976 will become famous soon enough
Originally Posted by spuds View Post
Thanks for the input...how about the ancillary items? Do I have everything they'll need for the installation? Thanks
I got that Knu amp kit as well and it has quite a bit of install materials in it.
Any plans for sound treatment? Do you need speaker adapters/baffles? That's the only other things I ended up getting outside of what you have already listed.
ajt976 is offline   Reply With Quote Quick reply to this message
Old 07-09-2019   #28
Rep Power: 0 spuds will become famous soon enoughspuds will become famous soon enoughspuds will become famous soon enoughspuds will become famous soon enoughspuds will become famous soon enoughspuds will become famous soon enough
The sound deadening and baffles are taken care of. I "think" I'm ready to pull the trigger. I'll try to show photos of the final build...it's really turned out to be a special build.
spuds is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to spuds For This Useful Post:
rton20s (07-09-2019)
Old 07-12-2019   #29
Rep Power: 93 CarGuru will become famous soon enoughCarGuru will become famous soon enoughCarGuru will become famous soon enoughCarGuru will become famous soon enoughCarGuru will become famous soon enoughCarGuru will become famous soon enough
Since your budget is so tight skip the retro headunit for now, buy a $25 Bluetooth receiver and most of the current iPods can send FM radio over Bluetooth.
Forget the Dayton DSP. It has bad reviews.
Get the MiniDSP 6x8 instead for $275. It has free tuning software that works with the optional rta mic. Great company, people on here use them. The 6x8 model is basically the same specs and features at the JL TWK88. Connect your Bluetooth receiver to the DSP with a digital optical cable.
Your DSP will have a built in DAC you don’t buy a separate one you buy a better DSP instead.
Coaxials will be less to install but in a classic car you will almost certainly have to put them low in the kicks. By going with components you’ll greatly increase you imaging because you’ll be able to aim the tweeters at your ears where the sound goes in...duh
As for the amp wiring you’ll have a processor and 4 channels for the front so you should be running active, no bridging. The 3ch amp would be better if you're dead set on the coaxials and retro head unit, but in this scenario you really don't have a substantial requirement for the processor at all. With the 4ch in this scenario, I think of bridging as a useful option when necessary but never ideal. Pushing all 4 channels of an inexpensive amp at the lowest impedance (2ohms) will almost certainly shorten its life.
Again, the 4ch amp and the processor is the ideal solution because you can use each channel for each of the 4 front drivers.
You’re also leaving out some important and costly items from your budget. Speaker wire, sound deadener, fused power for the DSP, ring terminals, heat shrink, unique speciality tools...there’s a lot of residual things that add up fast.
CarGuru is offline   Reply With Quote Quick reply to this message
