DSP’s Helix DSP mini vs DSP-408 - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 04-08-2019   #1
Rep Power: 0 Newbricha will become famous soon enoughNewbricha will become famous soon enoughNewbricha will become famous soon enoughNewbricha will become famous soon enoughNewbricha will become famous soon enoughNewbricha will become famous soon enough
Default DSP’s Helix DSP mini vs DSP-408
Hi all,
In the process of changing over from a rainbow audio passive two way system to an Ausion Vove 3 way active system. Im currently looking for a DSP and am stuck between two of the cheaper options. I can get a DSP-408 for around £170, but i can also pick up a second hand Helix DSP mini for £200. However because im going 3 way active plus a sub, i will need 7 channels, which is beyond the scope of the helix. However im wondering if i would be better off with thw helix running the front 3 ways and just keep the sub individually controlled from my Pioneer SPH-DA120 head unit? Is there much advantage of the sub going through the DSP?
Thanks for the help
Rich
Newbricha is offline   Reply With Quote Quick reply to this message
Old 04-08-2019   #2
mattkim1337's Avatar
Car Toys
MECP Advanced Certified Noob
Rep Power: 25 mattkim1337 will become famous soon enoughmattkim1337 will become famous soon enoughmattkim1337 will become famous soon enoughmattkim1337 will become famous soon enoughmattkim1337 will become famous soon enoughmattkim1337 will become famous soon enough
Default Re: DSP’s Helix DSP mini vs DSP-408
Your car has its own transfer function, which can alter the frequency response of your subs quite drastically. Parametric EQ can mitigate many problems that the environment causes (reflections, loading, cancellations, peaks). DSP control will give you the tools for integrating with your midbass drivers to create the illusion of up front bass. It's something that I would always include in my system.
You should either go with the DSP 408 for this extra control or try to get your hands on a Helix DSP.2 (8 channel), even though you may need to pay a bit extra. It will be well worth it.
iPad Pro dash integration and 7.1 Surround Audiofrog system with fully custom installation and fabrication. CLICK HERE to see the complete build log with pics
mattkim1337 is offline   Reply With Quote Quick reply to this message
Old 04-08-2019   #3
Thanks for the reply. The DSP.2 would be my ideal but i would have to go new at £430. Would you say the Helix DSP.2 is worth 3x more than the DSP-408? The main thing drawing to to the Helix is the inbuilt RTA functionality to aid a relative novice with setup.
Thanks
Rich
Old 04-11-2019   #4
Rep Power: 16 Fish-N-Chips will become famous soon enoughFish-N-Chips will become famous soon enoughFish-N-Chips will become famous soon enoughFish-N-Chips will become famous soon enoughFish-N-Chips will become famous soon enoughFish-N-Chips will become famous soon enough
I have the DSP 408 and, although it is my first dsp, it had been awesome. Not sure what level of tuning your going to, but there are only a few advanced features it doesn't have. And it's cheap...
Fish-N-Chips is offline   Reply With Quote Quick reply to this message
Old 04-15-2019   #5
Rep Power: 0 tacofox will become famous soon enoughtacofox will become famous soon enoughtacofox will become famous soon enoughtacofox will become famous soon enoughtacofox will become famous soon enoughtacofox will become famous soon enough
I just bought the DSP 408 over my second choice of the c-dsp 6x8. It will be getting here later this week so here's hoping it works well! I will report back with my findings
tacofox is offline   Reply With Quote Quick reply to this message
Old 04-15-2019   #6
Rep Power: 93 Jscoyne2 has a spectacular aura aboutJscoyne2 has a spectacular aura aboutJscoyne2 has a spectacular aura aboutJscoyne2 has a spectacular aura aboutJscoyne2 has a spectacular aura aboutJscoyne2 has a spectacular aura aboutJscoyne2 has a spectacular aura aboutJscoyne2 has a spectacular aura about
Thanks
Rich
Absolutely. In every way
Old 04-15-2019   #7
Rep Power: 130 Sine Swept will become famous soon enoughSine Swept will become famous soon enoughSine Swept will become famous soon enoughSine Swept will become famous soon enoughSine Swept will become famous soon enoughSine Swept will become famous soon enoughSine Swept will become famous soon enough
At the same token, I would say the 408 is 3 x better than nothing!
DNX 5120, MS-8, Scanspeak Illuminator R3004/6020, Focal 5w2, Morel CAW938, IDMAX12 V3, PPI Ax400's + JBL 1201.1 II
Old 04-15-2019   #8
Rep Power: 8 SiW80 will become famous soon enoughSiW80 will become famous soon enoughSiW80 will become famous soon enoughSiW80 will become famous soon enoughSiW80 will become famous soon enoughSiW80 will become famous soon enough
Default DSPís Helix DSP mini vs DSP-408
Depends how you will connect to the DSP - analogue, digital or Bluetooth.
If digital then Helix for sure, but if Bluetooth the the Dayton is hard to beat with the app
Rich - if your in the UK there is a Dayton on eBay from a UK seller for £150 and youíll only need the Bluetooth module
Also, get on Talkaudio
Simon
SiW80 is offline   Reply With Quote Quick reply to this message
Old 04-15-2019   #9
ryanr7386's Avatar
Rep Power: 115 ryanr7386 will become famous soon enoughryanr7386 will become famous soon enoughryanr7386 will become famous soon enoughryanr7386 will become famous soon enoughryanr7386 will become famous soon enoughryanr7386 will become famous soon enoughryanr7386 will become famous soon enough
OP, Pardon the HiJack of your thread but if your interested, I have Two of the DSP-408's i'm going to be letting go of. One slightly used, one New. Hit me up.
1994 Ford Thunderbird SC System - Alpine 7909, Helix DSP Pro, ADS MX Amps & ADS Speakers. On Going Build
ryanr7386 is offline   Reply With Quote Quick reply to this message
Old 04-15-2019   #10
Rep Power: 190 miniSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the rough
Default Re: DSPís Helix DSP mini vs DSP-408
Can you find a used HelixDSP? The original one would be on my list.
2018 Crosstrek
P SIX DSP MK2 GB10 GB25 Gs690 RM12 Z-2KD II
Dayton Audio DSP-408 or MiniDSP C-DSP 6x8? SiW80 Technical & Advanced Car Audio Discussion 12 04-24-2019 06:34 AM
MiniDSP C-DSP 8x12 dBFs level meter - what’s it referencing? Chris12 General Car Audio Discussion 5 01-19-2019 04:28 PM
80prs VS cheaper HU + DSP-408 ParDeus General Car Audio Discussion 25 11-15-2018 03:09 PM
Stinger 9000 17’ RCA’s 2pr BNIB Larry Chijner Car Audio Classifieds 3 05-27-2018 06:36 PM
Dayton DSP-408 vs MiniDSP c-dsp 6x8. 89grand Technical & Advanced Car Audio Discussion 12 05-07-2018 12:49 PM
