2016 VW Jetta Budget Build - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 3 Days Ago   #1
Rep Power: 0 jbird61801 will become famous soon enoughjbird61801 will become famous soon enoughjbird61801 will become famous soon enoughjbird61801 will become famous soon enoughjbird61801 will become famous soon enoughjbird61801 will become famous soon enough
Default 2016 VW Jetta Budget Build
I am starting from a stock stereo system which is terrible at best. I plan to keep the factory head unit because of some decent features like bluetooth, touchscreen, and backup camera. As well as trying to stay budget minded and keeping the factory look.
Component parts list that isn't set in stone:
Audiocontrol LC7i
Pioneer GM-D9705 5 channel amp
Alpine R-S65C 6.5" components(2 sets)
1 Rockford Fosgate P3D4 12" in a ported enclosure
Since I am getting my signal from a stock head unit, then getting mixed, summoned, accubased, and sprinkled with fairy dust, does it make sense to go with the high res versions of the Alpines(R-S65C.2) and the Pioneer(GM-DX975)? About a $300 jump in budget. Or would I just be polishing a turd?
Also, if anyone has alternative components in the same price range they would suggest, let me know.
Sent from my SM-G950U using Tapatalk
jbird61801 is offline   Reply With Quote Quick reply to this message
Old 3 Days Ago   #2
MrGreen83's Avatar
Rep Power: 58 MrGreen83 will become famous soon enoughMrGreen83 will become famous soon enoughMrGreen83 will become famous soon enoughMrGreen83 will become famous soon enoughMrGreen83 will become famous soon enoughMrGreen83 will become famous soon enough
Default Re: 2016 VW Jetta Budget Build
Get a cheap DSP instead of the line converter
MrGreen83 is offline   Reply With Quote Quick reply to this message
Old 3 Days Ago   #3
UNFORGIVEN's Avatar
Rep Power: 113 UNFORGIVEN has a spectacular aura aboutUNFORGIVEN has a spectacular aura aboutUNFORGIVEN has a spectacular aura aboutUNFORGIVEN has a spectacular aura aboutUNFORGIVEN has a spectacular aura aboutUNFORGIVEN has a spectacular aura aboutUNFORGIVEN has a spectacular aura aboutUNFORGIVEN has a spectacular aura aboutUNFORGIVEN has a spectacular aura aboutUNFORGIVEN has a spectacular aura about
I second that. A DSP would be the best move to make your setup dialed in to your liking.
Currently: *Hybrid Audio Legathia 3-Way Active Front Stage * (2) Morel Ultimo 12's * (2) Arc Audio 1100.1 XDi v2 (Strapped @1ohm) * (1) Arc Audio 1200.6 * RF 360.3 DSP*
UNFORGIVEN is offline   Reply With Quote Quick reply to this message
Old 3 Days Ago   #4
Rep Power: 365 bbfoto has a reputation beyond reputebbfoto has a reputation beyond reputebbfoto has a reputation beyond reputebbfoto has a reputation beyond reputebbfoto has a reputation beyond reputebbfoto has a reputation beyond reputebbfoto has a reputation beyond reputebbfoto has a reputation beyond reputebbfoto has a reputation beyond reputebbfoto has a reputation beyond reputebbfoto has a reputation beyond repute
If you need summing to get a full-range signal from your OEM head unit, you might need the AC LC7i, or a JL Audio FiX 82. If not, then as others suggested, I would get a DSP, which will be the single largest factor in obtaining good SQ after your front component choice.
And if the second set of components is for the rear, I would skip those and just use the stock rear speakers. Put the money saved into better front components and sound deadening, and/or a DSP.
DIYMA member "SkizeR" has a Preorder Discount going on right now for his ResoNix sound deadening products.
https://www.diymobileaudio.com/forum...-now-open.html
bbfoto is online now   Reply With Quote Quick reply to this message
Help with SQL build in 2014 VW Jetta w/ Fender Audio Lyons238 Technical & Advanced Car Audio Discussion 5 10-25-2018 12:21 PM
2016 VW Jetta, need some speaker/amp input Guitarmageddon System Design - Help Me Choose Equipment For My Car 8 12-28-2015 02:41 PM
2013 VW Jetta Sportwagen TDI Audison build TheDavel Build Logs & Project Install Gallery 112 10-02-2015 03:28 PM
2013 VW Jetta Sportwagen SQ Build Log fahrfrompuken Build Logs & Project Install Gallery 158 08-29-2014 05:57 PM
'01 VW Jetta 1.8T Carputer build log jacampb2 Build Logs & Project Install Gallery 45 04-16-2013 01:48 PM
