Basic setup questions - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 06-18-2019   #1
Rep Power: 0 milhouse82 will become famous soon enoughmilhouse82 will become famous soon enoughmilhouse82 will become famous soon enoughmilhouse82 will become famous soon enoughmilhouse82 will become famous soon enoughmilhouse82 will become famous soon enough
Default Basic setup questions
Hi everyone, I'm looking to upgrade my setup for the first time and have some questions.
I'm not an audiophile (maybe yet, haha) but I do love music and want it to sound reasonably good, considering price. But I wanna start with something basic and go from there. My plan is to buy the parts and get a local shop to install everything. Hoping to keep it around $500 all in if possible.
I have a 1997 Honda Civic CX. There's an aftermarket Kenwood deck in it but its old and I'll be replacing it. Beyond that there's 2 stock speakers in the back, and none in the front, just the plastic things that look like speakers, which I found kinda odd.
So onto the questions. How many speakers do I actually need? Can I just get a new deck, 2 speakers, and a powered sub and call it a day? Or do I need 4 speakers? The first scenario seems more convenient, because if I understand correctly (correct me if not), I can only plug in 4 things to the average lower-end deck. 4 speakers plus a sub would require me to get an amp, yes? Prefer to not go down that road if possible for budget reasons. Can I get 2 new speakers and keep the existing rear ones? Would that sound bad? I don't need crazy bass or crazy high volume.
Examples of components I'm looking at:
Heads:
JVC-KD-X360BTS
Pioneer-DEH-S5120BT
Speakers:
Pioneer-TS-F1634R-200W-2-Way-Speakers
Kicker-43DSC6504-Coaxial-Speakers
Rockford-Fosgate-R165X3-6-5-Inch-Full-Range
Subwoofer:
Rockville-RW10CA-Profile-Powered-Subwoofer
Sound Ordnance B-8P
Will appreciate any help. Thanks!
milhouse82 is offline   Reply With Quote Quick reply to this message
Old 06-19-2019   #2
Rep Power: 8 Furyan will become famous soon enoughFuryan will become famous soon enoughFuryan will become famous soon enoughFuryan will become famous soon enoughFuryan will become famous soon enoughFuryan will become famous soon enough
Default Re: Basic setup questions
I have been on these forums for a short amount of time compared to most but I think the general response to your question will be to
1. Get two nice speakers upfront,most you can spend on them within budget
2. Add an 2 channel amp to power them
3. Skip replacing the rear speakers
4. Add a sub in back,powered or otherwise.
5. Save up a little bit more $$$ if you can swing it and get the best quality you can afford.
Adding an amp to a great pair of speakers will boost your sound quality over just running off of the factory head unit power. Worthwhile in the long run. Amps are super affordable nowadays too. Find a cheap 2 channel amp to run the front speakers,most will say just disconnect the rears as with some good front speakers you wont miss them. So you could go
2 channel amp powering front speakers plus a powered sub
or
4 channel amp (2 channels) powering front speakers and (2 channels bridged) powering a non powered sub.
If I were in your shoes
Id go with the Pioneer headunit over the JVC
Id get this powered sub over the two you provided,for $20 more you'll get better bass https://www.amazon.com/Pioneer-TS-WX...4119&s=gateway
And Id save up a bit more and get these speakers https://www.crutchfield.com/p_108R65...EF-6532ex.html
And lastly a 2channel amp to power the Infinities,something like this https://www.crutchfield.com/p_108P60...nnel+amp&avf=N or this https://www.crutchfield.com/p_130GMA...nnel+amp&avf=N would be enough.
That would put you at $400 plus whatever shipping costs.
Furyan is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to Furyan For This Useful Post:
milhouse82 (06-19-2019)
Old 06-19-2019   #3
Thanks for the reply. I was actually looking at those Infinity speakers, they look pretty good.
You think I need an amp for the speakers even if I'm getting a powered sub?
What about wiring kits? When are those necessary? Just for a sub or?
Old 06-19-2019   #4
You dont need it per say. You could always add one later down the road if you wanted. Ive heard they (infinity)run well off of just deck power. Yes you will need an amp kit for your sub. If adding an amp you would need one as well. Check out Kno knoise website. Also you may need speaker adapter wiring for hooking up the new speakers to your factory speaker locations,but it may just be plug n play as well.
Edit This amp kit would work for your powered sub KCA Complete 8 Gauge Amplifier Installation Kit - Merchandise
Old 06-20-2019   #5
Ok, thanks.
The shop I'm talking to quoted me $72.50 for their wiring kit which seemed steep, though I see lots of the ones on Crutchfield are in that range.
Also, how do I know which gauge is appropriate?
Old 06-20-2019   #6
The one I linked above is what you'll need. 8 gauge is plenty for what you're gonna run.
Old 06-25-2019   #7
Alright, getting close to pulling the trigger here. Looking at this setup:
Infinity Reference REF-6532ex speakers
Sound Ordnance B-8P sub
Pioneer DEH-S5120BT deck
and mayybe
Pioneer GM-A3702 2-Channel Bridgeable Amplifier
Toying with the idea of installing everything myself. I have the free time and I'd prefer to save the ~$300 for the shop labor if possible. If I went this route, what else would I need in terms of accessories/tools to complete the installation? Obviously the amp wiring kit for the sub, and a second one if I get the amp, yes? What else? Crutchfield includes a free receiver wiring harness and a dash kit with the deck, and speaker wiring harnesses with the speakers. Is there anything else? I'd prefer to know in advance so I can order everything at once if possible. Thanks in advance for any replies.
Old 06-25-2019   #8
I believe that's everything you need,someone please correct me if I'm wrong. For tools crutchfield has pry tools on the cheap,doors may have torx or regular screws or both,plus bolts of some size. Check online to see. Crutchfield may also send u a free instruction guide specifically for your car via email. It should tell u the tools you'll need and can be had at most auto parts stores.
Old 06-25-2019   #9
Nottinghamshire Police
Auto electrician/Fabricator
Rep Power: 160 dumdum will become famous soon enoughdumdum will become famous soon enoughdumdum will become famous soon enoughdumdum will become famous soon enoughdumdum will become famous soon enoughdumdum will become famous soon enough
I’d aim for 100 dollars on a headunit, base level pioneers are good in my experience
100 dollars on components, sub and then use 150 dollars on a 4 channel amp, then 50 dollars on sound deadening for the front doors as putting speakers in a stock door will sound poor, not a lot of midbass, rattles galore... whereas even a stock system can be made reasonable with addition of deadener from experience as manufacturers don’t seal doors up very well at times... vag group cars are probably some of the better vehicles for having sealed up doors...
dumdum is offline   Reply With Quote Quick reply to this message
Old 06-26-2019   #10
What is required for deadening? Any recommendations?
I don't have the original keys to remove the current deck so I guess I'm gonna try using some butter knives or something.
As for pry tools, would I need those for anything considering it's an aftermarket deck in there already?
Old 06-26-2019   #11
Knoknoise deadener and fast rings is what I used. Pry tools for the door panels or panels in general,or you could whatever you want to pry em off. Pry tools made it easier for me and I didnt have to worry about damaging anything. Worth the $12 imo.
Old 06-27-2019   #12
Thanks, appreciate all the replies so far.
Next question. I looked at like 10 youtube videos for installing speakers into a Civic like mine, but in all of them they're replacing existing speakers so they can easily attach the new ones to the existing wires. My car has no speakers in the doors, just plastic covers on top, and no wires inside that I can see.
So the question is, how do I get the wires into the speaker hole? Do they come down that metal shaft in the first pic? Do I need to buy speaker wire? How do I do this?
(Sorry for the sideways pics, my phone does that for some reason)
Old 06-27-2019   #13
Rep Power: 34 SlvrDragon50 will become famous soon enoughSlvrDragon50 will become famous soon enoughSlvrDragon50 will become famous soon enoughSlvrDragon50 will become famous soon enoughSlvrDragon50 will become famous soon enoughSlvrDragon50 will become famous soon enough
Wow, no stock speakers in the doors? That's crazy!
You'll have to run wires through the door jamb. Then you can hook up the speakers. Not too hard, just annoying.
2014 Honda Accord LX - JL Audio C2-650, Kicker CSC674, Helix DSP Pro MK1, Pioneer GM-D8604, Rockford Fosgate R500X1D
SlvrDragon50 is offline   Reply With Quote Quick reply to this message
Old 06-28-2019   #14
Okay, so I assume that means taking some dash panels out? Was hoping to avoid doing that for my first install but if I have to
Do I need to buy additional wiring to connect them? I assume that doesn't come with the speakers?
Old 06-28-2019   #15
It may or may not require speaker wire. Depends on what kits you buy.
You probably don't need to take dash panels out, but I don't know that car.
Old 06-28-2019   #16
I’d be taking the door cards off and the weather sealing, the factory speaker cables are probably taped up inside the door somewhere 👍🏼
Old 07-01-2019   #17
Hmm, okay, why would they be in there? You mean they came like that from the factory or a previous owner did it? Keep in mind there's an aftermarket deck in there already.
Let's assume there's no wires. What else do I need to buy? I'm just gonna start with these 3 items:
Pioneer DEH-S5120BT
Dynamat 10415 Xtreme Speaker Kit
Old 07-01-2019   #18
You will need speaker wire to run to the factory harness I believe.
Old 07-02-2019   #19
Thanks, I actually ended up talking to a Crutchfield rep who said the same thing. Placed the order, just waiting for the dash kit and wiring harness to get back in stock.
Old 07-17-2019   #20
Alright so after digging around inside the door I did find the wires and harnesses. Got the deck installed and wired up, but I'm only getting sound out of the passenger side. It's not a speaker issue, I swapped them and they both work. I double checked the wiring and it's correct as far as I can see. So why isn't the driver's side working?
Old 07-19-2019   #21
After talking to a Crutchfield rep it looks like I'm just gonna try running new wire through.
Also the speakers don't fit in my doors, even with the supplied adapter, despite the fact that their site said they would. Guess I'll be drilling some holes.
