Powering mini dsp - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 10-16-2012   #1
bigfastmike's Avatar
Rep Power: 96 bigfastmike is on a distinguished roadbigfastmike is on a distinguished roadbigfastmike is on a distinguished roadbigfastmike is on a distinguished roadbigfastmike is on a distinguished road
Default Powering mini dsp
I just got my mini dsp. It has power and ground inputs. I can only assume it may only turn on if senses signal. Not sure. I have a decontrol battery I was going to hook power to but I was wondering if I could just power it from my remote turn on relay. And thoughts?
2012 toyota 4runner- 2013 USACI mod SQ+ 2nd place and spl world record. 2003 Lexus sc- 2014 USACI National Points leader, MECA state point leader, Am1SQ+ 3rd palce and spl world record.
bigfastmike is offline   Reply With Quote Quick reply to this message
Old 10-16-2012   #2
minbari's Avatar
Rep Power: 237 minbari is a name known to allminbari is a name known to allminbari is a name known to allminbari is a name known to allminbari is a name known to allminbari is a name known to allminbari is a name known to allminbari is a name known to allminbari is a name known to allminbari is a name known to allminbari is a name known to all
Default Re: Powering mini dsp
the minidsp have +12v, gnd and remote turn on, just like any device. do NOT power it with your remote from your HU, it will burn it up.
Original post whore!
Bent Nail Brewery
2014 Tacoma, Stock HU |AC LC2i | Dayton 408 DSP | Phoenix Gold T500.2 -> Silver Flute 8" | -> JL 300/2 -> Vifa XT25 | JL 500/1 -> 12" ID IDQ
Old 10-16-2012   #3
Mine has no remote input. It's the dsp in a box. Maybe different.
Old 10-16-2012   #4
Notloudenuf's Avatar
Human (not a robot)
Rep Power: 168 Notloudenuf is just really niceNotloudenuf is just really niceNotloudenuf is just really niceNotloudenuf is just really niceNotloudenuf is just really niceNotloudenuf is just really niceNotloudenuf is just really niceNotloudenuf is just really niceNotloudenuf is just really niceNotloudenuf is just really niceNotloudenuf is just really nice
Not all of them have remote turn on. I used a 9V battery when I ran it (ghetto)
The cigarette lighter to USB adapters have been used before as well.
NCSQ
Old 10-16-2012   #5
analogrocker's Avatar
Rep Power: 129 analogrocker will become famous soon enoughanalogrocker will become famous soon enoughanalogrocker will become famous soon enoughanalogrocker will become famous soon enoughanalogrocker will become famous soon enoughanalogrocker will become famous soon enough
Mine didn't have a remote turn-on input. I had the 2x4. I had to use the miniDC Isolator for remote turn-on.
analogrocker is offline   Reply With Quote Quick reply to this message
Old 10-16-2012   #6
minbari's Avatar
sorry, was looking at the 2x8/8x8 manual, he didnt specifiy.
you are right, with the 2x4 you can power it 12VDC, but put a relay between the HU RTO lead or use the isolation power supply as analogrocker mentioned.
Bent Nail Brewery
Old 10-16-2012   #7
Ok. I'm already using a rto relay for my amps. I wasn't sure if it would cause noise or any type of feedback. Not sure how it could burn the unit up.
Old 10-16-2012   #8
minbari's Avatar
lol, I guess I have not been clear all the way around, lol.
I meant if you tried to power the minidsp with the HU RTO it would burn up the RTO on the HU. it would draw more current than the RTO could provide.
if you have already put a relay to switch the RTO signal, you are good to go.
only concern will be turn-on/off thumps since it will turn on/off at the same time as the amplifiers.
that is one place where the iso-power supply would be of help, I beelive it has a turn-on/off delay biult in.
Bent Nail Brewery
Old 10-16-2012   #9
That was going to be my next question. Wasn't sure if that DC isolator had delay. I bought my dsp off caco unused the other day not had time to research everything yet.
Old 10-16-2012   #10
Well... found out it does have delay. Guess I'll be ordering the DC isolator.
Old 10-16-2012   #11
How the DC Isolator works is like this:
The miniDSPs are turned on immediately.
Then there's a 3 second delay before turning on the amplifiers.
When shutting down the gear, the amplifiers turn off first, followed by the miniDSPs 3 seconds later.
Old 10-17-2012   #12
I hooked it up to relay. No on or off pop but do have alternator whine. Bummer
Old 10-17-2012   #13
Common problem with the miniDSP when used in a vehicle. miniDC Isolator will solve that issue as well.
Or.. you could DIY by using one of these:
1205S DC-DC 5V(2Watt) Isolated Power Module. Ideal for 12V system
Instructions how to wire it up are here:
https://www.diymobileaudio.com/forum/...9-post251.html
Old 10-17-2012   #14
I went ahead and ordered the isolator. Just have to wait. I shoulda known I'd need it.
