Interesting Factory Sub Design....Isobaric Maybe??? - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 03-07-2015   #1
Niebur3's Avatar
High Definition Mobile Audio
Rep Power: 334 Niebur3 has a reputation beyond reputeNiebur3 has a reputation beyond reputeNiebur3 has a reputation beyond reputeNiebur3 has a reputation beyond reputeNiebur3 has a reputation beyond reputeNiebur3 has a reputation beyond reputeNiebur3 has a reputation beyond reputeNiebur3 has a reputation beyond reputeNiebur3 has a reputation beyond reputeNiebur3 has a reputation beyond reputeNiebur3 has a reputation beyond repute
Default Interesting Factory Sub Design....Isobaric Maybe???
This is the factory sub I pulled from my wife's 2011 Honda Pilot. It is very odd looking. It looks like a siamese twin that was never separated at birth. The 2 cones are different sized. The one playing to the front is 7.25" and the one behind is 6". As far as the sound.....not very good. The voice coil is front mounted (i.e. illusion audio) on the rear 6" "sub".
So, is this isobaric or one 6" sub with a 7" passive radiator attached?
Interesting design and I'm just wondering if the benefit to this design may cause us to see more. People that have more knowledge, please discuss.
Old 03-08-2015   #2
Rep Power: 77 Jcharger13 will become famous soon enoughJcharger13 will become famous soon enoughJcharger13 will become famous soon enoughJcharger13 will become famous soon enoughJcharger13 will become famous soon enoughJcharger13 will become famous soon enough
Default Re: Interesting Factory Sub Design....Isobaric Maybe???
Interesting design. I'd like to hear from the pros on this as well.
2013 Dodge Charger
Stock 8.4n HU - Pac adapter - Helix DSP pro
2x zuki eleets v1 4 channel -
Scan 18w revs, 10f's, Illum r3004
HD 1200/1, 12w7ae
Jcharger13 is offline   Reply With Quote Quick reply to this message
Old 03-08-2015   #3
Rep Power: 0 t3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to allt3sn4f2 is a name known to all
Doesn't look isobaric since the area inside the two cones is not isolated. My wild guess would be that it probably a way to bring up cone mass and rigidity using available material and saving spider cost at the same time. As well as gaining some linearity holding the cone at a great width than with the tradition coil first, spider, then surround.
Old 03-08-2015   #4
show all angles and pictures of the spider.
cut out a wedge so we can see a cut-away.
weigh the cones, and give us T-S parameters.
Old 03-08-2015   #5
Niebur3's Avatar
There isn't a spider.
T/S are as follows:
Re: 1.802 ohms
Fs: 43.74 Hz
Qts: .824
Qes: .938
Qms: 6.732
Le: .524
Old 03-08-2015   #6
might be a way to prevent spider sag, if the surrounds are able to hold the coil in alignment.
for a heavy cone with small Vd, the spider sag issue might be more prevalent and enough of an issue to call for drastic measures.
Old 03-12-2015   #7
Rep Power: 223 Patrick Bateman is just really nicePatrick Bateman is just really nicePatrick Bateman is just really nicePatrick Bateman is just really nicePatrick Bateman is just really nicePatrick Bateman is just really nicePatrick Bateman is just really nicePatrick Bateman is just really nicePatrick Bateman is just really nicePatrick Bateman is just really nicePatrick Bateman is just really nice
Looks like someone ripped off Earl Geddes.
That's an acoustic lever. He has a patent on that.
An acoustic lever is a speaker design where you have one cone driving a passive cone. In concept, it is somewhat similar to a bandpass box. Except you have a passive radiator instead of a port, and the big difference is that the passive radiator is physically connected to the woofer.
^^ picture this, but with the two cones physically connected
Old 03-12-2015   #8
Rep Power: 55 omnibus will become famous soon enoughomnibus will become famous soon enoughomnibus will become famous soon enoughomnibus will become famous soon enoughomnibus will become famous soon enoughomnibus will become famous soon enough
Is this any similarity to Alpines PLV-7 without the enclosure? I always thought that was such an interesting design but never could find one. Would like to hear it someday.
omnibus is offline   Reply With Quote Quick reply to this message
Old 03-12-2015   #9
808 Sound Factory
Rep Power: 108 HiloDB1 will become famous soon enoughHiloDB1 will become famous soon enoughHiloDB1 will become famous soon enoughHiloDB1 will become famous soon enoughHiloDB1 will become famous soon enoughHiloDB1 will become famous soon enough
Just looks like they used a secondary cone/surround as a "spider" vs a traditional one.
HiloDB1 is offline   Reply With Quote Quick reply to this message
