Quick disconnects? - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 11-24-2007   #1
Rep Power: 196 Mless5 will become famous soon enoughMless5 will become famous soon enoughMless5 will become famous soon enoughMless5 will become famous soon enoughMless5 will become famous soon enoughMless5 will become famous soon enough
Default Quick disconnects?
Are there any quick disconnects in form of a single plug? I'd like my father to be able to unplug one big plug and 2 pair of rcas instead of doing wire by wire type of deal. So far, I'd like to see 6 speaker wires terminate on one big plug. Anything like that available?
Thanks
Old 11-24-2007   #2
Rep Power: 0 khail19 will become famous soon enoughkhail19 will become famous soon enoughkhail19 will become famous soon enoughkhail19 will become famous soon enoughkhail19 will become famous soon enoughkhail19 will become famous soon enough
Default Re: Quick disconnects?
They make Molex connectors in various configurations, any electronics place will usually carry them. Something like this...
khail19 is offline   Reply With Quote Quick reply to this message
Old 11-24-2007   #3
Thanks mate! That is exactly what I am looking for!
Old 11-24-2007   #4
Rep Power: 0 bobditts will become famous soon enoughbobditts will become famous soon enoughbobditts will become famous soon enoughbobditts will become famous soon enoughbobditts will become famous soon enoughbobditts will become famous soon enough
check partsexpress. I think they sell some plugs similar to that.
bobditts is offline   Reply With Quote Quick reply to this message
Old 11-24-2007   #5
Rep Power: 200 Whiterabbit will become famous soon enoughWhiterabbit will become famous soon enoughWhiterabbit will become famous soon enoughWhiterabbit will become famous soon enoughWhiterabbit will become famous soon enoughWhiterabbit will become famous soon enough
any electronics store. different brands sell different plugs. everything from one quick disconnect to a plug with fifteen lines or even more. the pins can be tiny or very large, and some places even sell screw on type military connectors that are vibration proof.
can find plugs that are panel mount, surface mount, and cable mount.
check out what your local electronics store has. I typically buy my molex plugs from frys electronics. I use .062" pins, .096" pins, and I think .08" found on hard drive power connections. I use TONS of those in my car.
Whiterabbit is offline   Reply With Quote Quick reply to this message
Old 11-24-2007   #6
Rep Power: 151 Lumadar will become famous soon enoughLumadar will become famous soon enoughLumadar will become famous soon enoughLumadar will become famous soon enoughLumadar will become famous soon enoughLumadar will become famous soon enough
I too am looking for something like this.
I would love some solid connectors for my speakers so I can unplug them to work on stuff if need be. I only found one connector like that on PartsExpress, but it says 18-22 gauge.
Think I could get away with fitting 14 gauge speaker wire in those?
http://www.partsexpress.com/pe/showd...number=092-552
Lumadar is offline   Reply With Quote Quick reply to this message
Old 11-24-2007   #7
yep. it will if the jacket is small. I use .093 all the time.
18 gauge fits easily in .062, and some 16 gauge wires will fit also.
also. buy the pin extractor. Its a ripoff, and you will be SO GLAD you have it.
http://shop1.outpost.com/search?sear...ing=.093&cat=0
Old 11-24-2007   #8
Rep Power: 180 silent1 will become famous soon enoughsilent1 will become famous soon enoughsilent1 will become famous soon enoughsilent1 will become famous soon enoughsilent1 will become famous soon enoughsilent1 will become famous soon enough
Might have something here...
http://www.delcity.net/delcity/servlet/navi?action=home
silent1 is offline   Reply With Quote Quick reply to this message
Old 11-24-2007   #9
Yeah, I'd like something that I can screw down to the box.
Old 11-25-2007   #10
Rep Power: 151 QtrHorse will become famous soon enoughQtrHorse will become famous soon enoughQtrHorse will become famous soon enoughQtrHorse will become famous soon enoughQtrHorse will become famous soon enoughQtrHorse will become famous soon enough
Something like this below might work (you would need both sides) but you cannot screw it down to the box. You can get the inserts in many different gauges of wire.
Delphi Packard Connector
QtrHorse is offline   Reply With Quote Quick reply to this message
Old 11-25-2007   #11
Infinity's Avatar
Rep Power: 190 Infinity will become famous soon enoughInfinity will become famous soon enoughInfinity will become famous soon enoughInfinity will become famous soon enoughInfinity will become famous soon enoughInfinity will become famous soon enough
That's teh ones I recommend. I know Ford is using a lot of them in newer vehicles, and they're sturdier than any Molex ones I've used. I think Waytek carries them in many different configurations. Also check Mouser.
I gots no stereo for now......
Infinity is offline   Reply With Quote Quick reply to this message
Old 11-25-2007   #12
Yes, Waytek carries them in quite a few different configurations but they have a minimum for item you have to buy. You would need to buy around 100 of the little metal inserts (I believe there minimum per item is either $5 or 100 pcs). I buy all my crimp rings at Waytek. They are the cheapest and nicest that I have used (around $00.60 per 2/0 tinned crimp ring). Very are heavy duty and you can get them in tinned or copper finish.
Old 11-25-2007   #13
SQ_Bronco's Avatar
Rep Power: 181 SQ_Bronco will become famous soon enoughSQ_Bronco will become famous soon enoughSQ_Bronco will become famous soon enoughSQ_Bronco will become famous soon enoughSQ_Bronco will become famous soon enoughSQ_Bronco will become famous soon enough
x2 on the pin extractor. IIRC it's like $7 at radio shack. Good luck fitting 14AWG, i can definitely say that 12 streetwires twisted pair does not fit well w/.093 (it can be done, but it's tough, and you have to trim out some of the wire). canare 16AWG fits easily.
I'd also recommend soldering the wires because they have a tendency to pull out when just crimped. that is a good way to let the magic smoke out of your amplifiers.
"Don't eat that! It's Pluto!!!"
SQ_Bronco is offline   Reply With Quote Quick reply to this message
**WTB 1 0r 2, 10" or 12", 4 ohm subs to run w/ D5 1200.1..Quick like!!! covmachine Car Audio Classifieds 2 08-02-2007 09:11 AM
Quick question guys. Spray ensolite with glue, or surface? ErinH Technical & Advanced Car Audio Discussion 10 04-28-2007 06:59 PM
Quick Disconnects for a removable rig..... chad Technical & Advanced Car Audio Discussion 7 04-13-2007 02:41 PM
do tiny quick disconnects for tweeters exist? DonutHands Technical & Advanced Car Audio Discussion 16 12-28-2006 01:27 AM
quick question on subwoofer control and amplifier power mikemareen Technical & Advanced Car Audio Discussion 9 07-12-2006 03:57 PM
