Need help tuning active setup! - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 05-10-2019   #1
Rep Power: 0 skeptikal will become famous soon enoughskeptikal will become famous soon enoughskeptikal will become famous soon enoughskeptikal will become famous soon enoughskeptikal will become famous soon enoughskeptikal will become famous soon enough
Default Need help tuning active setup!
Hello everyone! I've finally gotten my stereo installed and cannot get it really dialed in to save my life. I've run the Auto TA/EQ on the 80prs, but the highs are still quite bright, and I feel like the vocals are quite muddy at higher volume.
So with the setup below.. how the hell should I go about tuning this?
Flat DEH EQ -> Gain/Xovers on amps -> Auto TA/EQ???
Flat DEH EQ -> Auto TA/EQ -> Gain/Xovers???
Mids/Highs
PPI 900.4 (4-channel mode)
2x Image Dynamics XS65 mids
2x Image Dynamics XS28 tweets
Sub stage --
Wolfram 1500.1 @ 1 ohm
2x Sundown Audio SA-12 @ 1 ohm
skeptikal is offline   Reply With Quote Quick reply to this message
Old 05-10-2019   #2
Rep Power: 29 Nik_Ind will become famous soon enoughNik_Ind will become famous soon enoughNik_Ind will become famous soon enoughNik_Ind will become famous soon enoughNik_Ind will become famous soon enoughNik_Ind will become famous soon enough
Default Re: Need help tuning active setup!
Lots of info on here, man! In your case, I would leave the headunit alone, and start from scratch. First set the gains, and then crossovers on the amplifier. Leave everything on the 80prs flat/off. See how you like the setting with changes made at the amplifier level, and then fine tune with the EQ (Bass-mid-treble-fader) on the 80prs. I don't have knowledge on the headunit as such, but I'd leave the auto TA function alone; since, I remember having read somewhere that it really messes up the tonality of the system.
Maybe the others can help more particularly with this headunit. Cheers!
'17 Ford Mustang GT Front- AudioFrog GS10- 4" Focal ES100K- SI TM65 mkIII
Rear Fill- SO Audio 165 2.8
Subwoofer- 2 Rockford 10" P2D4s
Amp/DSP- Helix V Eight DSP (F/R fill)- Audison SR1dk (subs).
Nik_Ind is offline   Reply With Quote Quick reply to this message
Old 05-10-2019   #3
Ifixtheinternet's Avatar
Rep Power: 48 Ifixtheinternet will become famous soon enoughIfixtheinternet will become famous soon enoughIfixtheinternet will become famous soon enoughIfixtheinternet will become famous soon enoughIfixtheinternet will become famous soon enoughIfixtheinternet will become famous soon enough
I have the 80prs and this is all backwards.
The auto T/A does a near perfect job, use it.
Sit in the driver seat with the mic taped to your forehead. Tilt the seat back a couple inches so the mic is where the center of your head is normally.
This will get the best auto results, but auto EQ still won't be the greatest.
The crossover network is powerful on the 80prs, having crossover options is one of the main advantages of going active.
Set all your amp crossovers to off or full-band.
You'll need to experiment with crossovers, but a good place to start is:
SUB: LPF 80HZ 24DB
MID: HPF 80HZ 24DB - LPF 2.5K 24DB
HIGH: HPF 2.5K 24DB
Edit: looks like those tweets like 3k.
Try 3k / 3k or 2k /3k with a more shallow slope.
I have my sub set at 63hz / 24db.
The auto EQ is far from ideal, manual EQ is way better, even with a cheap mic you can plug into your phone.
I also found the highs were too bright when I tried it, and it was boosting some mid-range frequencies into distortion.
A umik -1 and REW are golden for dialing in your EQ.
Sent from my Pixel XL using Tapatalk
Subaru Legacy SQ build
Pioneer DEH-80PRS | Alpine MRD-M500 - 2 JL Audio 12W3v3 | Rockford Fosgate Prime 300 @ 412 Watts RMS | SB Acoustics SB17MFC35 | Alpine Hiend 28mm tweeters
Ifixtheinternet is offline   Reply With Quote Quick reply to this message
Old 05-10-2019   #4
SUB: LPF 80HZ 24DB
HIGH: HPF 2.5K 24DB
My apologies! Was merely trying to help him out, but made sure I mentioned that I had no idea about the 80prs.
OP, please ignore my post. Cheers!
The Following User Says Thank You to Nik_Ind For This Useful Post:
Ifixtheinternet (05-10-2019)
Old 05-10-2019   #5
No, I'm sorry, that did come off as a bit rude!
Definitely want to start from scratch, everything needs to be revisited when moving to an active setup.
Get the criticals verified first.
Make sure all the speakers are in the same phase. Don't trust the terminals, speakers have been internally wired backwards before.
Use "polarity checker" app to verify all speakers are at 0 phase, including subs.
Then do gains, then T/A, then level match drivers.
The 80prs will play clean to 61/62 volume on all frequencies, provided you aren't boosting any frequencies, which I don't recommend.
The Following User Says Thank You to Ifixtheinternet For This Useful Post:
Nik_Ind (05-10-2019)
Old 05-10-2019   #6
Rep Power: 369 gijoe has a reputation beyond reputegijoe has a reputation beyond reputegijoe has a reputation beyond reputegijoe has a reputation beyond reputegijoe has a reputation beyond reputegijoe has a reputation beyond reputegijoe has a reputation beyond reputegijoe has a reputation beyond reputegijoe has a reputation beyond reputegijoe has a reputation beyond reputegijoe has a reputation beyond repute
I do agree that the auto TA is pretty good, but I still think you can get it better by setting the distances manually. It may not make a big difference, so it wouldn't hurt to run the auto calibration and see. The auto EQ on the other hand never gave me very good results, but luckily you can override the EQ while leaving the TA alone. Every Pioneer deck I've used (880PRS, 80PRS, and P99RS) all needed serious work on the high frequencies after running the auto tune, all of them left the tweeters way too high.
I highly recommend setting your crossovers before running the auto tune, don't trust the auto tune to do that.
Old 05-10-2019   #7
No sweat, bud! It's all good. We're all just helping each other out. Cheers
Old 05-19-2019   #8
So I set everything flat, set the gains on the amp (still kind of by ear, nothing scientific) and ran the auto TA/EQ.
The Auto TA was an INCREDIBLE step up and now the stage seems to be a bit more full. The auto EQ definitely produced some pretty piercing highs, but a simple -1 tweak made quite a bit of difference.
Definitely need some more tweaking but I don't have a mic or anything right now. Sounds pretty decent by ear for now until I can get it tuned.
Future plans
- 320a Mechman alt
- 1 or 2 more 1/0 runs
- Big 3 (or 4 whatever) upgrade
- Custom fiberglass under the back seat. Currently a FoxAcoustics Dual 12 ported.
DEH-80prs
Image Dynamics XS65 / XS28
PPI 900.4
Sundown Audio SA-12 (x2)
Wolfram 1500.1
Old 05-19-2019   #9
SkizeR's Avatar
Prisoner
Apicella Auto Sound
Janitor
Rep Power: 449 SkizeR has a reputation beyond reputeSkizeR has a reputation beyond reputeSkizeR has a reputation beyond reputeSkizeR has a reputation beyond reputeSkizeR has a reputation beyond reputeSkizeR has a reputation beyond reputeSkizeR has a reputation beyond reputeSkizeR has a reputation beyond reputeSkizeR has a reputation beyond reputeSkizeR has a reputation beyond reputeSkizeR has a reputation beyond repute
Originally Posted by skeptikal View Post
- 1 or 2 more 1/0 runs.
150% unnecessary with your setup
Sent from my SM-G950U1 using Tapatalk
Old 05-19-2019   #10
You can sort out you're left / right EQ without a mic.
Create mono sine wav tones at each interval of EQ on the prs (300, 500 etc.) Use audacity or another free program to create them.
Then as you play each tone, cut the left or right side EQ for that frequency on the stronger side until you get the tone coming from the center of the windshield.
Skip 125 and below.
The higher frequencies are more difficult.
If you find yourself cutting nearly all of one side over the other, you should probably lower the level on that side one notch and start again.
I think this method actually works better than with a mic anyway.
For your final house curve, you'll definitely need a mic.
Need some help on 3-way Active Setup - Tuning Specific onetwosixtwo Technical & Advanced Car Audio Discussion 13 03-01-2018 09:13 AM
Need initial setup/tuning help please jbb2388 General Car Audio Discussion 67 12-21-2015 07:30 PM
Need help tuning gains/crossovers with impotent setup Shorebreak Technical & Advanced Car Audio Discussion 3 07-07-2011 10:46 AM
Help with tuning an Active setup (using the $100 RTA) for both front passengers donkeypunch22 Technical & Advanced Car Audio Discussion 1 04-19-2011 02:40 AM
need help with tuning my 3 way active setup remps44 Technical & Advanced Car Audio Discussion 2 05-31-2007 10:58 AM
