2015 F150 platinum audio overhaul - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 05-14-2019   #1
Rep Power: 123 senile32nd will become famous soon enoughsenile32nd will become famous soon enoughsenile32nd will become famous soon enoughsenile32nd will become famous soon enoughsenile32nd will become famous soon enoughsenile32nd will become famous soon enough
Default 2015 F150 platinum audio overhaul
Hi All,
been a while since ive been on here or even messed with car audio.. we all come back eventually. Finally getting to overhauling my trucks audio.
Noico matting everything: its cheap and it works.
looking at running a tesla like screenhttps://www.phoenixautomotiveinc.com...-150-2016-2017
currently have: JL Audio 750/1HD for 13TW5, and 600/4HD
need to buy:
thinking of C5 653 and C5650x for rear.
Rockford fosgate DSR1 for integration and DSP
question is: should i run this active off the 600/4? is it even possible to, with the 3 way up front?
should i be looking at different speakers? i know things have changed since I've messed with things.
what are your opinions?
senile32nd is offline   Reply With Quote Quick reply to this message
Old 05-14-2019   #2
Rep Power: 0 Kyleo91 will become famous soon enoughKyleo91 will become famous soon enoughKyleo91 will become famous soon enoughKyleo91 will become famous soon enoughKyleo91 will become famous soon enoughKyleo91 will become famous soon enough
Default Re: 2015 F150 platinum audio overhaul
If your running 3 way active up front you need 6 channels of amplification. 1 channel per driver.
Sent from my Pixel 3 XL using Tapatalk
Kyleo91 is offline   Reply With Quote Quick reply to this message
Old 05-14-2019   #3
roger i guess ill just go passive and make my life easier and less expensive lol
Old 05-28-2019   #4
therapture's Avatar
Rep Power: 96 therapture will become famous soon enoughtherapture will become famous soon enoughtherapture will become famous soon enoughtherapture will become famous soon enoughtherapture will become famous soon enoughtherapture will become famous soon enough
You can run a nice 6x9 in that door easily for the increased midbass output over a 6.5"
I am using the DSR-1 as a DSP. Works very well in keeping the OEM head unit and is a breeze on install.
See my thread in the build logs.... https://www.diymobileaudio.com/forum...h-project.html
2015 Ford F150 Platinum Supercrew 4x4 "stealth audio"
DSR-1 / Alpine V9 / CDT-ES02 / Alpine S69 / (2) Dayton DCS165 vented
therapture is offline   Reply With Quote Quick reply to this message
Old 05-28-2019   #5
Rep Power: 56 jdunk54nl will become famous soon enoughjdunk54nl will become famous soon enoughjdunk54nl will become famous soon enoughjdunk54nl will become famous soon enoughjdunk54nl will become famous soon enoughjdunk54nl will become famous soon enough
You do not need to run the dsr-1. You can achieve this with forscan (setting everything to flat and can even do low level output) if you don't mind splicing or a $60 harness if you want no cut no splice of factory wires (For-11ck harness)
But if you also want the dsp capabilities of the dsr-1 than go for it, many have chose the forscan and dayton dsp combo over the dsr-1 though on f150 forums.
2014 F150 Limited
Factory HU programmed for 4v outputs, Alpine PDX-V9, Active Tweeters: SI M25, Mids: SI TM65 mk3, Sub: JL TW3, Rears: SB17's, Helix DSP.2, Resonix 35% CLD and 100% CCF, 100% MLV
jdunk54nl is offline   Reply With Quote Quick reply to this message
Old 05-29-2019   #6
therapture's Avatar
If you are completely removing the factory amp, you do not need FORSCAN as the oem head unit, at least on the Sony Premium system, outputs a flat, un-EQ'd signal. The amp itself is where the DSP/EQ is applied.
I chose the DSR-1 because I wanted a fast portable way of controlling it via my Ipad and bluetooth. Also for the super simple integration into the factory harness. I have a 360.3 but the DSR-1 was just easier to install and quite frankly it has all of the adjustability of the 360.3 in a smaller package. I have had great success with it.
Old 06-02-2019   #7
hi all,
well I installed the my amps and DSR 1 and all went well. i havent ordered my C5653 set yet and am thinking of buying a 6 channel amp and going active, ill keep my 600.4 for rear speakers. i am looking at the Zapco line of AB amps.. what are you thoughts on using a AB amp in leu of the D class i have now?
Old 4 Weeks Ago   #8
ok update and need help
DSR1 installed but went with active 3 way from Stereo integrity instead of the C5s, also got an extra 3.5 to run a center channel so i can set front stage center mass in truck. I also want to run either a 2 way coax in the back or single wide band 6.5 for rear fill and so my daughter can rock out too.
DSR1 doesnt have enough channels out WTF lol what do do now?
add a DSP to the DSR1 or ditch it and keep the Maestro cable and run something else?
current setu is as follows
MMats 6150d amp for front 3 way stage
JLHD 600.4 for center channel and rear fill
JL HD 750.1 with JL 13tw5
HELP!!
Old 4 Weeks Ago   #9
How are you tuning all of this? I didn't think the dsr1 could handle center channel processing. A proper tune can get your center near perfect without the use of a center channel.
Also to do everything you want you either need to add another dsp or swap out the dsr1 for something with more outputs like the helix pro.
2014 F150 Limited
Old 4 Weeks Ago   #10
ok my conclusion of options:
DSR1 used soley as integration and then the new alpine DSP for 699.
option 2 DSR1 and then a dayton on 4 channels to 8 channels and have to tune separately.
obviously option 2 much cheaper but how hard will that be to tune? initial PITA but not that big of a deal or nightmare?
Old 3 Weeks Ago   #11
well i came to a conclusion and if anyone is interested in how it turns out let me know.
DSR1 straight passthrough 6 channels full band going into a alpine PXE 0850S and doing full DSP that way..
Stereo integrity 3 way upfront. have the 6.5 and 3.5 in sealed doors and gonna try to put the tweaters in stock location if no go then in sail panels. have same 3.5 in as center channel. morel tempo 6.5 2 way coax in rear for fill, original 13TW5 3 ohm version for sub. MMATS 6150D, JL HD 600.4, 750.1; hoping it sounds great, will need to find someone near st pete to tune as i dont have all the tools and dont plan on doing this over and over again so should be cheaper than buying more tools.
F150 platinum... its been awhile... help! Gagezilla System Design - Help Me Choose Equipment For My Car 50 09-19-2018 08:51 PM
Recommendations for 2015 F150 Super Crew with Sony Audio Smash System Design - Help Me Choose Equipment For My Car 0 02-02-2018 01:00 AM
2015 F150 Platinum - Simple install - Sundown/Arc Audio/Audison KBT2011 Build Logs & Project Install Gallery 4 05-25-2016 08:54 AM
2015 Fall NCSQ Meet - 07 November 2015 - near Greensboro, NC bertholomey 12 Volt Events & Team DIYMA 693 12-30-2015 06:21 PM
2015 Spring NCSQ Meet - 25 April 2015 - near Greensboro, NC bertholomey 12 Volt Events & Team DIYMA 1062 07-27-2015 07:23 PM
