Protovision Reality 264 Amps minimum gain is to high for PRS80 headunit - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 3 Weeks Ago   #1
WinWiz's Avatar
Rep Power: 75 WinWiz will become famous soon enoughWinWiz will become famous soon enoughWinWiz will become famous soon enoughWinWiz will become famous soon enoughWinWiz will become famous soon enoughWinWiz will become famous soon enough
Default Protovision Reality 264 Amps minimum gain is to high for PRS80 headunit
I'm running 2 way + sub active with this hardware:
Headunit: Pio 80prs
Amp1: Protovision reality 264 (2ch. Power my tweeters)
Amp2: Pioneer D8604 (4ch. Bridged to power my woofers)
Amp3: D8604 (4ch. Bridged to power my dvc sub)
I like the sound my SB acoustics tweeters produce in combo with the protovision amp. But the gains on this old-school amp doesn't seem fit for the 80prs high voltage output. So what are my options? Should I set the gain on my pioneer amps to match the level of the protovision amp?
Or use the 80prs to match the levels?
Maybe my best option is to remove the protovision amp and run woofers and tweeters from my D8604, even though this would mean that my SB17NRX woofers would only receive about 100W each (instead of 150W) ?
Or maybe use the 80prs internal amp to power the tweeters?
WinWiz is offline   Reply With Quote Quick reply to this message
Old 3 Weeks Ago   #2
Nottinghamshire Police
Auto electrician/Fabricator
Rep Power: 154 dumdum will become famous soon enoughdumdum will become famous soon enoughdumdum will become famous soon enoughdumdum will become famous soon enoughdumdum will become famous soon enoughdumdum will become famous soon enough
Default Re: Protovision Reality 264 Amps minimum gain is to high for PRS80 headunit
As long as the gains are right down I’d then knock back the Prs output so it doesn’t clip and enjoy the old school output, basically use as much output as you can for each individual amplifier
dumdum is offline   Reply With Quote Quick reply to this message
Speaker Distortion on Minimum Gain robdewitte General Car Audio Discussion 6 10-20-2018 11:13 PM
Subwoofer too loud with minimum gain cossix General Car Audio Discussion 6 08-28-2018 09:51 AM
given that 'cabin gain' is a reality, do we need a low fs? 60ndown Technical & Advanced Car Audio Discussion 194 03-02-2015 11:23 AM
The Complexity In Sound Install - 2008 Acura RL :) (264 pics!) simplicityinsound Build Logs & Project Install Gallery 164 12-17-2014 10:43 PM
a/d/s 264 crossover freq dcarwin Technical & Advanced Car Audio Discussion 0 03-12-2008 12:00 PM
