Stuffing a small sealed box, is it ok? - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 05-26-2019   #1
Rep Power: 26 bitshifted will become famous soon enoughbitshifted will become famous soon enoughbitshifted will become famous soon enoughbitshifted will become famous soon enoughbitshifted will become famous soon enoughbitshifted will become famous soon enough
Default Stuffing a small sealed box, is it ok?
I've been reading around and the advice for stuffing tends to be 1lb per cu/ft of air. My question relates to making the box appear larger when it's outside the manufacturers specifications.
Subwoofer: Audison APS8 D4
Recommended box: 0.3cu/ft (8.5l)
Recommended Qtc: 0.86
My box is 8.75l, a little larger than the maximum recommended size according to the manual. I read that if I stuff the box, it will make it appear larger and thus lower Qtc, which might help with transients and flatten the response curve. With stuffing, I could make the box appear 30% larger, but the Qtc will still remain around 0.8. This seems desirable, yes?
What problems might I have if I make the subwoofer box appear larger than recommended?
bitshifted is offline   Reply With Quote Quick reply to this message
Old 05-26-2019   #2
Rep Power: 86 dgage will become famous soon enoughdgage will become famous soon enoughdgage will become famous soon enoughdgage will become famous soon enoughdgage will become famous soon enoughdgage will become famous soon enough
Default Re: Stuffing a small sealed box, is it ok?
A sealed enclosure is also caused acoustic suspension as it leverages the closed airspace to control the cone. When the sub plays into the enclosure, the air pushes against the cone so it helps control the suspension of the sub. So you donít want to go too big or the suspensions starts to get sloppy and could damage the driver. With that said, I donít think youíre to the point where you will cause damage unless you also put a lot more power. Go ahead with your plans but pay attention to any noises coming from the driver and turn down the volume if so. If you need to take up space in an enclosure, you can glue in some blocks of wood, XPS foam, or similar. Happy testing.
The Following User Says Thank You to dgage For This Useful Post:
bitshifted (05-26-2019)
Old 05-26-2019   #3
Bayboy's Avatar
Rep Power: 193 Bayboy has much to be proud ofBayboy has much to be proud ofBayboy has much to be proud ofBayboy has much to be proud ofBayboy has much to be proud ofBayboy has much to be proud ofBayboy has much to be proud ofBayboy has much to be proud ofBayboy has much to be proud ofBayboy has much to be proud ofBayboy has much to be proud of
Why not EQ the response you desire?
Man & Machine... Power Extreme!
Old 05-26-2019   #4
Rep Power: 192 miniSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the roughminiSQ is a jewel in the rough
You probably want to get into a larger box physically and not just by stuffing the one you have if possible. QTC of .85 is kind of high, and you want to get down closer to the .707 mark if possible. But for now try it in the box you have lightly stuffed, don't over stuff it. And see how it sounds. If its too boomy sounding then i would suggest a larger box.
2018 Crosstrek
P SIX DSP MK2 GB10 GB25 Gs690 GB10d4x2 Z-2KD II
The Following User Says Thank You to miniSQ For This Useful Post:
Old 05-26-2019   #5
Rep Power: 222 tyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura abouttyroneshoes has a spectacular aura about
stuff it
Subaru Impreza - Pioneer MVH-1400NEX - Zapco Studio 100 - ESB DT 8.25 - Zapco ST-204D SQ - ESB 8.165 - Sundown SD3-10
Jeep Patriot - JBL MS8 - Alpine PDR-F50 - Kenwood KFC-XP6902C (6x9 + 2.75 wideband) - MB Quart P19 tweets - Alpine PDR-M65 - Boston Acoustics g5 10"
Old 05-26-2019   #6
What defines "too big"? Do TS parameters tell us? i.e. Qtc < 0.5 will likely damage the driver?
Obviously there's a range of values it will work fine, but I'm trying to get at the reason why the designer would specify a maximum of 8.5l, when a box nearly double that size will only reduce the Qtc by ~0.15.
Good question. I simply assumed that any mechanical method in achieving the outcome would be preferred.
So do you think the subwoofer designer is aiming at that Qtc for sonic reasons and not for preserving the driver's integrity?
The box is already too big by a small amount, just wondering if there might be any adverse affects of being "out of spec". Or if it simply lowers Qtc and there's no problems with doing so.
Old 05-26-2019   #7
bnae38's Avatar
Rep Power: 67 bnae38 will become famous soon enoughbnae38 will become famous soon enoughbnae38 will become famous soon enoughbnae38 will become famous soon enoughbnae38 will become famous soon enoughbnae38 will become famous soon enough
Should be ok as long as you go slow and use a little lube.
Sorry I only read the title.
2012 Subaru Impreza Sedan. Pioneer P880prs, Helix Dsp.2, JL 12w6v2 sealed, Arc KS1000.1, Modified Arc KS900.6, FI N.7 midbass, Illusion Audio C3cx. Ipod Classic - apple lossless. Just keep tryin' to get a little better.
bnae38 is online now   Reply With Quote Quick reply to this message
The Following User Says Thank You to bnae38 For This Useful Post:
DavidRam (05-26-2019)
Old 05-26-2019   #8
Bayboy's Avatar
The designer probably settled on a compromise between acceptable output and response in a particular range which may not look "audiophile perfect" on paper, but when combined with the car works out fine for most.
It's easy to obsess over what's the perfect Q when .707 is sometimes blindly preached, but there's many examples of well liked subs above that and without fuss.
What enlarging a sealed box does is tradeoff some mid to upper response for a bit more low end extension, but it is very possible to wind up with too much of a tradeoff.... dry boring bass with extension that may not be of advantage to certain genres. .707 is considered a good tradeoff, but the difference between that and even .6-.9 isn't much to fuss about. The same can be done with EQ unless you're limited on EQ and ppwer.
The Following User Says Thank You to Bayboy For This Useful Post:
bitshifted (05-27-2019)
Old 05-26-2019   #9
And Iíd say many manufacturers suggest too small of an enclosure for marketing reasons more than anything. If one manufacturer goes optimal, ie larger, then another manufacturer might steal sales because they say their sub works in a smaller enclosure. Sealed subs respond well to DSP if the enclosure is slightly off, especially with the small percentage differences youíre looking at with your enclosure.
Old 05-27-2019   #10
Excellent advice fellas, thanks for the input. Sounds like I can happily stuff the box and EQ the rest. As long as I use lube and go slow. Got it.
The Following User Says Thank You to bitshifted For This Useful Post:
bnae38 (05-27-2019)
Old 05-29-2019   #11
LBaudio's Avatar
Rep Power: 306 LBaudio has a reputation beyond reputeLBaudio has a reputation beyond reputeLBaudio has a reputation beyond reputeLBaudio has a reputation beyond reputeLBaudio has a reputation beyond reputeLBaudio has a reputation beyond reputeLBaudio has a reputation beyond reputeLBaudio has a reputation beyond reputeLBaudio has a reputation beyond reputeLBaudio has a reputation beyond reputeLBaudio has a reputation beyond repute
That Audison recomendation is one big marketing bull shit if you ask me. Also, you will not benefit of 30% in volume rise when stuffing box with fiberfill or wool...maybe up to 20% more likely less.
For Fast Moving Concerts
Team LB audio
Team Hybrid Audio
Team BRAX
Team SCB
Old 05-29-2019   #12
Bayboy's Avatar
What is bullshit about a suggestion by the manufacturer? Suggestions aren't rules. The manual clearly states "maximum performance in a sealed enclosure STARTING from 7.5 liters". Catch the keyword... starting? It also goes onto state the "the range of applications are wide" and suggests contacting an authorized dealer/ installer...
From that what can we gather? Not bullshit, but a mere starting guide to where outside of that you should know what you're doing, if not, seek professional assistance. By knowing that the average consumer isn't going to know the tradeoffs of Q/transient response, power handling, or even when to apply it, it doesn't make them wrong or full of fluff. Heck, most don't even use or know what a box modeling program is, how to interpret the data, much less the acoustics of their own vehicle. No manufacturer can tell you what is best for your car and tastes.... thus suggestions.
bitshifted (05-29-2019)
Old 05-29-2019   #13
I was initially questioning box size for a couple reasons: This is my first subwoofer install. Also the technical spec sheet differs slightly from the website, thus the confusion.
The tech sheet says "from 7.5l", whereas the website says "The APS 8 D is designed to deliver maximum performance in a sealed enclosure with ultra-compact volumes from 7.5 lt. to 8.5 lt.". Couple that with their reference box in the manual being pretty close to 8.5l - that's why I bothered to ask questions here.
After the great advice here and reading around the interwebs on Qtc, I now realise the significance of "deliver maximum performance" in their marketing. The suggested upper bound of 8.5l is really a max efficiency thing, no? So if you know what you are doing and have the power to spare, you can push those suggested performance limits.
Old 05-29-2019   #14
Bayboy's Avatar
Actually, if you have less power to spare. As stated earlier, the tradeoffs in upper response for lower extension or efficiency usually means less power required to reach maximum excursion. However, without knowing how your particular vehicle boosts the low end, it becomes an experiment. Not a bad one since sealed is very forgiving in response, especially if you have a decent EQ for corrections.
If you feel you need to increase box size substantially over the suggested, just understand the tradeoffs. Stuffing the suggested box size will have a minimal although audible effect. If you want to get an estimate of said tradeoffs, model the sub in various sizes. Quite easy and fun to do.
Does stuffing a sealed box work?? masoman95 General Car Audio Discussion 12 03-04-2017 06:18 PM
Stuffing a port on a ported subwoofer box makes it sealed??? Ultimateherts Car Audio Truth, Myths & Industry Dogma 29 07-28-2014 04:16 AM
w12gti from sealed to ported (can I use stuffing) matdotcom2000 DIYMA - SPL Forum 12 06-08-2011 06:25 PM
box stuffing question xencloud Technical & Advanced Car Audio Discussion 5 07-18-2007 10:30 AM
Sub Box Stuffing Q - DIYMA12 CBRworm Technical & Advanced Car Audio Discussion 7 11-27-2006 04:12 PM
