Picking driver and crossover points - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 12-03-2006   #1
Rep Power: 156 -=Jeff=- will become famous soon enough-=Jeff=- will become famous soon enough-=Jeff=- will become famous soon enough-=Jeff=- will become famous soon enough-=Jeff=- will become famous soon enough-=Jeff=- will become famous soon enough
Default Picking driver and crossover points
I know these need to go hand in hand. What I am curious on is if you are doing a 2-way active set-up, how shoudl you pick the drivers?
Meaning, if you wanted a crossover point of 3kHz (that number is picked for the question only) when you look for drivers, what is the minimum freq response you would want the low end to be for the high side (tweeter) and max freq response for the low end (midrange)?
then what is a good range for a crossover point, meaning many cars are different and that will vary the crossover point, so what is a typical median setting and what range from there?
From reading Daytons (rs225) seem to have a lower high end for freq ( 2kHz? approx) so could you crossover at 2kHa or is that not a good idea.
just trying to get a better grasp for some of those basics before determining the drivers.
-=Jeff=- is offline   Reply With Quote Quick reply to this message
Old 12-03-2006   #2
Rep Power: 160 andthelam will become famous soon enoughandthelam will become famous soon enoughandthelam will become famous soon enoughandthelam will become famous soon enoughandthelam will become famous soon enoughandthelam will become famous soon enough
Default Re: Picking driver and crossover points
If you wanted a median range I believe that your value of 3KHz is pretty median w/ 2kHz-5kHz being a typical for crossong over say a tweeter and a 6.5" mid. Manufacturer's specs are hard to compare A/B. Look through some of the DIYmobile review sites for usable frequency response on different drivers and more importantly the sound you are looking for (Warm, bright, neutral, strong midbass, detailed, nice top-end.....).
Alpine X305S, Alpine Imprint, JL 500/5, Morel MDT43, Scan 18S/8531 , JL 10w6v2
It's not about the audio equipment, it's about the music!
andthelam is offline   Reply With Quote Quick reply to this message
Old 12-03-2006   #3
Yeah but if your xover point is 3kHz, could you use a driver with the freq response of 3kHz-20kHz and the midrange with a response of 40Hz-3kHz or would 2.5kHz-20kHz and 40Hz-3.5kHz be better with the 3kHz crossover point?
Old 12-03-2006   #4
fej
Rep Power: 167 fej will become famous soon enoughfej will become famous soon enoughfej will become famous soon enoughfej will become famous soon enoughfej will become famous soon enoughfej will become famous soon enough
To hell with what I had to say ... just read what Mini has to say
Fej
01 z06~Eclipse 8053~PPI dcx-730~Genesis Profile P5~Focal Polykevlar 7"~DLS Iridium 3" dome~a/d/s ps5.2~LPG 25nfa~IDQ 12" d4~Forever in tuning mode
05 Silverado Ext Cab~Eclipse 8053~Alpine PDX 4.150~Pioneer 720prs Mid / Seas Neo Aluminum ~Alpine PDX 1.600~JL 8w7~Installed and tuning
Team SQ Speaker Wire
Friends don't let friends have rear fill
fej is offline   Reply With Quote Quick reply to this message
Old 12-03-2006   #5
MiniVanMan's Avatar
Rep Power: 197 MiniVanMan has a spectacular aura aboutMiniVanMan has a spectacular aura aboutMiniVanMan has a spectacular aura aboutMiniVanMan has a spectacular aura aboutMiniVanMan has a spectacular aura aboutMiniVanMan has a spectacular aura aboutMiniVanMan has a spectacular aura aboutMiniVanMan has a spectacular aura aboutMiniVanMan has a spectacular aura aboutMiniVanMan has a spectacular aura about
I'm going to use a couple of examples, and some response graphs to help you understand this.
I'll start with the Peerless Exclusive 7". Scroll to the bottom of the PDF where the response chart is.
http://www.madisound.com/pdf/peerless/830883.pdf
You'll notice the "blue", "red" and "green" response graphs. Labeled at the bottom you'll see "On Axis", "30 Degrees", "60 Degrees" respectively.
Looking at the graph you can see that the upper end response of the driver lowers dramatically the further off axis you play them at. Now if your driver side door sits 60 degrees off-axis of your listening position (which most doors fall in that area) then you can get a good idea of what the upper end response will be. In this case the graph shows about 1750 hz before it starts to collapse, and is probably useable up to about 2200 hz.
Your passenger side driver will yield a considerably higher response due to it be much closer to on-axis than the driver side, so you might start to hear some bias from the passenger side should you try to run the set up to 3500 hz.
Now let's look at the Vifa MG 4" midrange
http://www.madisound.com/pdf/vifa/mg10md09-04e.pdf
Here you'll notice that on-axis response is great. Near 15k flat, with extension up to 20k. Npdang tested this driver and mentioned that it can almost be used without a tweeter. By the response graph we can see that.
However, now let's say we're building some kick pods, and due to some reason, we can't get them completely on-axis, but rather 30 degrees off-axis is the best we can do. You'll see that the 30 degree off-axis response graph basically tells us we can use these midranges up to about 5k before any real degradation of response. Pretty nice.
Now, for low end response. For tweeters, the general rule of thumb is twice the Fs (Resonant Frequency) at 12 db. A higher slope (i.e. 18 or 24 db) can get you closer to the Fs, but we'll use 12 db for now.
Let's first look at the most common tweeter on this board... The LPG
http://www.madisound.com/pdf/lpg.pdf
The Fs of this tweeter is 1850 hz. Doubled that is 3700 hz. Now, try coupling that with a 7" driver mounted in a door 60 degrees off-axis, and you have quite a gap between 2000-3700 hz. Almost a full octave. Now to be fair, let's look at the upper end extension. The on-axis, 30 and 60 deg graphs look almost flat up to 20k. Very nice. These can be mounted in some sail panels firing horizontally across your front stage and you can get great results from them.
Next is the Seas Neo tweeter.
http://www.madisound.com/pdf/seas/h1396.pdf
Here is a tweeter with a much lower Fs. 1170 hz, using our rule, can be crossed at 2340 hz. The specs say 2500, so we're pretty close. With a 24 db slope you could get 2200 hz out of them. These would be much better to mate with a set of Exclusives mounted 60 degrees off-axis. However, their top end is nowhere near that of the LPGs. You can definitely see that these would lack the top end "sparkle" that so many people refer to when talking about the LPG's. These will be much more neutral and laid back on the top end. Not a bad thing, as a lot of music doesn't go any higher than 15k. You will also notice a huge difference between on and off-axis. A major consideration when considering how to mount them.
These are just some suggestions on how to "guess" at appropriate crossover points. The graphs give you a good idea of how to tell how a driver will perform in a given installation. These graphs in no way indicate how a driver will sound, nor how they will perform at the upper and lower limits of their capabilities.
I hope this helps you, and hopefully, many others out there. I know it's rather lengthy.
MiniVanMan is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to MiniVanMan For This Useful Post:
Alain93 (05-08-2017)
Old 12-03-2006   #6
Rep Power: 358 azngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond reputeazngotskills has a reputation beyond repute
Thank man...very help guy ^^^
azngotskills is offline   Reply With Quote Quick reply to this message
Old 12-03-2006   #7
evan's Avatar
Rep Power: 159 evan will become famous soon enoughevan will become famous soon enoughevan will become famous soon enoughevan will become famous soon enoughevan will become famous soon enoughevan will become famous soon enough
Boooo! I read what you'd posted earlier and I found it to be really helpful.... unless it was wrong ...and then it's ok that you deleted it.... But I don't think it was.
evan is offline   Reply With Quote Quick reply to this message
Old 12-03-2006   #8
Rep Power: 169 thadman will become famous soon enoughthadman will become famous soon enoughthadman will become famous soon enoughthadman will become famous soon enoughthadman will become famous soon enoughthadman will become famous soon enough
If you want to determine the ideal LPF for a given midrange driver, observing the manufacturers (or npdangs, zaphaudios, etc) frequency response will give you loads of help. The driver must maintain a flat response 2 octaves above the crossover frequency.
For example, the Seas Excel W18E. It has a nasty breakup at 4800hz, the 2nd harmonic of this breakup is at 2400hz and the 3rd harmonic is at 1600hz. You will DEFINITELY want to avoid the 3rd harmonic of this breakup, and cross below that point (1600hz)
As a generalization (there are exceptions to this rule)
Metal cones are usually the best transducers (most pistonic, some people prefer more distortion ex. tubes) up until around 1-1.5khz (I wouldnt recommend taking a metal driver past 2khz), where they excite harmonics of nasty breakups
Paper cones breakup more easily, but the magnitude of the breakup is often quite minimal compared to metal cones and is easily tolerated. They can often be crossed much higher.
Also, you can get an idea of how a driver will perform off-axis with a little math by determining the diameter of the diaphragm.
For example, the Seas Excel W18E. It has a surface area of 126cm^2, A=Pi(r)^2. The diaphragm is ~4.99" across. The speed of sound is 13,397in/s, so divide the speed of sound by the diameter of the diaphragm and you get 2685hz. Above this point, the wavelengths the speaker will be producing will be shorter than the diaphragm and as a result, the driver will begin to beam. You will not want to use this driver off-axis, above this point
thadman is offline   Reply With Quote Quick reply to this message
Old 12-04-2006   #9
Thanks Guys!!! This does help and it does make sense.. I am still doing my homework on this.. front stage is last on my list, It has been a bit cold here to play around in the garage and try things..
Old 12-04-2006   #10
fej
Haha thanks Evan ... wasn't wrong I don't think, but the explanation mini gave was far more thorough. Mine was more sort of 6th grade style lol. Maybe I will motivate and repost heh.
Fej
Old 12-04-2006   #11
MiniVanMan's Avatar
Cold?? What do you mean cold. Wuss!! Get out there and tear those doors apart damnit. That's what earmuffs are for
I feel ya, it's been brutal here over the weekend.
Old 12-04-2006   #12
Rep Power: 166 02bluesuperroo will become famous soon enough02bluesuperroo will become famous soon enough02bluesuperroo will become famous soon enough02bluesuperroo will become famous soon enough02bluesuperroo will become famous soon enough02bluesuperroo will become famous soon enough
Great explanation MiniVan. I have one additional questions. When you refer to a driver being able to play to "x" frequency, does this mean it can be crossed over at that point or must be done rolling off by that point?
02bluesuperroo is offline   Reply With Quote Quick reply to this message
Old 12-04-2006   #13
LOL, Normally I would be, but I fighting a cold (sinuses), lost my voice on friday and have a bit of a sore throat since Sat. night.
I also think I am going to sell one of my eD amps, and get either an a/d/s PQ10 or PH15.. to help with the space issue.
Old 12-04-2006   #14
MiniVanMan's Avatar
Jeff, check out Memphis as well. They make a really nice small profile amp in their M-Class series. Great sound quality as well.
For Bluesuperroo, your question can be simply answered as crossed over at that point. However, it's a great lead in into different crossover types and how they're used. It'll be quite in depth so I'll probably post tomorrow a more detailed answer.
Old 12-05-2006   #15
Excellent, can't wait.
Old 12-05-2006   #16
solacedagony's Avatar
Rep Power: 173 solacedagony will become famous soon enoughsolacedagony will become famous soon enoughsolacedagony will become famous soon enoughsolacedagony will become famous soon enoughsolacedagony will become famous soon enoughsolacedagony will become famous soon enough
Send a message via ICQ to solacedagony Send a message via AIM to solacedagony Send a message via MSN to solacedagony
www.passivecrossovers.com for some basics on... passive crossovers!
A lot of it applies to crossovers in general, but they do have the specifics on setting up a passive crossover (caps, coils, resistors, etc).
solacedagony is offline   Reply With Quote Quick reply to this message
Old 06-21-2007   #17
Rep Power: 158 hyun will become famous soon enoughhyun will become famous soon enoughhyun will become famous soon enoughhyun will become famous soon enoughhyun will become famous soon enoughhyun will become famous soon enough
i don't understand what happens when you play a driver too close to, or at, the Fs resonant frequency. would the ill-effect be easy overexcursion?
e.g. for a 7" midbass with an Fs of, say, 45hz. What happens when you play it near the Fs, at 70, 60, 50 and even 40hz? the impedance rises at the Fs - does that mean the current flow through the speaker is reduced at the Fs? and therefore (as also illustrated in the freq response graph) its output drops at the Fs due to lower current flow?
Fs, being the resonant frequency, would that be equivalent to saying - the speaker's natural resonance is at this Fs - therefore, the little current that it receives at the Fs causes a lot of excursion, which can lead to damage? if that is the case, why does the measured output drop, when there's supposed to be overexcursion? won't there be higher and higher output until the speaker is destroyed?
finally, what is causing this rise in electrical impedance? what happens to the voice coil around that Fs, that causes the impedance to peak, which doesn't happen at other playable frequencies?
thanks! ... trying to understand more of the physics behind all this.
hyun is offline   Reply With Quote Quick reply to this message
Old 06-21-2007   #18
99IntegraGS's Avatar
Rep Power: 155 99IntegraGS will become famous soon enough99IntegraGS will become famous soon enough99IntegraGS will become famous soon enough99IntegraGS will become famous soon enough99IntegraGS will become famous soon enough99IntegraGS will become famous soon enough
Send a message via ICQ to 99IntegraGS Send a message via AIM to 99IntegraGS
Originally Posted by fej View Post
... the explanation mini gave was far more thorough. Mine was more sort of 6th grade style lol. Maybe I will motivate and repost heh.
Please repost... I'm thinkin' I need the Fer Dummies version of Mini's post.
JD
99IntegraGS is offline   Reply With Quote Quick reply to this message
Old 06-21-2007   #19
Rep Power: 153 thazy2 will become famous soon enoughthazy2 will become famous soon enoughthazy2 will become famous soon enoughthazy2 will become famous soon enoughthazy2 will become famous soon enoughthazy2 will become famous soon enough
I was woundering the same thing...........
SUPER explaination! The pics/graphs really helped me out.
thanks..........guys..............
89 Honda CRX Si "Add salt to make it sweeter" http://www.thezcr.com/gallery/member...=680&protype=1
thazy2 is offline   Reply With Quote Quick reply to this message
Old 06-21-2007   #20
Rep Power: 167 ghart999 will become famous soon enoughghart999 will become famous soon enoughghart999 will become famous soon enoughghart999 will become famous soon enoughghart999 will become famous soon enoughghart999 will become famous soon enough
That is one of the best posts I have ever read.
HU - Alpine IDA-X100, Comps - Seas W18NX and LCY 110 Ribbons, Subs - (2) RL-P 12's, Amps - Arc xxk4150 and xxk2050 and Sundown SAZ-1500D
ghart999 is offline   Reply With Quote Quick reply to this message
Old 06-21-2007   #21
Kuztimrodder's Avatar
Rep Power: 159 Kuztimrodder will become famous soon enoughKuztimrodder will become famous soon enoughKuztimrodder will become famous soon enoughKuztimrodder will become famous soon enoughKuztimrodder will become famous soon enoughKuztimrodder will become famous soon enough
Some of us understand 6th grade style betterer
Tis true though, MiniVanMan is the man...man!
'88 GMC Sierra: Alpine CDA-9813~Kenwood KAC728~PG Ryval V754~Dayton RS225~SEAS ER18RNX~Dayton RS28
Kuztimrodder is offline   Reply With Quote Quick reply to this message
Old 06-21-2007   #22
MiniVanMan's Avatar
Different drivers will behave differently near or at their Fs.
The most common effect is an increase in distortion. Fs is actually a point at which the speaker itself starts to vibrate. It can overemphasize the frequency due to the vibration, but it will be realized as distortion.
Another common effect is the changing of crossover points due to the rise in impendance. As your impedance rises, the crossover point lowers. This can result in a flattening of your response throughout the attenuated range of the crossover.
Let me see if I can explain that a bit better.
You're running a 4 ohm tweeter at 100 db. The Fs of the tweeter is 1000 hz. You decide that a 12 db crossover at 2000 hz is what you want to use. It's double the Fs, so it should be good, right?? Well, let's say the impedance starts to rise at 2000 hz, and the impedance reaches 8 ohms at 1500 hz, and tops out at 16 ohms at resonance, 1000 hz. As your impedance is rising the crossover point is lowering. For every doubling of impedance your crossover point cuts in half. So their kind of working against each other. In layman terms you're not realizing a true 12 db drop by 1000 hz.
God!! I'm trying to figure out a way to illustrate this. Suffice to say, that's highpassing is best left for very steep slopes to realize and real gains in cutoff, when approaching the Fs.
This is why enclosures are very desireable for controlling a low end on a speaker. They naturally cut of the frequencies mechanically as opposed to electrically. They're not as affected by the impedance spike at resonance, if at all.
This is a yucky explanation, but barring a much more technical explanation, where I'll have to cut and paste the same stuff you can google, this will have to do.
Old 06-21-2007   #23
I was wondering about this in regards to the Seas Excel W18NX which is very popular here on the forum. It's Fr graph is shown below.
http://www.madisound.com/catalog/PDF/seas/e0042.pdf
According to the graph the 60-degree slope takes a huge dump at 2200Hz and then recovers again at 4200Hz. Should one not play the driver past 2200Hz and LP it at around the 2200Hz? I know that some people, myself included, run this driver with no LP at all. When would it be bad to do this?
Thanks.
Old 06-21-2007   #24
MiniVanMan's Avatar
Thanks.
I wouldn't run it with no LP. That peak at 4.2k is breakup, and just plain nastiness. Sure being the W18, it's probably better sounding nastiness than say the Dayton RS180, but it's still nastiness.
Old 06-21-2007   #25
So would you LP at 4000Hz? Play with different slopes?
I am still building my system and will be putting in LCY 110 ribbons. But for right now I have just the W18NXs playing with no HP and I don't really hear breakup. But my ear in not very well trained.
A Basic Guide to Crossovers MiniVanMan How-To Articles Provided by our members 95 10-28-2014 01:35 PM
Best crossover points for tonality Fellippe Technical & Advanced Car Audio Discussion 4 11-29-2006 03:30 AM
Crossover points: overlap, underlap, gaps? FoxPro5 Technical & Advanced Car Audio Discussion 29 03-15-2006 10:45 PM
Passive crossover point woes and low crossover point small dome GRexer Technical & Advanced Car Audio Discussion 1 11-24-2005 06:18 PM
vertical bi ampily with passives crossover? silverX Technical & Advanced Car Audio Discussion 4 06-08-2005 10:19 PM
