JBL's MS-8 processor! - Page 500 - Car Audio | DiyMobileAudio.com | Car Stereo Forum
Old 06-25-2019   #12476
FordEscape's Avatar
Rep Power: 78 FordEscape is a glorious beacon of lightFordEscape is a glorious beacon of lightFordEscape is a glorious beacon of lightFordEscape is a glorious beacon of lightFordEscape is a glorious beacon of lightFordEscape is a glorious beacon of lightFordEscape is a glorious beacon of lightFordEscape is a glorious beacon of lightFordEscape is a glorious beacon of lightFordEscape is a glorious beacon of lightFordEscape is a glorious beacon of light
Default Re: JBL's MS-8 processor! ABRIDGED
Originally Posted by Tweaked View Post
Hello FordEscape, I only just found this post of yours. Unfortunately, the links for both the PDF of "Andy's Wisdom" and the link to download the manual and CD, are invalid. Can you please relink them? I would be most grateful.
Please see my revised sig-block for links
FordEscape is online now   Reply With Quote Quick reply to this message
The Following User Says Thank You to FordEscape For This Useful Post:
billqs (06-25-2019)
Old 06-25-2019   #12477
Rep Power: 104 billqs will become famous soon enoughbillqs will become famous soon enoughbillqs will become famous soon enoughbillqs will become famous soon enoughbillqs will become famous soon enoughbillqs will become famous soon enough
Much better answer supplied above so I removed my message.
billqs is offline   Reply With Quote Quick reply to this message
Old 06-28-2019   #12478
Rep Power: 114 KillerBox will become famous soon enoughKillerBox will become famous soon enoughKillerBox will become famous soon enoughKillerBox will become famous soon enoughKillerBox will become famous soon enoughKillerBox will become famous soon enough
I have a theory about the lack of midbass on the MS8 calibration & would like to ask anyone that has ever experience it,
if you were using a center channel speaker or not?
KillerBox is offline   Reply With Quote Quick reply to this message
Old 07-01-2019   #12479
Rep Power: 53 Tweaked will become famous soon enoughTweaked will become famous soon enoughTweaked will become famous soon enoughTweaked will become famous soon enoughTweaked will become famous soon enoughTweaked will become famous soon enough
I do not run a center channel. Just a bi-amped two way front stage with rears powered by the MS-8. I had to do a lot of equalization to get midbass. My doors are treated with Stinger Roadkill, and I installed the Stinger FAST Rings. It took a lot of EQ, but I was able to get decent midbass, and a reasonably flat response in my car. Additionally, I was finally able to get a good center image. I had to reduce the gain on my subs. I read where Andy recommended running the sweeps around 85db. So I used my DB meter during the sweeps and noticed that although my mids and highs were around 79db, my sub was peaking around 103. It didn't sound all that loud to me, but according to Andy, that will clip the calibration mic and screw up the TA giving you a smeared center image.
Tweaked is offline   Reply With Quote Quick reply to this message
The Following User Says Thank You to Tweaked For This Useful Post:
billqs (07-01-2019)
Old 07-14-2019   #12480
Success!!!!
After one last brain fart, wherein I put the output RCAs into the inputs, I got it all sorted out input/output set up, 4 positions calibrated and it sounds really great!
Of course, I've got some tweaking to do. Sub level was very high and even after bringing it down most bass sounds like it comes from the sub. I crossed over at 100, I'm now thinking it should be 80 or 85.
Old 3 Weeks Ago   #12481
justin30513's Avatar
Rep Power: 0 justin30513 will become famous soon enoughjustin30513 will become famous soon enoughjustin30513 will become famous soon enoughjustin30513 will become famous soon enoughjustin30513 will become famous soon enoughjustin30513 will become famous soon enough
I need remotes!
Please 2 is what need.
Thank you!
Sent from my SAMSUNG-SM-G891A using Tapatalk
justin30513 is offline   Reply With Quote Quick reply to this message
Old 3 Weeks Ago   #12482
Rep Power: 26 Kocil will become famous soon enoughKocil will become famous soon enoughKocil will become famous soon enoughKocil will become famous soon enoughKocil will become famous soon enoughKocil will become famous soon enough
Dear all.
I just installed a new (but old of course) JBL MS8, but found situation
as follow:
- The car ground was not connected to the battery
- The MS8's remote IN was not connected
- Power (+) and (-) were connected
- The display cable was connected
then when I connected the car ground again,
the MS8's blue LED was illuminated forever, until the GND is disconnected.
But when the display cable was disconnected,
and the GND was connected again,
the blue ligh illuminated for a short while, then went off.
Is it normal ?
Any cure, or should I return the product ?
Kocil is offline   Reply With Quote Quick reply to this message
Old 3 Weeks Ago   #12483
Rep Power: 66 drop1 will become famous soon enoughdrop1 will become famous soon enoughdrop1 will become famous soon enoughdrop1 will become famous soon enoughdrop1 will become famous soon enoughdrop1 will become famous soon enough
I cant help you, I just find it amazing that this thread is still going.
drop1 is offline   Reply With Quote Quick reply to this message
Old 2 Weeks Ago   #12484
Rep Power: 0 ricanmeng will become famous soon enoughricanmeng will become famous soon enoughricanmeng will become famous soon enoughricanmeng will become famous soon enoughricanmeng will become famous soon enoughricanmeng will become famous soon enough
I just got my 2019 Nissan Altima SR non-Bose system installed and am having some strange distortion on 3/4 volume and a tough time tuning. If I do tuning myself with processing defeated it sounds better overall tonally but lack the time alignment, at that point it is just crossovers and EQ. See my setup below and recommend my next course of action. Be it active 2 way in the front using my existing speakers, 3 way with a midrange from the same series, make a center using an aftermarket enclosure and 6.5" coaxial, change DSP, or settle with what I have gotten. I have tried the measurements several times with level matching and various volumes but still am getting the same issues. Tweeters in factory dash locations, woofers in the front door, 6x9's in rear deck. Sub in the trunk facing outward.
My System:
JBL GX608C 2 way 6.5" Component - Passively crossed over fed from Channels 1&2 of Kenwood Excelon X301.4
JBL GX 3 way 6x9 Coaxials - Channels 3&4 of Kenwood Excelon X301.4
Diamond Audio 12" Sub inside of OBcon Godzilla Slotted Enclosure. Single Channel of Kenwood Excelon X500.1
ricanmeng is offline   Reply With Quote Quick reply to this message
Old 2 Weeks Ago   #12485
FordEscape's Avatar
Exclamation STILL Uniquely Capable
What's amazing (impressive) is that Andy, his team, and JBL managed to bring a product to the market that now a decade later is still uniquely capable and competitive in the market.
We're fortunate that in addition to the unique features, they managed to produce an item that's proven reasonably robust. It's still quite possible to find units that haven't been abused, haven't had critical components lost, and have every reasonable expectation of delivering great SQ for a long time to come, all at a very good price on the used market.
You can find items that touch some of the bases, but still nothing that covers all of the bases the MS8 does. Nope, it's not for everyone, never was, but there's still nothing else that touches it in the niche it was designed to fill. And that niche still exists.
IMO
The Following 2 Users Say Thank You to FordEscape For This Useful Post:
KillerBox (2 Weeks Ago), oldschoolpunk13 (2 Weeks Ago)
Old 2 Weeks Ago   #12486
Default Re: STILL Uniquely Capable
IMO
I agree and I have got a boatload of them in an air condition closet for spares until something else better comes along.
Old 2 Weeks Ago   #12487
My System:
My suggestion is to get what you have working properly first and then add to it. To make it easy, I would cross your front JBLs @ 80hz and your rear JBLs @ 100hz - all at a 24db slope.
Your subsonic filter needs to be set according to your tuning frequency of your box and subs. (You don't want any speaker trying to play a frequency it is not capable of playing)
I would then find the maximum volume on your Nissan radio by turning it up until you see ok, ok, ok on the MS-8. This is around the maximum you need to turn up the Nissan radio.
Then run the MS-8 auto-tune with your amplifier gains at minimum and (rough guessing around -35) on the MS-8.
After the auto-tune, turn the MS-8 up to -6 on its volume. Then with a Zero Bit track MS-8 volume @ -6 and the predetermined maximum volume on the Nissan radio, turn up your front amplifier gain until you start to hear a hiss from your tweeters and then turn it back down a little bit. This is your maximum undistorted volume level for the Nissan, amplifier and MS-8.
Turn volume back down and set the other amplifier gains the similar amount of gain. Then play a track that you are familiar with to make sure your speakers are NOT being overpowered and everything blends together.
P.S. Save yourself a lot of time, by downloading a free speaker pop program for your phone and verify that each midrange speaker is in positive polarity (by disconnecting all other speakers other than the one you are verifying) before doing the MS-8. (The tweeters may in negative polarity depending on your passive crossovers.) The subwoofer also may be in negative polarity depending on what sounds the best in your system. So you I would try the subwoofer both polarities and rerun the calibration each time.
Also, the MS-8 does a better job if you can disconnect or cover the tweeters for the first step in each seating position. This makes the time alignment work off the midrange location instead of the tweeter's location.
Old 2 Weeks Ago   #12488
Thank you Killer Box,
I have already tried all of those items you listed after exhaustively reading the thread. I had the MS-8 connected in my Ford flex previously with the same amps and subs, but Kicker CS speakers and a center. It sounded great. I am just worried about pissing money down the hole for negligible returns after I already spend a good chunk dampening this car and getting it installed professionally (vs my rinky electrical tape work and velcro). My next step is to do the front 2 way active, but then I would end up running all the cabin speakers off of the MS-8 amps so I don't have to worry about level matching for them and gain structure.
Old 2 Weeks Ago   #12489
The main issue I have with the MS-8 processing being active in this car is the sound being hollow and distortion of certain frequencies at normal listening levels (80% of my volume on the HU).
Tags
kill it with fire
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
PPI DCX-730 Digital Signal Processor crash813 Member Reviews & Product Comparisons 432 12-10-2017 08:17 PM
Processor Power PPI DCX 730 vs Alpine PXA H701 ... netken Technical & Advanced Car Audio Discussion 8 01-24-2011 11:07 PM
Processor selection Sr SQ Technical & Advanced Car Audio Discussion 13 01-04-2007 02:51 PM
stand alown processor of time alignment KingSVT Technical & Advanced Car Audio Discussion 9 10-19-2006 09:04 AM
My MaxxBass 103 Processor Impressions blackreplica Technical & Advanced Car Audio Discussion 17 09-29-2005 07:14 AM
