1 - 20 of 101 Posts
2005 mustang, v6
Well, its about that time when i'll be making REAL headway on my install so i figure i'll do my build log.
Gear so far:
JVC KW-350BT
db audio pro6k (components)
Kicker KS693 (6x9)
Diamond Audio TDX10D4 (wired at 2ohm)
Soundstream RN4.1400D
Kenwood Excelon XR600-1
db link 10ga OFC speaker wire
Font Gas Signage Advertising Brand
Black Font Art Pattern Automotive tire
Fedora Hat Wood Dishware Audio equipment
Automotive tire Automotive lighting Camera lens Gas Wrist
Hand Camera lens Cameras & optics Camera accessory Gadget
Automotive tire Finger Gauge Measuring instrument Wrist
Wheel Automotive tire Motor vehicle Automotive lighting Alloy wheel
Automotive tire Gas Rim Font Automotive wheel system
2005 mustang, v6
Discussion Starter · #2 ·
Reactions: JohnL2001
2005 mustang, v6
Rear dash.
3/4" pine plywood for 5x7-to-6x9 adapter ring
Vehicle Automotive tire Automotive lighting Hood Car
Automotive lighting Hood Eyewear Automotive tire Automotive design
Hood Automotive lighting Automotive design Motor vehicle Automotive exterior
Tire Automotive tire Automotive lighting Vehicle Hood
Cameras & optics Tints and shades Personal protective equipment Auto part Service
Automotive tire Motor vehicle Wheel Alloy wheel Rim
2005 mustang, v6
OEM plugs to Kickers
Wood Pliers Handheld power drill Gas Saw
Door speakers: 5x7-to-6.5" adapter rings. OEM connectors, quick-disconnect pigtails in prep to run full wiring through OEM door boot
Edit: 1/2" pine for these
Wood Beige Road surface Floor Flooring
Tool Wood Gas Font Wire
Automotive tire Hood Motor vehicle Automotive design Automotive lighting
Automotive lighting Automotive tire Hood Motor vehicle Vehicle
2005 mustang, v6
2005 mustang, v6
Internal bracing, wiring, 2nd baffle for sub box and sub installed
Wood Floor Flooring Composite material Door
Road surface Asphalt Floor Public space Flooring
Wood Floor Flooring Hardwood Beige
Comfort Wood Flooring Floor Hardwood
Wood Gas Circle Plywood Road surface
Wood Rectangle Natural material Circle Triangle
Wood Door Gas Automotive wheel system Circle
Hand Wood Finger Art Nail
Eyewear Wood Bumper Gas Twig
Automotive tire Wood Cookware and bakeware Gas Automotive wheel system
2005 mustang, v6
Discussion Starter · #7 ·
2005 mustang, v6
Discussion Starter · #8 ·
Air vent tweeters
Removed this length of duct. Still looking for a cap that'll fit it.
Carbon Auto part Metal Wood Automotive exterior
Electrical wiring Gas Automotive tire Engineering Cable
3" PVC coupler and rubber pipe cap
Automotive tire Bumper Rim Gas Automotive wheel system
Automotive tire Aluminum can Tin can Gas Tin
Hood Automotive tire Motor vehicle Bumper Automotive exterior
Automotive design Automotive tire Motor vehicle Gadget Automotive lighting
2005 mustang, v6
Discussion Starter · #9 ·
Sounds better on atleast computer speakers
Reactions: LowBassSubs
2005 mustang, v6
Discussion Starter · #10 ·
Update: yep, the sony mch-gx355 is dead. Plays but skips all over the cd tracks and there's no amp for the line-in port.....
Now accepting donations for a new bench amp that is rated for atleast 4ohm and not stuck at 8ohm 🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣
2005 mustang, v6
Discussion Starter · #11 ·
Template fitting time
Wood Rectangle Ruler Beige Font
Wood Road surface Asphalt Font Gas
Wood Comfort Automotive exterior Tints and shades Flooring
Hood Vehicle Motor vehicle Car Steering wheel
Vehicle Motor vehicle Automotive tire Automotive design Tire
2005 mustang, v6
Discussion Starter · #12 ·
Automotive design Automotive exterior Bumper Vehicle door Wood
Motor vehicle Hood Automotive design Automotive exterior Gas
Wood Tints and shades Flooring Shade Stairs
Blue Automotive lighting Hood Automotive tire Motor vehicle
Wood Bumper Automotive exterior Hardwood Tints and shades
2005 mustang, v6
Discussion Starter · #13 ·
Got a little somethin-somethin in the mail today
Tire Automotive tire Azure Tread Synthetic rubber
2005 mustang, v6
Discussion Starter · #14 · (Edited)
Positive distribution block for amp wall
Wood Art Metal Auto part Artifact
Fitting pos and neg ends. The 2 small brass ports on the left of the terminal block are for the alternator and starter wires
Wood Bicycle part Gas Hardwood Rim
Automotive tire Gas Auto part Asphalt Motor vehicle
Blue Electrical wiring Cable Gas Rope
Blue Automotive tire Electrical wiring Rope Auto part
2005 mustang, v6
Discussion Starter · #15 ·
Finished the positive distro block.
Wood Fastener Gas Household hardware Audio equipment
Opinions: black oxide allen bolts or stainless bolts?
Wood Auto part Metal Ammunition Audio equipment
2005 mustang, v6
Discussion Starter · #17 ·
It seems not alot of people with mustangs put sounds in their cars, most people are more performance oriented.
2005 mustang, v6
Discussion Starter · #18 ·
Tweeter amp is here! Thanks to @OldOneEye for the sale. Gonna use one of the three and save the others for another build.
Black Wood Comfort Floor Flooring
White Sleeve Rectangle Grey Hood
2005 mustang, v6
Discussion Starter · #19 ·
Setting up wiring for starter and car's underhood fuse block. Gonna run 2ga (so more waiting simce i don't have any) for the starter since i can't find definitively whether the 4.0 (245cu in) v6 uses 2ga or 4ga starter wire.
Networking cables Gas Electronic engineering Electrical wiring Electronic component
1 - 20 of 101 Posts
