Good morning,
I'm looking for suggestions for a high end, single din radio for an 2007 Ferrari F430.
Needs to have integral bluetooth. I don't really want to put a mic in the cabin, but I'll do what has to be done.
Needs to be easy to read / operate
Needs to not look like a Dekotora
I do not want a flip out screen.
If I didn't need to have BT I would use a Denon for sure. I had my eye on the Continental radios, but they seem like availability might be an issue. Anyone got any ideas? Thanks in advance!
I don't know if the Pioneer P99 has the integral bluetooth (personally, I don't know of any that do not at least need an external microphone), but that's where I would start looking. You would also need the CD-BTB200 for Bluetooth, which may be a deal breaker. It also requires external amplifiers, so may not work in your situation.
Then maybe the Sony GS9, but I think the Pioneer would look better in the F430 dash, from talking to people as well the Sony can be a headache to navigate with, it also needs external amplifier(s).
Thanks! The GS9 was a consideration, but the screen is too small.
I'll put the P99 on my list, although I'm not sure about adding an amplifier to this car. It only has 600 miles on it and I don't want to do anything that can't be reversed.
How about the Alpine CDE-H1498BT or Kenwood Excelon KDC-X998? Not quite as high end as the P99, but they look to be decent units, easy to read screens, built in bluetooth, no need for external amplification.
The unfortunate thing is all modern, full featured, decks are cheesy looking/feeling.
I'm helping a friend put together a system for a classic car and he ended up picking a KDC-X702. He wanted CD, radio and bluetooth. Only other way to accomplish that is doing an old premium head unit and a DSP with bluetooth.
I'm not sure that you need a "High End" head unit if you aren't also going to upgrade the speakers and install
an amplifier or two to drive them properly?
I also think that the classic Sony ES CDX-C910 would look great in the dash, but they're old, don't have BT,
have a horrible display (dim & hard to read in sunlight), and you'd need external amplifiers as well.
Most of the above would apply to nearly all of the classic "high end" head units.
You could add a tiny "micro amp" to almost any of the head units that you choose, and it wouldn't require
any extensive wiring or major modification.
Something like the Mosconi Pico 2 amplifier
or one of the Alpine, Clarion, or Kenwood micro amps, etc.
None of the Single-DIN head units out there (at least that I've seen) have a really good display that's easily
view-able with top-down driving in full sun.
Do you really need it to Play CDs???
I'm fairly certain that you have a smartphone? If so, maybe the new Pioneer SPH-10BT
Watch the Video on the Crutchfield page.
You can fully customize the front panel lighting, and Pioneer will be selling Parking Sensors that integrate
with both the HU Display and SmartPhone Display (could be useful with that car).
And nearly every aftermarket HU with BT for Hands-Free Calls will require you to add an external microphone.
If your OEM stereo has BT Calling and there is already a microphone installed in the cockpit for it (doubt it), you can
tap into the existing OEM microphone via the OEM wiring harness/plug and connect it to your new
aftermarket stereo. I've done this with 3 of my own vehicles and it has worked flawlessly
with the aftermarket HU.
If not, installing the aftermarket BT mic is usually fairly simple and you can nearly always find a good,
inconspicuous location for it.
I would also really consider the Pioneer DEX-P99RS, but as mentioned, for BT you would need to
add the separate CD-BTB200 adapter.
I use aptx Bluetooth adapters. The phone calls come through the speakers and your phone mic (assuming it's a modern smart phone) is more than capable of hearing you with the windows down.
I don't think that the OP already owns the Denon HU?
But I do this in one of my vehicles as well with the Arcam rBlink (now discontinued), but I don't think
the OP's OEM HU has an AUX input or an amplifier to connect the output of the BT Receiver to, and it
looks like he isn't and doesn't want to add amplifier(s). So he would still have to install an
aftermarket single-DIN HU with an AUX Input or one of the micro-amplifiers at minimum.
I think that one or two members here might still have a Black Faceplate Denon DCT-x Head Unit which
would look great in the dash, and some of these have a rear RCA AUX input, but would require an
outboard amplifier of some sort.
I'm not sure that you need a "High End" head unit if you aren't also going to upgrade the speakers and install an amplifier or two to drive them properly?
In this instance I think I'm looking for "high end" in appearance
A microamp might be doable if it comes to that
I don't
I weep for humanity
I'm slowly coming to terms with this
I do own a silver DCT-R1, but this isn't my car
There are a couple black face units on ebay right now
As someone else stated not sure a high end single din radio would be much of a benefit for you. If you are just wanting the looks.... visit the different radio manifacturers (Alpine, JVC, Kenwood, Sony, Pioneer) and see what you like. I am also a Hugh Denon car audio fan, loved their stuff back in the day.....
If you do go that route or get another radio and decide you need more power there are numerous small, light and good sounding small amps that can easily be added and also removed when the day comes to move on. Many are so small/light that they do not need to be screed into the car, zip ties etc can mount the amps somewhere.
If possible, I would suggest visiting your local car audio stores to see what they have, some looks great on the companies website and are horrible to use.
System Design: Help Me Choose Equipment For My Car
Looking for a recommendation for the best amp to run 2 American Bass XFL 12". I've been looking at the following:
Skar Audio RP-2000.1D
Or
American Bass XFL DC-2000
Or are there better options?
Looking to ditch my Pyle 6.5 components and get something new. Running a Kenwood xr400-4 excleon to My ds-18 TW120B and my Pyles. Ds18 are crossed over at 5,000 Butterworth, and my plyes are bandpassed at 80(Bessel) and 5000(Butterworth). My sub jl hi wedge which is upfiring as is passed at 80...
Looking into picking up some RCA cables and came across AudioQuest - Evergreen cables, for $20 less there is the AudioQuest - Tower
sort of pricy and I need three. The AudioQuest - Evergreen cables are 70.00 X 3 = $210.00 ouch.
Searching the forum, it seems to be that some people are making...
Hello, I'd like to upgrade the basic multimedia system i have.
*what do i need ?
1. Car stereo receiver (for example : pioneer avh-2400NEX - android auto is important)
2. Two front speakers (4 inch), instead of the basic default speakers that come with the car
3. Bass : I need...
Two of the X5 subwoofer installs I have seen used either the JL 10TW3 or 12TW3 in order to fit them underneath the cover of the rear storage compartment. I’m not sure what size they used. One install used a single TW3 in a down firing configuration and the other used two TW3’s facing up.
Maybe...
