1 - 20 of 20 Posts
Tight work...
Very nice! What kind of volume did you get in those sub enclosures.
Another very nice install Steve.
Very clean installl.
Must likey the Acura brand.Really awesome work & definitely show worthy vehicle.You really given me the inspiration to redo my FG enclosure in my '11 Accord,cant wait for spring.
Any side shots of the car?
Good job!
Do you use some kind of DSP to convert signal from oem HU to the amps?
What is there for the front stage? Tell us more about the system structure.
Moderator
really nice Steve,
how many SLB-Us are you running to boost the super weak signal from the stock head to get enough to maintain a high enough output?
and that is a dsp6 in addition to the DC amps? U souther folks seem to like doing that :D
Discussion Starter #20
Well what I did was sent Matt R, the factory amp and had him use the input plug from it and add it to the new class a 6 chan. Line driver he made . It has the factory input plug so the radio plug , plugs right in to the new line driver mounted in the same spot where the amp was then there are simlink plugs on the outputs. It has 16volt bal. Outputs;) ,
1 - 20 of 20 Posts
