We are blowing out Blaupunkt THW1200 12" thin line subs for the month of March. They are only 2.44" deep and can be mounted just about anywhere. They come with grilles and mounting hardware. They are very good sounding subs and can be used in a variety of enclosure sizes.
They are $39.99 each while they last. Here is a link with info and purchase details:
BLAUPUNKT THW1200 12" SUBWOOFER
Please enter promotion code: diy12thw at checkout for the forum discount.
Here are some specs:
Power Handling: 600W max/200W RMS
Frequency Response: 20-200 Hz
Sensitivity: 90 dB (2.83V/1m) - 87 dB (1W/1m)
Impedance: 4 Ohms
Woofer Magnet: 40 oz. Barium Ferrite
Voice Coil Diameter: 2.0"
Spring Loaded Binding Post Connectors
Installation Depth: 62 mm or 2.44 inch
Installation hole diameter: 280 mm or 11.02"
Thiele-Small Parameters:
Resonance frequency: 25hz
Qts: .50
Qes: .54
Qms: 5.91
Vas: 4.0 cubic feet
Xmax: 10mm
Re: 3.67 ohms
BL: 13.2 tm
Sd: 547 cm^2
Cms: 258 uM/N
Mms: 167g
Sealed Enclosure: (cubic feet)
Vol. - f3 - SPL
___________________
0.5 - 55 - 87
0.75 - 50 - 87
1 - 48 - 87
1.5 - 46 - 87
2 - 45 - 87
Vented Enclosure:
Vol. - f3 - fb - SPL
___________________________
0.5 - 57 - 55 - 88
0.75 - 47 - 45 - 88
1 - 42 - 40 - 88
1.5 - 35 - 35 - 88
2 - 32 - 30 - 88
Impedance: 4 Ohms
Qts: .50
Qes: .54
Qms: 5.91
Vas: 4.0 cubic feet
Xmax: 10mm
Re: 3.67 ohms
BL: 13.2 tm
Sd: 547 cm^2
Cms: 258 uM/N
Mms: 167g
Vol. - f3 - SPL
___________________
0.5 - 55 - 87
0.75 - 50 - 87
1 - 48 - 87
1.5 - 46 - 87
2 - 45 - 87
Vented Enclosure:
0.5 - 57 - 55 - 88
0.75 - 47 - 45 - 88
1 - 42 - 40 - 88
1.5 - 35 - 35 - 88
2 - 32 - 30 - 88
