61 - 73 of 73 Posts
Discussion Starter #61
First pillar wrapped in vinyl. LOT of stretching to get this to work. The heat gun is your friend...
270399
Old pillar vs. new pillar:
270400
Passenger a-pillar installed:
270401
Driver's side a-pillar:
270402
Discussion Starter #62
Driver's side pillar from the driving position:
270403
My grill work turned out cleaner this time as well:
270404
270405
The new pillars are a noticeable step up in fit-and-finish from the first version, and the vinyl integrates into the interior much better than the grill cloth.
Impressive, professional level work. The pillars integrate very nicely.
Did you have to play with the tuning to compensate for the angle change?
Discussion Starter #66 (Edited)
Thanks for the compliments! Much appreciated.
Definitely needs re-tuning! I frankly was surprised at not only the amount of adjustment required, but the nature of the changes in frequency response. I've only had time enough to adjust the existing tune to smooth things out, but I'll probably do a full re-tune. I actually think the frequency response is smoother in the more off-axis aiming. I'll try to confirm that theory with some raw measurements this weekend.
Discussion Starter #69
OK, I stand corrected on this impression. Measurements showed almost identical pre-EQ frequency response between the previous a-pillars and the new ones (with exception of a 2.5khz spike on the left mid, which I attribute to reflection off the factory monitor "hump"). Really surprised at this considering the significant change in speaker angles. The first version had the speakers aimed directly between the front seats at head height, while the new ones are aimed at the center of each side window. Pretty interesting the off-axis response would be so similar. 🤷‍♂️
Wow, that vinyl work turned out great! I’m gonna do a little vinyl wrap on the front of a fiberglass sub box this weekend. Got my heat gun handy! Which adhesive did you use?
Discussion Starter #73
Thanks! I used DAP Weldwood Landau Top and Trim. Really indispensable for this type of upholstery work. The 2 game-changers for me on the vinyl upholstery were learning to be way more liberal with heating the material to achieve the necessary stretching, and buying a gravity-feed sprayer to apply the adhesive. 😊 (y)
61 - 73 of 73 Posts
