141 - 150 of 150 Posts
Discussion Starter #141
It was a hot one today... a local favorite of mine.
273562
So other than re-installing the passenger side door card, the two front seats and then finishing up the URC.3 (which is hooked up, but not mounted) and my DAP mount, it is physically complete.
I connected the battery, started the car (which hasn't be run since I started this project) and while sitting in a nice cooled backseat, I realized none of the amps were on. 😏 I turned the car off and began to investigate. I got the multi-meter out and started checking power connections. The amps were both getting good power and I ultimately realized the remote wire was not measuring battery voltage when the ignition was on, but I measured battery voltage from the damn thing when I ran my 9-wire and it was good to go. I'm sitting there scratching my head and for some odd reason I decide to probe the REM Output of the Helix. I get 12.5v on one and 0v on the other. Of course, I'm like "WTF?!". I then proceed to slap my forehead realizing that I hooked the REM input line to the REM output of the Helix and the REM output line that goes to the Pico to the REM Input (they were reverses). Of course this wasn't a quick fix because I had to re-ferrule and re-heatshrink both lines (with me sweating and cursing the whole time). After I fixed that, the amps powered up.
I got the WiFi controller set up and was able to access the Helix fairly quickly. I worked on a setup file a while ago with inputs/outputs and crossover settings in demo mode while trying to get familiar with DSP Tool and fired up some XM radio. One by one, I unmuted each driver and had sound! Keep in mind, my input gains were cranked all the way CCW and I still have to set them another day, but at relatively low volume, it was a night and day different from the OE system (I should hope to hell it would!). I set up the HEC BT and played a song off Tidal. OMG!! 10+ times better than XM off the OE HU. I can't wait to hear it with my DAP/Optical.
That's all for today. I will try to finish the odds and ends and start tuning this week!
So happy you got it up and running brother!! That .10 must definitely feel good going down after all the hard work put into the system! Don't blame the Ace screws too much, I had a hell of a time with screwing into that box as well. Screws would seems to go in perfectly (pre-drilled of course) and then about 1/2 way in it simply would not screw down further! Ended up stripping a few drive heads in the process. If I ever get anal enough to remove that speaker again I will definitely change over to the threaded inserts instead. How did the FastRings turn out with the printed mounts? I mean since its basically at stock distance from the door did you have to cut a lot of the foam off? Any mods to the panel to get it to fit? At least now you can drive the car a bit mean while you tune it in man. Congrats, everything came out beautifully!
Hey guys, I have a Subaru (Ascent) and an under seat amp install and I’ve been a bit intimidated to take out the passenger seat. I’m getting ready to redo my install and it would be AWESOME to have all that room with the seat out when doing the install.
Is taking out the seat a big deal? Is the process found in the manual? What’s the general process? What tools do I need? Any safety issues?
Thanks for your help!
Discussion Starter #144
The Stinger rings fit perfectly (the largest one in the package). I did trim the plastic on the inside the door trim panel to make the inside of the speaker grill pretty much flat. I will take a pic of that tomorrow. I still have the passenger side panel off.
Discussion Starter #145
Seats are pretty easy to remove. Usually just 4 bolts (14mm) and some electrical harnesses to disconnect for the airbags and seatbelt sensors. Hardest part is awkwardly lifting them out of the var without scratching anything.
Sweet. I can’t believe it’s that easy, but I’m glad it is. I’m sure not scratching anything is pretty tough though ;-)
Discussion Starter #147
Everything is back together and the car is able to be driven again. I hope to get some tuning in tomorrow. Some random pics. Here's my DAP mounted. I forgot to take a pic without the DAP in the mount to show the Proclip I bought. This setup is going to work nicely. I was able to run the thin optical cable up the seam between the glove compartment frame and the radio/climate section of the dash. It fits in there snugly and will not move. I then ran it up behind the DAP mount.
273710
My interim DAP cover.
273711
A pic of a Helix from the rear seat (the front seat is still pulled forward about halfway).
273712
THX, this is how much I cut off the door panels to accommodate MTuna's GB60 mounts.
273713
Well that's about it. I'll probably snap a few more random pics, but the hard part (hopefully) is over. I'm going to fire up my UMIK-1 tomorrow and play around. I still need to run some 50hz 0db though it to set gains for on the Pico. There is no clip light so I'll hook my O-scope to it.
Discussion Starter #148
I was able to take the car to work today and get a good listen to the system. I was all smiles for my 40 min drive! It sounds great. One thing worth mentioning is that I don't hear a bit of buzzing or rattling from anywhere in the car. No system noise either. It is solid. I was terrified the thing was going to be buzzing and rattling everywhere having read that Subaru's are just crap when it comes to interior materials and sound deadening. Not the case at all. I am sure there's a little bit somewhere, but I can't hear it. I never did use the last piece of sound deadener. I figured I'd save it just in case I needed to focus on a specific area of concern later on.
One issue I've run into already that will need attention is the optical cable. I read not to spend a whole lot of money on an optical cable so I bought a cheapy $8 cable from Amazon. I liked it because it is really thin and was easy to route/hide in the car, but I noticed from day one that the mini-Toslink end of it that goes into the DAP doesn't fit as snug as I'd like it to. Today I heard some static while listening to some quieter acoustic songs and when I touched the cable near the DAP, it got worse. If I put downward pressure on the cable, it went away. I pulled the cable out and I can swear the tip of it is not perfectly smooth and polished so I think it's a POS and do believe you get what you pay for (to an extent) with optical cables. At this point, with the cash I laid down for all of the other components of this system, it probably doesn't make much sense not to drop $50-100 on a good cable for piece of mind.
When there's no static though, this thing sounds killer. If I can verify there is no static while the car is still, I may try tuning with the existing cable, but I don't really want to put much time into tuning if the quality of the signal is in question.
Another initial thought is that I may move the URC.3. I like the location I chose when it comes to being stealthy, but I find it's a little awkward to reach down there to adjust the master volume when listening to either the HEC BT or Digital sources. I also foresee myself forgetting to stow the door every time I get out of the car and ripping it off its hinge with my knee (I did this today... LOL). More importantly and regardless of my joy even thinking about it, I foresee my wife not appreciating that she doesn't have a volume control within arm's reach of the passenger seat. 🙄 So... it may eventually get moved to a more "convenient" spot - little things that'll need to get refined...
Discussion Starter #150 (Edited)
Did some auto-TA and EQ tuning today. I used the UMIK-1 90 degree calibration file numbers for the Helix RTA.
Front stage left:
273791
Front stage right:
273793
Main EQ:
273775
Time Alignment (this looks like it didn't work correctly):
273776
I didn't bother EQ'ing with the sub yet because I need to scope the Pico to set the gains. I had limited time today to fool around with it and I was sweating my ass off.
I ran a REW RTA for the whole system once I did the auto-EQ and included the sub without tuning. I'd say it doesn't look bad at all. How do I get target curves for individual drivers and overlay them on my RTA?
273781
