hello, i have a dip problem when both left and right channel plays. wondering if can help with this problem.
my setup
-2 way active front, door and a pillars
- 12” sub behind passenger seat firing forward. (i need space at back for my equipment)
suzuki wagon blind van.
crossovers
tweeter crossed at 3.5khz-20khz
midbass from 70hz- 3.3khz
sub 20hz-60hz
mic used dayton audio imm-6 and audiotool app on android. ( yes is not perfect accurate but its what is available to me).
below are individual measurements of left and right channels. yes not perfect linear but is ok for me. target curve linear from 20khz until about 200hz then rises up.
and below are the measurements when both left and right channel plays.
L+R FULL are when all drivers are in phase( i think). quite linear down until 200-180-160hz where it dips.
L+R NOT PHASE i switched one of the midbass 180° and shows more significant dips and peaks. dip at 80hz, 250hz and throughout the midrange not quite as linear. so i assume the L+R FULL measurement are in phase.
the mic was placed at listening height, centered at the headrest roughly where my ears would be. moving the mic left and right few inches does not help with the dip. but putting the mic at passenger side gets rid of the dip.
how to fix something like this? or maybe i am doing something wrong with the timings at the dsp.
thank you
my setup
crossovers
sub 20hz-60hz
thank you
