sub configuration
  • 1 x 15" subwoofer with 300w
    Votes: 1 14.3%
  • 2 x 15" subwoofer with 150w wach
    Votes: 6 85.7%
1 - 6 of 6 Posts
· Registered
Can you fit both the 15s in the same type of enclosure as the single 15? In other words, you're not having to do two 15s sealed vs a single 15 ported, etc? If not, and you can fit the pair, I would run the two as well.
· Registered
what are the subs? It would depend on the power handling, if you are not able to over drive one of them with 300 watts, then i dont see the need to add a second unless you can buy more power.
· Registered
Yes, please list all the information you can.
Sub model(s) {hopefully they are identical subs}, amplifier model, vehicle this is going into, music preference, end goal, etc etc.
Depending on power handling and power able to "really" be produced, running just one of them in a ported enclosure to proper specs has the ability to produce as much as both in a sealed enclosure, all while taking up similar or less cargo space. However, running ported requires the use of a infrasonic/subsonic filter, very low tuning, opting to not play music with audio recorded below the tuning, or running the setup at half or less rated power.
1 - 6 of 6 Posts
