1 - 3 of 3 Posts
Digital Designs M1A mono block and C4B 4 channel. They were purchased brand new from an authorized Digital Designs dealer and come in the original boxes. The M1B does not come with the bass knob.
SPECIFICATIONS
Series C
Input Sensitivity 0.2V - 6V
Variable High Pass Filter 30Hz - 1.2KHz
Variable Low Pass Filter 30Hz - 500Hz
Variable Bass Boost 0-12dB @ 40Hz
Tested Voltage 14.4
Tested THD 1%
Model C4b
Cont Power at 4 ohm 60W x 4ch
Cont Power at 2 ohm 100W x 4ch
Cont Power at 4 ohm mono 200W x 2ch
Damping Factor >100
Dynamic Power 800W
Efficiency thru Output 65%
Dimensions - mm 244.5W x 54.3H x 300L
Dimensions - inches 11.81L x 9.63W x 2.14H
Signal to Noise >100dB
Shipping Weight 11.5 lbs
M1B
Input Sensitivity: 0.2V - 8V
Variable Subsonic Filter: 10Hz - 50Hz @ 24dB/Oct
Variable Low Pass Filter: 20Hz - 200Hz @ 24dB/Oct
Clipping Display: LED
Tested Voltage: 11.9 VDC
Tested THD: ≥1%
Cont Power at 2 ohm: 780W x 1ch
Cont Power at 1 ohm: 1200W x 1ch
Dynamic Power 14.4 VDC: 1905W x 1ch
Dimensions - inches 13.78L x 9.13W x 2.5H
Shipping Weight 16 lbs
Excellent, they were only used for a few months
$450 shipped for both FIRM and no trades
1 - 3 of 3 Posts
