1 - 6 of 6 Posts
This will be going in a Scion tC either door or kick panels. So gonna need something that can work IB in a car door.
Current setup consists of:
Tang Band w4 1320SJ full range drivers from 325hz up
LPG 26NA Tweeter Crossed at 12khz (still trying to find a good mounting position if anyone has suggestions)
Subs are Dayton HO 10s, 2 of them.
wanted the Peerless SLS 8's but dont have enough power to push 8 ohm midbass :( so need to be 4 or 2 ohm. No deeper than 4" preferably. More shallow the better.
highest they will ever be crossed is 350hz (probably not that high)
want them to play down LOW to the point that I dont miss my subs in case I have to take them out for trips.
I have about 125wrms to push to the each driver and about $200 to spend on them both....suggestions?
hmmm, ill consider thsoe .....thanks
I auditioned a set of those ^ AWESOME mids.
1 - 6 of 6 Posts
