1 - 12 of 12 Posts
Hey guys,
I have a 2007 Dodge Ram Mega Cab. I bought a Subthump sealed box with the built-in amp rack: 2006-2018 Dodge Ram Mega Cab Dual Sub Box With Amp Space
Amp rack is 20" W x 13" H.
Reference pics are below.
I have a pair of the older 12" SSA GCONs.
I spoke to SSA to ask for amp recommendations; they suggested something around 2000W @ 1Ω. Based on the amps in their store, they suggested:
Synergy Audio WFO 2.1D 2,000w RMS Mono Block
Incriminator Audio IA 15.1 Mono Block Amplifier
(Along with a couple others I have written at work).
My challenge is choosing a quality amp (up to $5xx range) that will deliver the clean power, and fit in the provided space (with room to run the wires)...I'm guessing the amp settings will need to be done before mounting.
Synergy is 17" wide.
Incriminator is 17.7" wide.
Ampere Audio AA-2000.1 is 19.4"
SSA IC2200.1 is 18.9"
Any recommendations?
How much space do I need on the power and RCA side to run cables without bending them too sharply?
I've tried to provide as much info as possible. Anything I missed, just ask. Thanks!
- Dave
260023
260024
260025
260026
260027
260028
Hey guys,
- Dave
Check Wolfram Audio, they're pretty solid amps (the W series), they may have one that works for you. Nevermind, the W3000.1 that I have is the only W series that puts out enough power, and it's 23 inches long, and $599.
Hey guys,
- Dave
Maybe something lightly used?
This won't disappoint.. Couldn't find dimensions but something tells me it's small enough.
Reactions: DavidRam
Hey guys,
- Dave
How about this?
Reactions: miniSQ
The Taramps MD3000.1 easily fits your criteria. It's small, inexpensive, and reliable. It won't bring home any trophies in the appearance department, but it will handily do what you're asking.
Priced at ~ $235.00 and with 3000 RMS @ 12.6 volts, it's a tough package to beat. Not to mention, it provides rated power at 12.6 volts, and not 14.4 quoted by most manufactures.
Dimensions: 8.98" x 2.76" x 8.58"
Read Only
shameless plug, although I think it sold it last night.
Reactions: Dave88LX
The sundown salt amps are nice
I actually just picked up a tezla tz2kd
It’s got a plexiglass bottom and different color leds inside the amp. It’s super clean and within your budget.
Here are a few.
Gladen SPL-1800, 1,750 watts @ 1 ohm
Rockford Fosgate T1500-1BDCP, 1500 watts @ 1 ohm
ZAPCO Z-2KD, 2050 watts @ 1 ohm
ZAPCO ST-2000XM II, 2000 watts @ 1 ohm
1 - 12 of 12 Posts
