1 - 20 of 43 Posts
I am starting the install on my 2004 Ford Ranger FX4 Ext. Cab. I have finally made my decision on the equipment I will be using. deck-Eclipse AVN6620, Phoenix Gold 15x Eq, Amplifiers Alpine PDX 4.100 and PDX 1.600, Front stage Morel Hybrid Ovation 6" with a mt-23 tweeter, Rear doors JL 6" subs, Subwoofer- JL audio 13w5 thin mount 13 subwoofer, I have started the box. The JL sub only needs .80 cu ft. so I am making a box that will go on the back wall of the truck. I went and bought a sheet of mdf and worked until the rain hit. More pics soon.
Discussion Starter #2
Some pics of my box build with 3/4 mdf
I finally got a brad nailer and finished assembling the enclosure. I have to take it to the stereo shop to have the hole routed out for the JL 13". After the hole is cut I will finish making the box air-tight and use filler to fill all the box imperfections. The box is 32 x 14.5 x 4.5 x 6.0. I have a total of .83 the woofer requires .80 so I built a little larger for displacement and bracing.
This weekend I will be busy pulling out the interior panels, planning my wiring route, removing jack, removing jump seats, and planning the damping. I will also be working on my boxes in the rear doors that are going to hold the JL 6" subwoofers.
awesome! post some pics of the truck!
Here is the head unit and I need to get pics of the truck.
sweet, check out my thread on my 03 fx4.
I am looking at it now how do you like the woofer?
well i havent powered the woofer yet, but if it sounds as good as it looks and people say it sounds, ill be happy. going for sq, and ive read great things about this sub and sq
damn u, just read u gonna be using pdx amps. those are the exact amps im gonna run when the money comes!
How do I get the big pics like on other threads
Administrator
Get a photbucket account, they're free, upload your pics there. Then link them in here by copying the IMG code of the pic you want.
im interested in seeing this. i seen a thread somewhere of a guy who put 8s in his rear door. ive thought about this myself, but just gonna keep it simple.
Discussion Starter #14
I have some 8w1's I could put in the rear doors but I think the 6w0's will be alot easier to work with and require less power while still performing like I need. I may hold off this weekend on removing the panels I am worried about breaking stuff when it is cold.
yea, let me know when we can cut a sheet of wood! im ready to get this sub installed! i was thinking about trying to glass my PDX amps into the rear doors. well if i ever buy new amps.
Discussion Starter #17
Maybe this weekend we can cut if it gets decent. I have no room in my garage, so I wheel the saw out into my driveway to cut. Do you have a cut sheet? I might try to buy a brad nailer tommorow so I can build some other boxes. I will pm you my number later.
sounds good. i do have a cut sheet, well not really a cut sheet, but a paper that says all the sizes needed.
Discussion Starter #19
Here are some more pics seeing how it will fit in the rear of the truck. I have removed one jump seat and the jack holder. I have to remove the rear panel and figure out how to secure the box the woofer alone weighs around 18lbs plus the box. I may be able to use the factory mounting points for the box.
Discussion Starter #20
1 - 20 of 43 Posts
