1 - 6 of 6 Posts
Here is system layout so far:
Front doors: CDT CL-69sub 2ohm
dash: CDT unity 8.0
Rear factory location: CDT HD-690CFX 2 ohm
Amps: JBL 3ez
jBL 504ez
DSP: Dayton 408
Had amps and DSP laying around so why not use them. But need to come up with a sub. The 3ez gives me 500 wats at 2ohms. Don't have anything in current collection I think would work. Would like to go to a single 15. Don't really want to spend more than $300 (which is more than I bought the van for). The SI SQL looks super
interesting but don't think I have enough power but I would pay a little more if yall think it sounds worth it. Dayton doesn't offer so a dvc 4ohm 15. Any other suggestions??
Reactions: MetricMuscle
SPL, SQL or SQ?
Ported or Sealed and maximum enclosure size?
SPL, SQL or SQ?
SQL ported or sealed. Probably 2.5 cuft max. Want to use half of rear stow n go area
Not much to choose from with these constraints:
  • $300
  • 500W @ 2 Ohms
  • 15" small sealed or ported
The biggest problem is the 2.5 cuft which is small for a 15 unless you have a bunch of power (SQL with 2-3kW).
Most of the contenders are going to be SPL starter brands like Sundown (which are not bad but they need big boxes) or something like a Rockford P3 but again, big box. But I did manage to track down one that's very close...
Which works surprisingly well in 2.5 cuft at 28Hz:
Colorfulness Rectangle Slope Font Line
Dead on xmax at 500W:
Rectangle Slope Font Line Screenshot
With Cabin gain manages to hit 126dB at 32Hz:
Rectangle Slope Font Parallel Screenshot
Reactions: tbomb
Man I really appreciate how far you went into that for me. I started off with just trying to use what I had. I mean I barely spent $400 on van in the first place. I have a 2ohm kicker solobsric 12c. I may just use that until I can justify the cost and move up in power. I'm already diving down the Helix/audison rabbit hole and just have to stop myself.
1 - 6 of 6 Posts
