So, time to break out REW, as I have experience with it from tuning my home theater as well as live venues, since as a musician, I've often times had to setup live sound .... but, my rig for HT and live sound is a Tascam interface with a phantom power microphone, with all the signal and power requirements that come along with that ... and man, that's just a lot to manage for tuning the car.
Then I find this cool Dayton Audio iMM-6 calibration mic, that'll work with my phone and the AudioTools app ... sure, that'll be enough
So I pick one up, along with a lightening to 1/8" TRRS adapter, and an extension cable ... NOW I can get that clarity I'm looking for, right?
Armed with the measurement setup and the 80PRS capabilities, I get to tuning ... and man, the system takes another leap forward in terms of clarity.
But am I now completely satisfied?? Naa, of course not! It must be the cheap Toro amp, right? I mean, it sounds better than the setup when I had the old PPI and RF amps in play ... but that must be due to the Hertz speakers, the sound deadening, and the power upgrades, right?
So I start thinking way down the road ... What if i were to replace the 80PRS with a nice modern touch screen, with backup cam, navigation, wireless carplay, etc, etc ... But then I'd need to find a HU with all those features, which can also match the SQ capabilities of the 80PRS.
And then I ran into the world of DSPs ... Nice! With one of these, I can offload all the SQ processing out of the headunit, freeing up my HU selection to focus more on the usability features and less on the SQ capabilities.
That leads me into more reading, more research .. and wouldn't you know it, there are DSPs which also have integrated amps! Whoah, ok ... so now I can not only address the future scalability of the HU, but I can also get the cheaper Toro amp out of there at the same time ... and, now that I'm thinking long term, it sure would be nice to reclaim my trunk space so I can actually fit my guitar and gear in there when I need to drive the GTO to an event...
Does the rabbit hole even have a bottom??
So all of this thought process leads me to a Helix V-Eight DSP MK2 ... nice, this thing not only has 10 channels of DSP capability from one of the leaders in the space ... but also has an integrated 8 channel amplifier built in. And ... it'll fit in the same place where the GTO's OEM amp was mounted for the stock 6" subs which came in the rear deck.
But, I need a way to control it from the driver's seat ... Hmm, the URC, the Helix Director, the Helix Conductor, or WiFi control ... more reading, more research ... I decide the Conductor is the way to go for me. and I rip the system apart yet again ...
To mount it, I attach two strips of wood to the bottom, with 4 philips head screws exposed for mounting to the OEM location
Yep, perfect fit! Everything wired up, cables ran, and it's a nice clean install in an out-of-the-way location, perfect!
So the conductor, hmmm ... There's this perfect place next to my window switches, but it's a self contained module. Ahh, but that doesn't stop me ... I pull the window switch module out, and hack it open and start modifying. It really is a perfect fit!
So now I need a way to tune the system easily, and opening the trunk, pulling back the panel, and plugging a USB cable in isn't really easy.
To solve this, I ran a USB extension cable into the center console, and installed a USB jack for connecting my laptop.
For the power, I ended up relocating everything to be nicely hidden behind the trunk panels.
The 2ga power from the battery comes through the hole at the top left of this picture, then there's a 3-way distribution box hidden by the fuel filler hose, which splits the power out to the two circuit breakers. There is a very conveniently located channel across the entire back of the car, and you can see where I ran the cables for the Helix DSP through it.
Just a quick look at the underhood changes as well ... The blue line shows where I installed additional 2-awg tinned OFC ground from the battery to the chassis and the engine block ... and you can see the single fuse block now, with 2-awg tinned OFC power wire as well.
So now I need to tun this thing, but the little iMM-6 mic with AudioTools seems inadequate now LOL ... it probably would have been fine, but I really wanted a way to use REW ... which leads me to picking up a dayton UMM-6 USB mic.
Here is what I end up with after this phase ...
... and wow, after tuning, the system takes yet another leap forward in clarity!
