1 - 3 of 3 Posts
I purchased a factory sub that came out of a 2013 Ford F-150. I want to put it in my 2009 Ford F-150. It also has the system with the factory subwoofer, however, the sub was missing when I purchased the vehicle. The sub fits perfectly under the seat and lines up with holes for mounting. The harnesses are different though. Is there a way I can wire that sub into my 2009? Any help is appreciated!!
I just installed a full system in a 2013 f150 this past weekend. Here is something I used to help me. You should be able to just splice the wires from the old harness with the ones on the sub enclosure.
Also, research on F150forum.com if you already haven't. There is a ton of good info there and there are plenty of build logs and whatnot.
http://www.intyss.com/downloads/2010F150AUDIO.pdf
1 - 3 of 3 Posts
