121 - 125 of 125 Posts
Discussion Starter · #121 ·
I had the same drivers as you. Did some testing before.
First pic was totally sealed. Nearfield
2nd pic was opened up venting outside. Possibly nearfield. might be at ear tho.
Sent from my LM-Q730 using Tapatalk
Do you know what caused all your big dips in that response between 100-300?
Sounds like the jigsaw is coming out this weekend
Experiment idea.
Do a nearfield. Then take the enclosure out. Strap it down in the garage so the enclosure can't move when the driver plays. do a nearfield. If the two are similar enough then you can test if venting it will work. Simply cut out the back of the enclosure and do a nearfield. Should tell you what you need to know without cutting metal. If the first two match that is.
Discussion Starter · #125 ·
Experiment idea.
Thanks for that idea, it would be way easier patching the enclosure back up then putting metal back in
