1st "build post" here...
There are not a lot of threads on Volvo so I decided to take the plunge...
Thread to document the upgrades made to my S60 2011 "premium sound" set-up.
Upgrade 1 - Front Door Tweeters: Small project over a long wkend. Replacement of the front tweeters by the tweeters of my Hybrid Audio Imagine 6.5 taken from my old V70. (Stage II - Imagine - The Home of the World's Finest Loudspeakers, and World Championship Car Audio Speaker Systems.)
Since I want to be able to swap the OEM back if I sell the car, I bought the front Tweeter pods from Tasca.
(In my case, part for "no BLIS" without Premium)
Right Side: CORNER COVER, RIGHT - 2011 VOLVO S60 (8648753)
http://www.tascaparts.com/volvo/s60/...position=right
Left Side: CORNER COVER, LEFT - 2011 VOLVO S60 (8648752)
http://www.tascaparts.com/volvo/s60/...&position=left
I took some pictures along the way.
Album photobucket:
2011 S60 T6 - Audio by harleyvhh | Photobucket
OEM Tweeter "POD"
Step 1: separate the components from the POD
1) grille
2) support
3) Tweeter assembly
These three components are held in place with plastic rivet.
To separate them, one has to take away the rivets carefully with a drill.
PIC "tweeter_2.jpg" shows the rivets to take away
PIC"tweeter_2a.jpg" shows the three components
Step 2: Take away the OEM tweeter from the tweeter assembly.
Step 3: Modify the tweeter assembly to support the new tweeters.
Photo "tweeter_2bb.jpg" shows what I took out of the assembly to fit the new tweeter
Photo "tweeter_2c.jpg" shows the results after "dremel"
Step 4: Glue on the new tweeter and solder the connections.
I did not use the OEM low pass filter for the tweeter. I took the low pass filter from the HA speaker.
Connect positive (with filter) on the same side as the OEM.
Before going to the next step, check if all is working by connecting the assembly to the car.
Step 5: final assembly
Glue new tweeter assembly to grille
Final assembly
Step 6 - install & enjoy
Album photobucket:
OEM Tweeter "POD"
1) grille
2) support
3) Tweeter assembly
Final assembly
