1 - 20 of 236 Posts
Approximately 4 months ago I sold my 2010 Volvo C30 and purchased a 2013 Honda Accord EX sedan. I actually loved my Volvo, and I loved the stereo system in it even more (build log here) but my wife and I were expecting our first child and I needed something a little more practical. After driving every sedan under the sun, the new Accord was hands down the nicest in my price range. I convinced myself that I wouldn't miss the stereo system and would just get by listening to a stock stereo.
I made it about 2 weeks before I started planning my new installation.
After scrimping, saving, and begging my wife to use part of our tax return I finally have all the gear together for a build. I learned a lot from my previously mentioned first "complete" installation and I hope to continue that learning trend here. My goals for this project are:
1) Achieve good sound quality using primarily factory locations and a simple 2-way front stage.
2) Learn to build and properly tune a ported subwoofer enclosure (I have always done sealed or IB).
3) Be able to return the car to stock relatively easily.
4) Maintain serviceability of the vehicle.
5) Respect the original design of the vehicle interior. I want everything to "look like it was supposed to be there."
6) Learn new composite fabrication techniques including but not limited to vacuum bagging (wet layup, I will likely not be attempting infusion yet)
7) Have fun.
8) Finish in time for my first sound quality competition (IASCA event June 8th, 2013).
9) Retain the spare tire, tools, and ability to access them.
I am definitely not an expert. What I lack in experience I try to compensate with persistence. I post a lot of photos with my builds, it helps keep me honest and details my thought process, for better or worse. I encourage and embrace feedback from the multiple talented individuals here.
Here is my core gear list. This doesn't include a lot of odds and ends such as wiring and sound deadener, but it gives a general idea of what's going in the car.
Here is my proposed system layout. The only unknown at this point is whether I will be running a three way center channel using a Vifa NE85W that I picked up. If space will allow I will do this. This is, therefore, not represented in the diagram.
I will be running the entire system off the rear outputs of the stock head unit and will be running two full range drivers off the front channels of the stock head unit. These will be mounted in the top of the doors, near the handles. This will allow me to run bluetooth calling out of these full range speakers only and not through the entire system. It will also allow me the potential flexibility to convert the system to a three way front stage should I get the itch in the future.
Oh, and I will be running four eight inch subwoofers :). The subs will be mounted as pairs in two custom ported enclosures in each side of the trunk. The front and rear speakers will be in stock locations, but with some twists. The center channel… well I will have to keep you in suspense there :).
The amplifiers, processor, and wiring will be mounted in a false floor built into the trunk. I will do two pairs of fans in a push-pull configuration to handle cooling.
Subscribed, as my wife is also a physician. Congrats on the great news about your forth coming baby. :)
Here are some pictures of the gear:
Everything. I gotta send a big thank you to Don (RudeBoy) at Sound Deadener Showdown for his assistance with formulating a sound deadening plan for the project. The gear I purchased from him is top left in the photo. The only thing not pictured is the 160lb package of mass loaded vinyl. It was too unwieldy to pack into the garage for this shot.
Dayton RSS210HO-4 8 inch subwoofer
JBL MS8
Kenwood KAC-9105D
Kenwood KAC-8405
Kenwood X450-4
Tang Band W4-1337
Vifa NE149W
Vifa NE65W
Vifa NE85W (Not sure if I will be using or not)
Thanks a lot! He was actually born on 04/21/2013 so I am running on pretty much no sleep :). My wife is awesome though and she is letting me work in some time for this project as she can.
Discussion Starter · #6 · (Edited)
Some more photos:
Vifa XT25 Tweeter
Vifa OT19 Tweeter
Monoprice RCA Connectors: I'll be using these with some Gepco 61801Z wire, tech flex, and some heatshrink to do custom, DIY RCAs. They are super easy to build, and I can make an RCA cable for a couple bucks that kicks the pants off anything available commercially.
Various raw materials including fiberglass, carbon fiber, resins, mold release agents, etc. You can also see my ridiculous collection of detailing supplies.
Discussion Starter · #7 · (Edited)
I started deconstruction of the car today and installing some sound deadener. It's late and I have to work tomorrow so I will update that tomorrow.
Best of luck with the build. Are you aware of the headache people are having with aftermarket stereos and Honda's active noise cancellation? While you're tearing the car apart, it may be a good time to disconnect the ASC module.
in for more pics...good luck on your install
Discussion Starter · #12 ·
Thanks for the heads up. Yes, I am aware of the need to disconnect the ANC module. It will be a relative piece of cake though. I will be pulling the headliner to sound deaden the roof so I will have to disconnect the ANC microphones at that time anyway. I'll leave them disconnected when I put everything back together.
looking forward to the build trevor... looks like a simplified budget (over last time) but what looks like some really nice drivers... should have good results :)
in for updates ...
Discussion Starter · #14 ·
Thanks Matty. It is definitely similar to my last build simply because I loved the way that car sounded. I just had to set a limit on the spending. I really want to focus more on the build quality and use of composites in this build over high dollar components. I still have some ideas up my sleeve though. If everything turns out the way I envision it, it should be super cool when it is done.
And those Vifa mids are REALLY nice.
Discussion Starter · #15 ·
Well, this is the most boring part of the build... sound deadening. There isn't a whole lot to show but I will post some pics of the little progress I made. This stuff always takes longer than I expect. I am going to rally this weekend and try to finish up all the deadening by Monday so I can actually get into the fun stuff.
First some measurements. I used my iphone and Dayton IMM-6 calibrated microphone to take some measurements prior to making any modifications. I want to be able to quantify how much a difference the sound deadener makes. These are all a-weighted RTA measurements. All measurements were taken with the windows up, stereo off, and the heating/AC off.
Engine off, stationary in garage
Engine on, at idle, stationary in garage
Quiet road (no traffic), cruise control set at 25mph
Quiet road (little traffic), cruise control set at 45mph
Quiet road (little traffic), cruise control set at 65mph
Quiet road (little traffic), accelerating onto freeway (engine floored). Measurement taken at approximately 45-55mph
I will refer back to these measurements after I finish the sound deadening.
Discussion Starter · #16 ·
Here some quick pics of my work area and the off camera flash mounted on a storage rack
The shop tunes (speakers are orb audio point source drivers and a 10 inch energy subwoofer, source is my iPhone and an Emotiva stereo preamplifier and 2 channel amplifier, it sounds great)
Discussion Starter · #17 ·
Stock trunk
Trunk, rear deck, and back seat stripped
Trunk lid with alpha damp applied until panel resonance controlled
All crevices stuffed with jute padding
Back together
Alpha damp down in the trunk and spare tire well
It doesn't look pretty, but all crevices were stuffed with jute padding and polyfill. Some places needed to be secured with a bit of tape until the carpet is replaced.
The rear deck was treated from above and below with enough alpha damp to take care of any resonances. The rear seat platform was also treated. Luckily the Accord comes with a ton of factory sound deadener so overall panel resonance isn't a huge issue along the floor.
The rear deck was treated with a layer of closed cell foam. Everything was mocked up and fits well. No obvious resonance remains from the panel or rear deck. First mission complete.
Tomorrow... more sound deadening. I'm hoping to get the rear of the car covered in CCF and MLV then remove the roof panel and front seats to start deadening there Sunday.
nice shop setup! I would be happy with that as my main rig. :)
Good luck with the build. It looks good so far.
1 - 20 of 236 Posts
