I used a ground I found to the right of the passenger seat and established that first with 4awg cable.
Then ran it under the carpet right next to the seat. I had to unbolt it and lift it up though.
It exits the carpet from a cut out.
I ran the 4awg positive through a grommet that's in the driver's side.
Location of grommet and it's removed...
Into the engine bay...behind where the battery is for all the non-hybrids.
Ran it behind the fuse box...
Added in-line fuse.
Connected to fuse box.
Also found a couple rattles for anybody who's been tracking them down. One rattle was the fuse box. It was VERY loose. The washers were actually rattling back and forth. Another was the floor vents. They connect to a primary duct. There was just enough space that vibrations caused the vent and duct to rattle against each other. I used foam tape to seal it up. It also got rid of the whistling noise from my hvac.
Terrible shot of the hvac...but this is the floor vent that connects to the primary duct. It was pretty tight. Maybe I'll try to get another shot later?
Added in-line fuse.
