I found this car in June. I was really looking for an SQ5, but my mechanic gave me his A6 for the weekend. I fell in love with it except for the bose sound. It took me until the end of November to sell my A4. I spent that time researching audio upgrades for the A6. I ran across Jimmy Dee’s rs5 build in audizine which lead me to diyma. I took over the a6 early December and continued my research. My original plan was to use the components I had and add what I needed to use the oem head unit. MOST was a new concept to me. After several months of visiting I joined diyma. MythosDreamLab welcomed me, said there were lots of audi guys on the site, and be prepared to spend lots of money. I ignored the last part, but he was right. The only thing Im using from my a4 is a JL audio mono sub amp. I pieced together all the components from our classified ads. Thanx to Flyhogz, james2266, ajb1205, nautchilous and bruce miranda. they were all very helpful and were a pleasure to buy from.
The components are as follows
mobridge DA1
Audison AP F8.9
Jl audio jx 500
Seas 6.5” woofers
fountek 3” wideband
audio frog gb 10 oem
Jl audio 12w3 v4-2
Rear shelf fill tbd.
My goal is to do a stealth, simple and easily returned to stock build.
This will be my first dsp and 3 way active front stage.
After reading skizeR‘s exotic builds I decided to do this in stages. Mainly because it is still to cold to be popping off door panels and plastic interior bits. ( 2” of snow last friday).
I‘ll start off with Nicks stage one. DA 1 preamp to audison dsp amp to oem 3 way active speakers and a sealed box sub in trunk. I will run the Audison preset 3 way active tune for now while I save up for a remote tune by Nick.
This has been made incredibly easy with brucemirandas 38 pin board. It connects the oem harness for the bose amp/dsp, which feeds all the speakers via 16 awg oem wiring. It also provides 12v+ and ground
The bose amp and radio unit are in the driver side trunk behind the wheel well. The ap f8.9 is smaller than the bose amp so I could modify the oem rack. The da1 is velcro’d to the top of the audison. Everything is accessible from the access door.
Bose amp
Audison and DA 1
I had installed the sub amp in the winter running it from the bose wiring to the oem sub. So I just had to change the input from high level speaker to rca from the ap f8.9 sub output. The da 1 triggers the audison which triggers the Jl amp.
I got everthing buttoned up, double checked all the connections, and tried a test listen.
NO SOUND.
I finally wondered if the audison was not on the proper input. It is wired for optical input only. I connected the drc and sure enough it defaults to master input even though nothing is connected to those inputs. I can switch inputs on the drc but every time I start the car I have to manually change to optical input. My next step will be to hook up the dsp to my computer and return the ap f8.9 to factory setting.
Results so far
The sound is significantly improved even with oem bose speakers and a generic tune. The bose system is typical no highs-no lows, compressed dynamics and no sub to speak of. And on top of that sounds like there are pillows covering the speakers. The radio is pathetic. CDs better, my main source is tidal master downloads through my iphone, connected to dragonfly and aux input of audi head unit. Real instruments are ok but metallica and blues downright depressing.
Now I have significant dynamic range, clean clear sound and higher volume. Bass is much improved.
Next step
When the weather gets warmer I will yank the door panels, deaden the doors and install woofers and 3” wideband in factory door locations, tweets in factory dash location. I will fabricate a "new sealed sub box out of bb ply and veneer it with claro walnut which matches the interior trim. I will decide wether to fire the sub through the oem sub hole or remove the ski port and make a grill for the hole and fire the sub through the back seat back. If I find another set of small widebands, I”ll mount them in the rear shelf.
If the canadian dollar ever gets better I’ll get a remote tune from Nick. If you think $500 is expensive, thats over $700 canadian.
Its cool that there are 2 other members doing a6 builds right now. Hopefully we can learn from each other.
mobridge DA1
Audison AP F8.9
Jl audio jx 500
Seas 6.5” woofers
fountek 3” wideband
Jl audio 12w3 v4-2
Bose amp
Audison and DA 1
NO SOUND.
Results so far
Next step
