Oh yeah! And I have to out do the last so that calls for two IB 18” minimum!Sounds like another adventure of VW CC
Sent from my Pixel 4 XL using Tapatalk
And than we heard big boom from the amplifiersMy Lishen 36ah lithium lto bank and maxwell 500 farad supercap bank…
the Lishen will be hidden behind trunk lining and maxwell fits in a small cubby on opposite of Trunk View attachment 307895
Awesome i have one as well Jon.Looks great. I'm a VW dealer tech. I can run your CC to check for any open recalls and check to see what warranty extensions you might have. Jon
What deadener did you use on the rear deck?All wiring to trunk is done. All sound deadening is done. Deadened the rear deck and attached a birch plywood 1x4 brace to the underside of the read deck using carriage bolts. The baffle will attach to this on top. Nothing is needed on the bottom because the baffle is made to press into place and it works!
Removed my full size tire and bought a donut spare to free up room for an amp rack that will be cooled by 4 big dead quiet fans made for home audio amps. They are usb powered so I bought a 12v to 5v usb converter that connects to my relay box turned on by the remote wire.
View attachment 307887 View attachment 307888 View attachment 307890 View attachment 307892 View attachment 307893 View attachment 307894
nothing expensive lol. I think fatmat or kilmat with some siless liner adhesive back foam over that then some auto insulation with foil and adhesive tape backing. I also always cover all holes and gaps with foil tape first.What deadener did you use on the rear deck?
You have to remove the rear panels on left and right side, and there are 2 screws that hold rear deck. Once you take them out, the rest is holding by clips. I have the same car.It looked like something inexpensive. Was it difficult to completely remove the rear deck panel? Are there lots of clips???
