Is the ground for all components also running off a distro? or is each component ground at different points (LC2i, mini, amps) Are the RCAs from the LC2i to the min running along with the power wire for any distance?
These things are typically a ground issue, or RCAs running in parallel along with the power wire for some distance.
Without seeing the install (pics/diagrams) it will be very hard for anyone to trouble shoot this...
You can try connecting your phone using an RCA adapter to the input of the Mini to remove the HU and LC2i from the equation...
