1 - 12 of 12 Posts
2016 Toyota Sienna SE
AF 3way active front stage
-gb10, gb60, gb25(dash)
-2 Arc Audio x2 1200.6 amps
-AF gb40, gb10 center channel dash
-AF gb10d2 10" sub
-rear speakers passive Boston Acoustics Z6 2 way.
-Helix dsp ultra w/usb input
-Audison lrx4.1 amp on standby depending on the best setup...
-knukonceptz wires
Here is my progress
Extensive sound proofing.
-80mil noico butyl 100% coverage
-315 mil noico foam 100% coverage with
-luxury liner over the noico foam squares in some areas... or butyl with luxury liner pro foam backed vinyl.
-doors are 100% butyl outer wall with 100% foam layer. then 100% butyl and a sheet of luxury liner pro on the inner door panel. TEDIOUS!
271711
271712
271713
271714
Discussion Starter #2
Should i just make luxury liner pro pieces to replace the factory white pads? or try to get more coverage than those areas? I will cover the gactory speaker area. Also how worth is it to remove the headliner and go to town on the ceiling with the butyl and stickyback foam?
271715
HAHA. I showed your first picture to my wife letting her know that's what I need to do to her van to install a system and she not so nicely said no. :)
Regarding your question on the white pads, I wouldn't necessarily replace them if there is enough room to fit a full layer of the luxury liner pro over the white pads. If only room for one layer, then I guess remove the white pads if you think the luxury liner pro will be an improvement. Then again, it depends on if you're adhering or hanging the luxury liner pro.
Tha
I guess i will adhere them since its a complex surface
Ha Yeah my gf was like "your the only person i know that would buy a new car then tear it apart".
Hey, I’ve got the same van, see sig. Don’t bother with the roof, a single 10 wont flex it but the plastic parts in the back are horrible. These vans swallow up the bass. The GS690 would have fit nice in those doors. I put my amp up behind the glove box on a custom bracket.
I have a 2014 and thought I was doing something with mine. Guess I'll be pulling the trigger on the 3-way active setup and DSP.
Cool... are you gonna sound proof? My custom 8th row seat stow cubby .subwoofer box is being made now.
I put almost 2 layers in the front doors, so they at least sound less like steel drums. If the dually gods bless me, then I'll put the van off the road for a little bit and do more deadening along with some adjustments to the front stage.
Reactions: brandom79
1 - 12 of 12 Posts
