61 - 71 of 71 Posts
Thank you for sharing the link know I know what product are called hopefully I can find them locally. Great work so far!
Discussion Starter #68 (Edited)
got the rear speakers foam taped and mounted up:
polarity checks out, time to get the door panels back on!
going to add some sound deadening around the door speaker area/ABS plastic speaker mounting bracket
Discussion Starter #69
Again, not perfect, but good enough for this project. I found this area to be rather difficult to get everything to lay flat-ish...anyway, this is the process I've been using. First I trace a "rough" template on a bisquine type product, then stick it to the Stinger Roadkill, cut it out, then use the cut Stinger Roadkill piece to trace a template on the 1/8" Dynamat Dynaliner. Then I clean the area I want to apply it to with Isopropyl alcohol and then apply the sound products.
Door speaker/Stinger Roadkill
Door speaker/Dynamat Dynaliner
completed door:
Discussion Starter #70
rear door panels are back on; overall the rear doors sound very solid...feels like I added a decent amount of mass. I also added tesa tape underneath all the door panel plastic pins before I mounted them back up.....not sure if it will help much but figured why not.
Discussion Starter #71
first time working with ABS sheet; stuff gets everywhere! Again, far from perfect but good enough for this application
61 - 71 of 71 Posts
