For that past recent months, I’ve been acquiring gear and planning what I’m hoping is a very nice clean sounding, factory looking, and simplistic install, hence the Keep It Simple Stupid. I plan to start putting everything in when the weather starts to warm up. In the meantime, I have started to work on the fabrication. Instead of having my car taken apart, I ordered used sail panels and a low priced door panel. I will be fabricating tweeters into the sail panels and the door panel will be used for fit tests. I also ordered water proofed brackets from DIYMA member Delander for the front midbass and rear fill speakers. He also made me a nice floating shelf for the amp.
The car is a 2018 Infiniti Q50s with non-Bose. The front doors have tweeters in the sail panels, 3” drivers in the middle door and in my case (non-Bose) a 6.5”, however the woofer opening easily fits a shallow 8” or 10”.
This car has connectors at the door boots, so adding extra wiring for running active requires drilling though the connectors. I decided to go the passive route first. If I’m not happy with it I will take the plunge and start drilling.
I auditioned a lot of gear and I’m shocked at what I settled on. I wanted to audition the Morel Piccolo but instead of dropping $700+, I figured I order the Tempo tweeters to get a feel of Morel first. It’s been a while since I heard a Morel tweeter. I owned the MT22 in 2005. When I started to play the Tempo in my home testing rig, I noticed I was doing less tuning and more head bopping. This tweeter checks all the boxes for me. Super smooth, super detailed, high resolution and instruments sound real. Guitar sounds phenomenal. I don’t have anything negative to say about this tweeter. Even when the music gets a little crazy, it doesn’t get washed out.
I don’t want to turn this into a review, but just something about the Tempo that draws me in. MT220 sounds similar to the Tempo. It is slightly bigger and the dome has a coating that the Tempo does not. It brings a tad bit more resolution to the table while still being almost as smooth as the Tempo. This one was slightly too sensitive for the other speakers I chose, but what a great tweeter as well. This thing gave me goose bumps. A lot of people are sleeping on Morel. I felt that I didn’t need to go up to the Piccolo anymore. Just to give everyone a reference of what I’m comparing these tweeters to, here is a list. All are great in their own way so not knocking any of them.
I tested:
Focal KX3 3 way
Focal aluma/mag tweeters from their home $7k-$15k towers
Dynaudio MD102 & MT171
Vifa XT25
Dayton small ribbon
Audio Frog GB10
Morel MT220
Canton Pullman
Scan Speak Ring Radiator
Audio Frog GS25
Dynaudio Esotan 3 way
I’ve also owned a few old goodies like the Seas Lotus, LPG26na, and MT22.
This is the gear I’ve settled on:
Tweeters: Morel Tempo
Mids: Morel 2.5” CCWR254
Midbass: 8” Volvo Dynaudio woofers
Crossover: Dynaudio 3 way crossover
Rear fill: Morel Tempo 5 1/4”
Amp: JL Audio VXI1000/5 with built in DSP
SUB: JL W6 12”
Sound deadening: Dynamat Extreme (ordered before I found out about “the deadening”)
So on to the pics. I’ll reserve the next posts to update with pics.
I tested:
Focal KX3 3 way
Vifa XT25
Dayton small ribbon
Audio Frog GB10
Morel MT220
Canton Pullman
Audio Frog GS25
SUB: JL W6 12”
