21 - 40 of 71 Posts
Discussion Starter #22
Lol.
Nice job on the sails, Gregers, I really like the unique shape.
Have you had any issues with the Pioneer modular screen? I know they had some issues with some of them and sort of pulled them back to repair/update them.
Jay
The shape of the sail pods are interesting. Instead of just rounding the bottom of the pods I threw in some sharp lines and angles because I wanted to bring some of the lines from the door panels and dash to it.
With Pioneer unit I initially had all sorts of random issues with it, including screen flicker but I figured out it was because of a poor ground. After I ran the ground wire back to the common distribution block all of the problems went away and it has been working great ever since. By the way I tested it with a DD-1 and there is zero distortion up to max volume, as should be expected. The HU / amps are extremely quiet with barely any noise floor. I need to put my ear close to a speaker to hear it.
awesome build! I didnt know those headunits exsisted !
How’s the Mmats amps working out? I’ve heard good reviews on them but not too many people run them. Install looks like it should sound amazing!
Discussion Starter #28
Updates? I just got a 2019 Edge ST not going to go this far, but looks great!
I don't have any updates. I took a break from audio to work on my Master's degree so I haven't done much of anything with the system since my last post. I still want to finish the bezel around the HU but otherwise I am happy with everything. I haven't needed to hook up my computer to tune anything in months. It sounds pretty awesome at low volume or loud.
Congrats on the ST. I love mine.
Discussion Starter #29
I picked up the HU as soon as it was available. It has been working pretty well so far, other than on occasion I need to toggle the rocker switch under the dash to get it to turn on. It may be the switch or wiring. One of these days I'll look into it.
Discussion Starter #30
The Mmats have been treating me good. No complaints at all. In fact I don't even think about them, they just do their thing, which is what I want out of an amp. The system does sound like one would expect for the equipment and install. :)
Is that pic with the what looks like a vacuum where you ran your power wire? If so was there a grommet there or did you drill out a hole?
Discussion Starter #32
I believe that grommet was already there, but do not hold me to it because I did install a few myself and don't remember if that was one of them. It's pretty easy to add one if you need to. It is a hollow cavity behind that wall and easy to get the wires to it.
Do you have any plans to go aftermarket on the performance? I just picked up some H&R springs, which I will be installing when the weather warms up here, and will be doing the Livernois tune soon. Their 93 octane performance tune is good for about 400hp and 440 tq @3k rpm on pump gas. Should be a lot of fun!
Nothing on performance just yet, but I am going to do audio starting with just adding a sub and amp, ill eventually move to adding better mids and highs and an amp for them.
Discussion Starter #34
I have the LMS tuner on the way, supposedly the guys at Livernois have done more tweaking and the latest version has even more power!
Do you know what sub / amp combo your doing? There's quite a bit of room under the rear floor once you pull the dividers out. I got a solid 1 cubic ft per sub with my enclosure. Also, in case you didn't know the stock battery in the ST is an AGM with a good charging system. I haven't found any reason to upgrade it yet.
Banned
this is a really nice build. i wish i could run some eights in the kicks in my car i don't know if i got enough room in a 2018 altima.
Awesome job ! Hope you are enjoying the fruits of your labor. Waiting for weather to break to embark on my own journey. Hope I have the patients skill that you possess.
Very nice job! I have a ‘19 edge ST- I might have missed it but what did you do to get sjgnal off the factory HU? I’m putting an amp and sub in the back and was gonna use speaker level inputs off the factory sub to the amp.
Im using the styrofoam inserts around the spare tire (mine has one) to put the amp and epicenter in. The sub box will go on top and I’m trying to figure out how to cool the amp.
263543
thanks for sharing- your pic and comment about the power wire should help a lot. I’ve been having a hell of a time figuring out how to get through the firewall!
Discussion Starter #38
I pulled the power-on lead from one of the fuses in the car. I don't recall which one so I will need to look. I found the best way to route the amp power wire through the firewall was behind the battery. I don't recall the exact location but if you pull out the battery you should see a grommet or a place to install one somewhere back there.
That reminds me I'll need to get trigger power straightened out as well- thanks!. I was actually asking about the signal from the head unit- how did you feed that into your amps? Are there RCA pre-outs on the back of the head unit like aftermarket stereos?
Discussion Starter #40
You may have missed it, but I installed an aftermarket Pioneer HU. The HU is modular which allowed me to install the box with the electronics under the passenger seat and screen in the center console. As far as I know there is no way to get a full clean signal from the factory HU. I know that Nav-TV was working on something but it has not be released, so your probably going to have pull the signal from the factory sub or maybe one of the other speakers.
21 - 40 of 71 Posts
