The wiring diagram shows that the sub has a triple voice coil which is most unusual. Threads on 5thgenrams talk about it. No one knows, that I have seen, why it would be built this way. I’ve read elsewhere that any sub with multiple voice coils has to get exactly the same signal to each coil, which makes sense. Each coil can not be trying to do something different.
The higher end HK system in the Ram has a single coil sub.
So it all makes sense now, doesn’t it! ?
Thanks!Dang lookin nice !
Is that MTI box the same MTI that makes switchers for boards (displays)
I've actually verified that the front and rear speakers participate in the noise cancellation... via the wiring diagrams from the dealership. However, I have the headunit faded to the front, so no sound comes thru the rear speakers, although the ANC still sends the signal to those speakers, and it helps without causing any issues.Unplug the ANC mics and be done with it.
.02c
I'd like to figure out which wires going to the sub are for the sub and which are for the ANC. I think if we clip the sub wires and leave the ANC wires, we might get similar results from the sub as we do the rear speakers... noise reduction without interference from the speaker. The sub is not included in the DL filter correction, so it interferes with the response when it is left plugged in... unplug it and it solves the issue... and the rear speakers and vibration reducing sensors still work to help cancel noise. Bypass the mics and it's a bit much for me when listening to sports radio.
I am hoping there is a way to get the best of both world... just need to experiment.
Absolutely!Oh so you want to know if earl Thomas is still in love with Brandon Williams.
Awe ! Lol
Yeah I like the drama sometimes more than the gameAbsolutely!
2020 Limited with Black appearance package^^^^. Nice, which version did you end up getting ?
