First build log here for me.
This will likely be a slow build/thread because I have very limited time to spend on it, but hopefully it will move along.
The Car:
2021 Camaro 2SS with the OEM Bose system (I need better pics of the car...)
A10 - Summit White - NPP - MRC - Adrenaline Red Interior Pkg - Black Appearance Pkg - Ground Effect Pkg - Suede Steering Wheel and shifter - Red Calipers - Carbon Flash Wheels w black lug nuts - DD Tinted Side Markers - Hero Tinted Rear Reflectors - Redline Fender Badges - 20% Tint
The Equipment:
OEM integration
DSP
Amplifiers - I was planning to do two amp racks for A/B testing but not sure if I can because of the space...I already had the ARCs from a previous install but I bought the Toros to play with.
Here are some pics from my first half-day work on it yesterday. I would really appreciate any ideas on how to do the amp install for the ARC amps. The Toros fit no problem.
I have no idea where/how to relocate the fuse box and that other device...
I removed the Bose amp and relocated the MRC controller into the bottom of the driver's side quarter panel. The wiring is the flimsy connector that comes with the Zen integration device. I will wrap all the plugs in CCF and then Tessa tape everything. The Zen will be installed on a vertical panel attached to the cross member and the panel on which the MRC controller is mounted
That's it for now. Will keep updating as I move along.
The Car:
The Equipment:
OEM integration
DSP
- (A) ARC Audio SE2300 - Subs
- (A) ARC Audio SE4200 - Midbass + Midrange
- (A) ARC Audio XDi 450.4 - Tweeters + (optional) Rear Fill
- (B) Toro Rage R4F - Subs
- (B) Toro Rage MRx2 - Midbass
- (B) Toro Rage MRx4 - Midrange + Tweeters (No real fill)
- Subs - (2X) Dayton Audio RSS265HO-44 in a sealed enclosure
- Midbass - Audio Frog GS690 in stock door locations
- Midrange - Audio Frog GS25 in stock dash locations
- Tweeters - SEAS Prestige H1396 27TFFNC/G in A-Pillars (need to fab)
- Rear Fill - Dayton Audio DC130B-4 in stock back seat side panel locations
- Resonix CLD, CCF and Butyl Rope
- KnuKonceptz Kolossus Flex power and ground, KNF-60 and KNF-36 distros, Krystal RCA and Karma SS speaker wires
