Going to be a long read but hopefully enjoyable to follow along with my rapid descension into the rabbit hole of car audio.
Finally had made arrangements to find a new 2021 6.2L AT4 in Satin Steel Metallic that had a confirmed delivery date to our local GMC dealer. This is a company truck for our family construction business. As most people know, inventory is literally nill nowadays and getting any sort of options on your vehicles (esp. GM trucks) cause major issues with delivery times. We found this truck with production spot but was coming with no options added but the basic AT4 trim is still decent enough. Love the truck and have had 3 of the previous Sierra body types. The 10 speed is fantastic and finally the interior are getting refreshed.
Before I jump into the audio side of this post, I wanted to briefly show what other mods have been done to the truck:
Exterior:
On to the audio side of my journey:
I knew I was going to make some level of audio upgrades because the truck was not coming with Bose system and regardless, the Bose system is a sad system in itself. So I began to research. Hadn't upgraded car audio in anything except high school, had an Infiniti QX4 with Alpine HU, Kicker 700.5, Some Kicker Speakers and CompVR10 Sub. So I started by setting a budget - initially wasn't planning on a sub, just speakers and an amp only and put $1500 as my goal. Long term, boy was I naive on my wants vs price of components.
I went Crutchfield and started a convo with an agent an was able to put together a system that seemed to check all my boxes. I was very, very green at this point and wasn't doing a ton of my own research or talking to many experienced installers. We had spec'ed a system with an amp but I needed to sort out a way to get my HU signal back to my amp. I eventually found LLJ Customs out of Arizona who specializes in custom wiring harnesses. They make a full plug and play wiring harness that intercept the 4 high level speaker outputs under the glove box and provides a long harness to mount your amps anywhere in your vehicle. I got the Loopback option which also includes an additional set of speaker wires that use the OEM speaker wiring without splicing, it is a massive time saver. I also had them added an extra set of speaker wires for my tweeters as I was going to keep my crossovers out back with my amp. Overall a great investment for someone who wants plug and play DIY, just take 5-6 weeks to get.
NavTV still isn't offering their module still, so this was my choice. I run digital now for music but still will use this as my analog source for chimes/nav/factory BT.
Build #1 - Speakers and Deadening Only (waiting for my LLJ harness)
"Deadening"
Infiniti Speakers.
Conclusions - To be honest, made a kick ass value oriented build. Had I actually used some CLD on outer and inner door shells, this would probably satisfy the average user. They are sensitive speakers and play most anything you throw at them. For running off just the HU, it was much better than expected.
Exterior:
- 20x9 Fuel Vector Wheels
- 275/60/R20 Michelin LTX Defender Tires (Drive 99% on road and the stock Duratracs are noisy af/also have Nokian winter tires)
- Magnum Headache Rack
- OEM Off Road Running Boards
- Illuminated Black Front GMC Emblem
- Black Rear GMC Emblem
- Black CarbonPro AT4 Emblems
- Black OEM Exhaust Tips
- Truxedo Lo Pro Tonneau Cover
- Bed Mat
- ProClip Phone Mount
- OEM All Weather Mats
- S&B Cold Air Intake
- Pulsar LT Programmer
- J&L Oil Separator
- Infinity Reference-9630x 6x9 - Components, Front
- Installed the woofer only during this phase
- Infinity Kappa 62ix - Coaxial, Rear
- Dynaliner CCF on outer shells of doors
- It took me months recognize this is useless without CLD
- Dynalliner CCF on inner side of plastic door panel
- Again probably helping with rattles but not resonance
- Dynamat Xtreme at Speakers
- Added some butyl rope to seal mounts and SoundSkins Rings
"Deadening"
Infiniti Speakers.
