2022 Ford Explorer ST - Helix, Mosconi, ZR, Illusion Audio
3 reading
126K views 651 replies 73 participants last post by  Mikiehotrod
#1 · (Edited)
I finally started really getting the installation started this week. I've been acquiring, designing, and building odds and ends for the past few months. I also picked up a new hobby learning to use Fusion360 and 3D print my own parts. Without further adieu, here is the component list.
OEM Interface: NavTV Zen A2B, Mobridge A2B Entry
DSP: Helix DSP Pro Mk3 w/ HEC BT HD module and Director
AMP1: Mosconi Pro 4|10 (Left - Tweeter, Mid-Range, Mid-Bass)
AMP2: Mosconi Pro 4|10 (Right - Tweetrer, Mid-Range, Mid-Bass)
AMP3: Mosconi Pro 1|10, Mosconi Zero 3 (Subwoofer)
AMP4: Mosconi Atomo 2 (Rear Fill)
AMP5: Mosconi Pico 1 (Front Sub)
Tweeters: Morel Supremo Piccolo Lotus , ZR Saturn
Mid Range: Morel Elate Carbon MM3, Dynaudio E430, ZR Prestige 9DD
Mid Bass: Morel Elate Carbon MW9 Focal 8wm
Rear: Morel Tempo Ultra Integra 602 Mk2 6.5", Audison Thesis 3.0 II VOCE
Rear Subwoofer: Raven 12XL, Audiofrog GB12, Illusion Audio C12XL
Front Subwoofer: Illusion Audio C10
Wiring: Blue/Clear Stinger HPM Series
Interconnects: Stinger 8000 Series, StingerX Tos-Link, PlanetWave Solderless RCA System, Audioquest Toslink
Sound Treatment: ResoNix CLD, ResoNix CCF, ResoNix Fibermat, Second Skin Luxury Liner Pro, ResoNix Barrier, BlackHole Tiles
Tuned by Jeffrey Hald (MTI, TotalTuningUSA)
Competitor Spotlight on the vehicle at Finals 2024
#2 ·
Man - this is truly a fantastic composition of gear. Going to be a killer, killer build.
Almost exactly what I’d spec out for myself if I did it all over again. The Raven is in my Top 3 for pieces of gear I’m curious to try alongside 3.5WM and the Morel Ultimo subs.
Next build I truly hope to integrate a Raven into it. How much air are you looking to give yours?
very much looking forward to seeing this one come together.
#3 ·
I’ll be curious to hear your thoughts on the single 12XL. A single C12XL just wasn’t cutting it for me so I wound up with a pair.
I really wanna try a pair of 12XL’s but I gotta get through this winter project first.
Reactions: lpreston
#5 ·
I'm not sure if it will suffice for me either, luckily the box my IDMax is in just happens to be the size I need for the Raven. The plan is to see if a single sub will do or if I will need to add a second one and add a second Pro 1|10. If I'm unsatisfied, my entire layout is going to change. I'll have to lose the spare and go your route.
#4 ·
Yea, I'm pretty stoked as this will be by far the best system I have put in one of my vehicles. I have been off all week, but didn't get as much done as I wanted due to it raining almost every day. I wanted to get the CLD applied to the doors, the amp rack mounting locations secured, and rack layout done. I wanted to have continued access to the spare tire, to I had to get a little creative with the amp rack mounting locations, but I got it figured out and got the tub around the spare tire deadened.
#6 ·
Tub has had Resonix CLD applied. It's not the best looking job, but it will work. Ill get the area under the trim when I'm ready to start running wire.
#10 ·
That's the idea, if it doesn't sound good, then clearly I did a :poop: install. I'm not looking forward to installing all the Luxury Liner Pro, that will be a Christmas break job as I will be off work for 2 weeks.
#8 ·
Mounting locations for the amp rack. I used some factory mounting holes to mount some 1/2" aluminum angle that will get 4" magnets so secure the rear of the amp rack. for the sides, I 3D printed some pretty thick brackets out of ASA, and for the center, I used a tall nut (I forget what it's actually called) and attached a 3D printed support that the center of the amp rack will be bolted to. The center support is made out of carbon fiber infused poly-carbonate. It's very stiff and has zero flex unlike the ASA where I wanted a little bit of flex. To remove the amp rack, I will simply remove the side 6mm bolts, the center 10mm bolt, and slide it back an inch to release the magnets; I can then simply lift the entire rack out of the way to remove the spare.
#9 ·
Once I got the 1/2" HDPE sheet cut, I started looking at layout of gear. My original vision of a 2 tier design to hide all the wires, but still make it accessible went into the toilet. So I looked for a layout that allows for easy accessibility and installation, but also still look nice.
Once I got a couple different options, I felt that option A and B would probably be the easiest for wire routing, but I don't thing I would be happy looking at my gear from the side, so I went with a variation of option B. Once I started working through the power wire routing, I found that there wasn't enough room to run all 6 4g wires around the right 1|10 amp, so I decided to build 11mm risers and run them under the amps. Signal cables will run around the left or under the amps also, I just have to figure out how to take up the excess cable.
Final layout.
Prototype risers being printed.
Finally, the HDPE looks like a sack of :poop:, so it's going to get wrapped with Matt Black Vinyl. I've never done a wrap, so we'll see how it goes tomorrow. Then I can get the heat-set inserts installed in all the holes and start wiring everything.
#12 ·
It was on back order and I wasn't really interested in paying 3 times as much. It did look to be much easier to work with and was probably worth it. Had it been available, I probably would have just bit the bullet, cried about it for a minute, and then got over it. I'll probably regret my choice later, especially after I saw how thick and stiff the LLP was.
#14 ·
So far, I have all my adapters printed. The most complicated thing I have been working on is a mount for the director. Think of it like a cup phone, but it will fit in this goofy spot designed for a small phone. I have the mount built, but I haven't created the part that actually goes in the location that the mount bolts on to.
#15 ·
Here is a rendering and an actual print of the Director mount I am working on. In the background of the pic, you can also see the center support for the amp rack that mounts to the existing spare tire support.
#17 ·
I designed it so that the mounting base can be what ever shape the end user needs it to be. I'm sure I'll still have to make some adjustments, but I think I got it really close. I may have to adjust the height depending on if I recess the base or make it flush with the console.
#25 ·
Update for the day. I got a lot of work done on the amp rack today. I did my first ever wrap using VViViDx Matte Black. I fully expected to have to do it twice, but I think it turned out pretty good. Good enough I wasn't going to redo it. I had some issues on the corners, but it will work. I also got the heat-set inserts installed and verified all the components mount to the mounting points correctly, then verified it fits in the vehicle securely and can be removed when necessary.
Before wrapping, I did sand it to ensure all the holes were flat from drilling and scuffed it up a bit to help with glues adhesion.
Wrapped and cutout the mounting holes.
Cutout all the mounting holes.
Installed all the M4x8 heat-set inserts and test fit the amp risers.
Made sure everything fit, amazingly I hold had to adjust one insert that was a little off. It was the very last one I put a screw in for the auxiliary distribution block.
And finally, a test fit in the vehicle.
I also installed the 4" magnets and the 3/4" steel strip on the bottom of the rack. I did a test to see how secure it is, and it will stay put until I slide it back for removal of the rack. It works as intended.
#28 ·
In all honesty, I wasn't sure if I would get into it either. I knew I was going to need a way to build things and I figured I would give it a try while I was waiting on all my parts for the build. So I didn't spend much on my first printer, but had the intentions of upgrading to to print higher temp filaments if I was able to learn it and the CAD part, and produce parts I felt were usable to my standards. I can be a bit OCD, so I had that hurdle to get over. I found that I liked it so much, I bought a second smaller printer as an upgrade project. If I stick with it, I may even buy one of the fancy Bamboo ones like Turb0Yoda has. Those things are getting great review and clearly, they can print some amazing things. I'm not a nic-nak collecting kinda guy, everything I print is functional and doesn't need to be absolutely perfect.
#29 ·
That's the flip side my ocd tends to make me hyper fixate on things so I think I would love it especially once I learned the cad part. I do end up watching alot of 3d printing vids on YouTube because I enjoy them pushing the envelope on what's possible. CNC/laser is just as interesting to me. Both can be costly though.
Hopefully I can get more or less settled this year coming up with less traveling. I'm supposed to be sitting at this one refinery for practically the next year and a half. Which is nice, even nicer when I'm working 70-80hrs weeks
#30 ·
A CNC that can do Aluminum is on my wish list. One project at a time though.
#32 ·
:cry:
Not rich, far from it. Not poor either. My mother died and we sold her house. Paid off my new vehicle and spent some on the tunes.
#36 ·
Well, it's dark when I get home so I am working on small things. Today, I got the shape figured out for the Director mounting base. The spot has a taper to it, so the top is actually wider than the bottom. The first full size test print is going to take a couple hours, I'll be able to test fit in the morning and adjust the angle if necessary. I'm also working on wire retention. Everyone (almost everyone) does the zip-tie method, I wanted something cooler looking so I am making these little doodads to hold the wires down. I"m making a bunch of 2 wires ones, I'll also make some 4 and 6 wires ones. They print pretty quick and actually look pretty good. And, yep; you are see that right in the last picture. I am missing a digit.
#40 ·
I've had a few, but that has been the worst one so far. It taught me a lesson on printing ASA, use a brim and reduce z offset.
#42 ·
My Tech Fun = Great for filament analysis
ModBot = One of my favorites
Teaching Tech = Also one of my favs.
Product Design Online = Fusion360 tutorials are very good and easy to do.
CHEP = nice short videos, but I can't get his profiles to work for :poop:.
Ricky Impey = Has some good tutorials on fine tuning the printers
There are several others, but those are the ones I watch whenever they have something new.
Chris Riely
Crosslink
BV3D: Bryan Vines
EB3D Printing
and a handful of others.
