1 - 20 of 77 Posts
· Registered
After a long pause, its time to get back into the SQ game, so I decided to start a new build.
The main goal is to build a stealth system in my daily driver.
The car: 2022 Toyota Prius aka. Project Uber SQ.
Source: Ill use two. First, the OEM head unit connected via high level into the DSP. Second, iPhone/Ipod touch into a Topping D10 DAC via coaxial digital into the DSP.
Speakers: IIAF Magnifica LE Carbon Fiber/Copper 3 way + 12" IIAF BL5 sub
Amps: Two IIAF D410 4 channel amplifiers. One for each side. Channel 1, 100 watts for the tweeter. Channel 2, 100 watts for the midrange. Channels 3 and 4 bridged to get 275 watts on the midbass. D135 Mono amplifier for the subwoofer (500 watts).
Processor: MINIDSP C-DSP 8X12 DL
Installer: Me.
Picked the car up from the dealer on June 22, 2022.
Car Wheel Tire Automotive parking light Vehicle
Car Wheel Automotive parking light Tire Land vehicle
Car Vehicle Land vehicle Vehicle registration plate Grille
Take a look at the dash. Its a pretty nice platform to start.
Vehicle Car Motor vehicle Automotive design Window
J.
· Registered
Discussion Starter · #2 ·
What do you do the first day you get a new car?
Take it apart, of course. LOL.
The top of the dash comes out in under 10 minutes, 5 if you hold my beer.
Motor vehicle Vehicle Automotive design Window Fixture
Hood Motor vehicle Automotive design Automotive tire Automotive exterior
Hood Motor vehicle Automotive tire Automotive exterior Automotive design
Tire Automotive tire Hood Motor vehicle Automotive lighting
White Motor vehicle Hood Automotive tire Automotive lighting
Motor vehicle Hood Automotive tire Automotive lighting Bumper
Grille Rectangle Grey Gadget Bumper
Grille Rectangle Musical instrument accessory Grey Bumper
Automotive tire Camera lens Cameras & optics Bumper Motor vehicle
Automotive tire Bumper Tool Automotive exterior Guitar accessory
J.
· Registered
The doors also come apart pretty easy.
Hood Automotive tire Motor vehicle Automotive exterior Automotive design
Added a bit of deadener and put it back together.
Hood Product Automotive design Motor vehicle Automotive exterior
Moved onto the hatch area.
Hood Automotive tire Motor vehicle Vehicle Automotive design
Added some deadener.
White Automotive lighting Automotive tire Hood Motor vehicle
Then the headliner suddenly came off.
Motor vehicle Hood Automotive tire Vehicle Automotive design
Window Hood Light Motor vehicle Automotive tire
Motor vehicle Automotive design Automotive exterior Window Auto part
J.
Reactions: bbfoto and M_Mark28
· Registered
Also did a bit of measuring.
First, had to get the mic out and measure the OEM system.
Land vehicle Vehicle Car Plant Automotive design
Computer Personal computer Product Peripheral Computer monitor
Then used the osciloscope to measure clipping on the front and rear speakers.
With a 1 khz 0 dB tone, the fronts clip at 51/62 and the rears 53/62.
With a 1 khz -5 dB tone, the fronts clip at 56/62 and the rears dont clip.
With a 1 khz -10 dB tone, the fronts and rears dont clip.
With a 50 hz 0 dB tone, the fronts clip at 54/62 and the rears 61/62.
With a 50 hz -5 dB tone, the fronts and rears dont clip..
With a 50 hz -10 dB tone, the fronts and rears dont clip.
Hood Light Automotive lighting Motor vehicle Yellow
J.
Reactions: vactor and bbfoto
· Registered
Very interesting , I didn't know you test each driver for clipping and thought you test your amps and headunit and be done. The build is looking very pro , keep up the good work. I'll checking the entire build progress !!
· Registered
With the last picture that shows the oscilloscope, I believe that he actually is testing the electrical signal from each amplified channel of the OEM system, not the acoustic "clipping point" (distortion) of each speaker. ;)
· Registered
Discussion Starter · #8 ·
bbfoto is right.
Since Im using the OEM hu as one of my inputs into the DSP, I wanted to know the clipping volume to be able to adjust gains down the rest of the gear with a clean signal.
The amps are here, just waiting on the speakers and this should move pretty fast.
Product Motor vehicle Bumper Rectangle Automotive exterior
Rectangle Packing materials Wood Shipping box Font
J.
· Registered
Hahaha facepalm to my self , I totally missed that picture and just went by his verbal description of testing front and rear speakers . I now see your testing for maximum UN-distorted output signal from the head unit , makes sense now.
i"ve never seen or heard of Italia hi-fi car audio products but those amps look business , I own some steg audio components and twister amps made in Italy and they perform beautiful , It looks like you're going all out for sound quality (y)
· Registered
bbfoto is right.
J.
Unfortunately, my experience with the SQ of all of the Toyota OEM head units or amplified systems I've done aftermarket installs in has been far from stellar. So, if possible, try to have the option to use a secondary "clean & pure" SQ source into your DSP using another input/preset, such as a portable DAP, etc.
EDIT: DOH! You already covered that in your OP. (y) I should have known better from this being another well thought out and high end Jorge/doitor install! 😊 :bowdown:
· Premium Member
Welcome back as I always enjoy your work. I took a break from car audio as well and now I'm back down the rabbit hole!
Reactions: carlos_93240
· Registered
Discussion Starter · #12 ·
Yeah, you should. LOL.
Thanks.
Welcome back to the madness.
J.
Reactions: bertholomey
· Registered
Looks like plenty of room on the dash and pillars to play.
· Registered
Discussion Starter · #17 ·
Yes, could do several configurations but will start with the easy one.
Tweeters in the a pillars, midrange drivers in the dash and mid bass in the kicks.
Power and speaker wire is also here, so its going to be a pretty busy weekend.
Auto part Jewellery Circle Rim Metal
Wood Tints and shades Chemical compound Electric blue Thumb
Plant Wood Natural material Tree Terrestrial plant
Plant Gesture Thumb Natural material Nail
Tree Wood Rim Audio equipment Eyewear
J.
Reactions: optimaprime
· Registered
Discussion Starter · #18 · (Edited)
Weekend progress.
First grabbed the OEM high level signal from the dash speaker harness.
Hood Bumper Automotive exterior Fixture Vehicle door
Wood Electrical wiring Wire Electric blue Twig
Solder.
Wood Electrical wiring Wire Cable Electric blue
Individual heatshrink.
Electrical wiring Wire Electric blue Electrical supply Cable
Paired heatshrink.
Hood Blue Pliers Sleeve Eyewear
Blue Wood Electrical wiring Hood Electric blue
Used electrical tape like the OEM harness.
Natural material Wood Computer keyboard Twig Fashion accessory
Electric blue Auto part Font Bumper Rim
J.
· Registered
Discussion Starter · #19 ·
Also started with the tweeters.
Leg Sleeve Chair Sportswear Waist
Made some mounting rings with acrylic and mdf.
Brown Wood Font Material property Flooring
Wood Nickel Jewellery Font Auto part
Hood Automotive tire Automotive mirror Vehicle Motor vehicle
Car Vehicle Motor vehicle Automotive design Speedometer
Footwear Product Chair Synthetic rubber Audio equipment
J.
Reactions: M_Mark28 and dgage
1 - 20 of 77 Posts
