I live in Mexico, just on the border with Mcallen, Texas.Aren’t you in Texas?
Yes, Ill be there.Gotcha. Are you doing the money round in Monterrey this weekend then?
Thanks.Wow, I enjoyed looking this thread through !
I see you use little sound deadening material - is this because there is little difference if you had covered all areas ?
Spesiffi thinking about the trunk
I have really enjoyed the MiniDSP as well, and your screenshots of the responses you got look very similar. Very cool that you are able to get up to 3k on the dash mounted mid ranges. I struggled with that because on my mid range placement in the dash - eventually, reluctantly moved to pillars, which really opened the response I could get from them.First DIRAC tune.
Followed the "Quick tuning guide" on this forum which made the process a lot easier.
Horizontal lines are 10db scale.
This is the tweeters graph.
Left=Purple
Right=Green.
Corrected response under yellow solid line.
Used a x-over at 1 khz pre-Dirac, but this tweeters can play pretty low.
Have them playing from 3 khz and up with 24 dB LR high pass.
This is the midrange graph.
Left=Yellow
Right=Blue
This speaker could play from 100 hz up to 6 khz in my install.
Have them playing from 320 up to 3 khz and up with 24 dB LR on both ends.
This is the mibass graph.
Left=Yellow/Orange
Right=Blue
This speaker could play from 60 hz up to 5 khz in my install.
Have them playing from 80 up to 320 hz and up with 24 dB LR on both ends.
This is the subwoofer graph.
This speaker could play from 16 hz up to 100 hz in my install.
Corrected response under purple solid line.
Have them playing from 80 with 24 dB LR low pass.
Gains and delay settings.
Im pretty impressed with the results you can get with the Mini DSP C8-12 DL and Dirac.
In 20-30 minutes it left the car sounding pretty good and it still has a lot of potential.
J.
Thanks, buddy.I have really enjoyed the MiniDSP as well, and your screenshots of the responses you got look very similar. Very cool that you are able to get up to 3k on the dash mounted mid ranges. I struggled with that because on my mid range placement in the dash - eventually, reluctantly moved to pillars, which really opened the response I could get from them.
Very good looking equipment! You make a top notch install look so simple and easy - great job!
I’d love to hear this car sometime next year
Had the chance to meet the guys behind the brand at the Lone Star Money Round event in Dallas early this year and really liked what they told me about the brand. Told them what my goals where and they told me what gear they had to offer. The gear is pretty solid. Hell I was able to play with the big boys over here with a diy garage build that I finished the day before the event. The speakers played music two days before the event and arent even fully broken in. To give you an idea, the top car has all Brax (speaker, amps, dsp), the other car has the full Audison Thesis HD, both built by pro shops and tuned by seasoned guys and still was able the be 1.25 points from the top and thats averaged from 4 judges. The car still has a lot of potential.Also - I don't think you mentioned it but what drew you to this speaker set ? I've never really heard of them or your amplifiers.
It sure felt like it.I’d call that a successful first outing. Congrats, man.
