1 - 3 of 3 Posts
I have two mint 2nd generation HCCA 225 amps. What should I do with them?
I've been toying around with putting a system together again and thought about pulling these out of retirement. Would it be worth using them in a modern system or has technology changed for the better?
Was thinking about running each mono for my right and left front channel or maybe paring them up to run a single 12". This would be in a 2004 Mach 1 mustang.
What would you do if you had a pair just sitting around? What would you pair them with?
sounds fun to me to use them. I'm 18 and I love OS stuff, works great and is often cheap. Running each mono for your speakers sounds good to me. Maybe use Image Dynamic 2 ohm comps to get the full power out?
1 - 3 of 3 Posts
